front wheel bearing DIYs? - LS1GTO.com Forums
Old 12-04-2013, 04:11 PM   #1
fishagto
fishagto's Avatar
Anyone have a link for a DIY on the front wheel bearings for an 05 GTO? Or a link for a free online factory service manual? I haven't had any luck locating a free service manual yet.
I went by Chevy today and they claim the front bearings only come as a pre-assembled hub unit with 2 tapered bearings inside for $450. Looking up parts at advance you can buy the separate bearings for about $13/each or a preassembled unit for about $150. It seems they are a typical tapered bearing with races and seals up front. Any reason I can't replace the bearings, races and seals at home?
Old 12-04-2013, 04:19 PM   #2
elephantrider
pea on mea
elephantrider's Avatar
check out rock auto. they have full wheel hubs from
$100 all the way up to $260.
they also have all of the bearings you need to replace,
but I would just do the full hub.
trico wiper blades
Old 12-04-2013, 04:26 PM   #3
schmen
schmen's Avatar
the entire hub needs to be replaced as a unit in the front. You cant swap only the bearing like you can in the rear.
nom nom nom
Old 12-04-2013, 04:31 PM   #4
1337vending
1337vending's Avatar
The one I had that failed ate the ABS reluctor, and as far as I can tell you can't buy that part separately. Also, it seemed to be permanently secured together, I didn't see a way to change the bearing.
I bought the timken front bearing assembly from rock auto, no problems yet. HA590006 and HA590007. Looks like they have some cheaper ones like raybestos that you could probably get for $100ish/set.
"You can sleep in your car, but you can't race your house..."
"My drinking team has a racing problem"
Old 12-04-2013, 04:55 PM   #5
Bbejj123
Bbejj123's Avatar
http://www.wikiauto.com/Pontiac-GTO-...ent-Front.ashx
this should help
Old 12-04-2013, 04:56 PM   #6
steamwalker
Goatlove
steamwalker's Avatar
06/QSM/A4
SoCal Goat Club
BFG / Borla / Edelbrock / Energy Suspension / King Springs / K&N / Koni / Lovells / Mishimoto / Whiteline
Old 12-05-2013, 04:52 AM   #7
fishagto
fishagto's Avatar
Originally Posted by steamwalker...View Post
http://www.youtube.com/watch?v=nyABZaLVhQ0
Nice link, thanks!
Old 12-05-2013, 04:53 AM   #8
fishagto
fishagto's Avatar
this should help
Very helpful, this is exactly what I need.
Old 12-05-2013, 08:24 AM   #9
high school goat
Retarded Spark
high school goat's Avatar
Send a message via AIM to high school goat
Biggest pain for me was getting the bolts out of the back of the hub. I pulled mine to put ARP studs in them.
SOLD
Old 12-05-2013, 08:42 AM   #10
Mock52
whats that smell? Its rubber
Mock52's Avatar
Send a message via AIM to Mock52
Does anyone have experiance with the Pedders front hubs? Are they worth the price? Im thinking my bearings are going bad and need replaced as well. Good to know that im not crazy looking for the bearings and only finding the Hubs.
2004 LS-1 M6 Torrid Red/on Red 1 of 517
K&N Air charger, B&M Shortshifter, JBA Short tube headers, TRS HIDs, DBA rotors with Hawk pads.
http://www.cardomain.com/ride/2360315
Old 12-05-2013, 08:51 AM   #11
fishagto
fishagto's Avatar
Rockauto has a "Pro" hub assembly for about $57, raybestos is $80. Anyone used the Pro brand hub assembly?
Old 12-05-2013, 09:43 AM   #12
My1970Boss
Noobie
My1970Boss's Avatar
What are these things on a time release to fail/wear I have a bad wheel speed sensor and was about to search this topic yet here it is. I've noticed Summit has a WIDE swing in prices for GTO wheel hubs any advice? I'll probably replace these when I do the CTS-V brakes, should I throw some ARP studs on while I'm at it?
Sent from AutoGuide.com App
Old 12-05-2013, 10:06 AM   #13
high school goat
Retarded Spark
Yes
Old 12-05-2013, 10:28 AM   #14
Napalm
Have Bar, Will Travel
Napalm's Avatar
Other Holden/HSV
Send a message via Yahoo to Napalm
Have you broken a wheel stud? are you intending a spacer and or some other wheel combo that necessitates a longer stud.
if the answer is no to either questions - save the money on the ARP studs as you won't ever care.
on the hubs I believe 2 companies make them. Timken and SKF paying less than 100 per is a little dubious to me. considering the amount of metal in them and the inbeded encoder.
Replacement is fairly easy - get an impact socket drive 10mm hex key. the impact socket drive is important as you might have to bang on it.
I've not seen a set of hubs that didn't come with studs already in them. Course the ones I bought were from Rock Auto.
Since Guns Kill People, Spoons Cause Diabetes.
Old 12-05-2013, 10:32 AM   #15
Napalm
Napalm's Avatar
Other Holden/HSV
surely on this site somewhere there are still pics of these - but the hub unit is sealed, and carries inside the inner bearing race the encoder for the ABS sensor. thus the non-rebuildable unit.
There once was a thread about replacing them - pretty easy, jack car, pull wheel, caliper and rotor, with 10mm hex drive you find the 3 bolts - take them out - hub falls out. I suggest cleaning said bolts and putting fresh blue loctite on them.
reverse removal - connect wire harness. should be golden. there is not a relearn process for ABS sensor replacement necessary.
Old 12-05-2013, 10:34 AM   #16
Spooky_pitboss
Zzzzzz......
Spooky_pitboss's Avatar
Send a message via AIM to Spooky_pitboss
Here's some service manual docs in case someone needs them to print out. Looks pretty straightforward nuts, bolts, and swearing.
Larger exploded images
Old 12-05-2013, 10:35 AM   #17
elephantrider
pea on mea
wonder why rock auto sells the bearings separately, if the unit is not
rebuildable...
here's a pic of a raybestos hub ( thx rock auto )
Old 12-05-2013, 12:26 PM   #18
fishagto
fishagto's Avatar
rebuildable...
That was my thought. I found the bearings at advanced auto and figured they were serviceable. At least there are cheaper than GM ($450 each) complete units available.
Old 12-11-2013, 05:40 PM   #19
fishagto
fishagto's Avatar
installed a new raysbestos front left hub assembly tonight. Took twice as long to get the rotor off than the actual hub assembly. No more bearing noise!
Old 12-11-2013, 05:55 PM   #20
slimbobaggins
Let's roll
slimbobaggins's Avatar
I would not use a chinese/tiwanese, or other far east built unit, except japanese. This is where you get what you pay for.
I went with Timken. Moog of course is good, if available.
757 GTO Owners Association of Tidewater
http://www.757goat.org/phpBB3/index.php
Originally Posted by CoolAid...View Post
Shaking/vibrating/rattling more is actually a bonus to me. I enjoy the Parkinsons effect at a stop light while the car belches out fumes of unburnt fuel from its monster lopey overlap. To me, thats muscle car.
Mods: ARP hardware, Shrouded valves
Old 12-11-2013, 06:00 PM   #21
GannyGoat
Transplanted Sooner...
GannyGoat's Avatar
I would have posted up if I'd seen this sooner, but it looks like you've got it handled. I did both my front hubs at about 120,000 miles since I was replacing shocks/struts/springs etc., and I was pleasantly surprised at how easily the old hubs came out.
By "easily" I mean "pounding the ever-loving shit out of them with a BFH" for a few minutes to break them free.
Strong work, fellow Goat man...Cheers!
TSP 402 w/"mild cam", CTS-V blower/intercooler @ 7lbs, LS3 heads, Nick Williams TB, Dynatech 1-3/4 headers catless mids, Magnaflow Competition 3" S/S with X-pipe, Speed Inc tune, FLT Street Performance T-56, Monster LT1-S Twin Disc Clutch GForce 1320 3.5-inch aluminum driveshaft/Level 1 Anti-Wheel Hop half shafts, DSS inner stubs, Eaton TruTrac, Motive 3.91's, Harrop diff cover, Monroe GT struts/springs, Kings HD front/HD rear springs, Whiteline sways, 19x8 Polished 5th Gen Camaro wheels.
Old 12-12-2013, 03:49 AM   #22
TObey
Where's my elephant?
Most rotors have a little threaded hole on the rotor hat. If the rotor is stuck, get a bolt, thread it in the hole, and it will usually pop the rotor right off.
That said, I can't remember if the GTO rotor has that threaded hole or not. It's been a while since I changed mine, and they came off pretty easy.
'05 M6 GTO
JBA Long Tubes with Catted mids, TSP Torquer V2, Vararam
421 hp, 394 ft-lbs
www.nismorons.com
Old 12-12-2013, 04:28 AM   #23
My1970Boss
Noobie
My1970Boss's Avatar
Anyone know what's different about the Pedders hubs, aside from $$$$?
Leaning toward the Moogs but if there is a "significant" difference I could be swayed.
Old 12-12-2013, 04:50 AM   #24
fishagto
fishagto's Avatar
Mine did not, but they are an aftermarket cross-drilled and slotted rotor, I looked for the threaded holes as well, no luck.
My car only has 49k on it, strange it would already have a bad bearing, but it definitely needed to be replaced. I actually couldn't get the rotor off, so I unbolted the hub, put a pry bar behind the rotor and pulled the rotor and hub off together. Put the rotor on a couple of 2x4s and hammered the old hub out.
Old 12-12-2013, 04:52 AM   #25
slimbobaggins
Let's roll
Email them and ask country of origin
Old 01-07-2014, 04:14 AM   #26
OliGeorgs
OliGeorgs's Avatar
I've never had problems with Timken. I've had and heard of endless problems with the inexpensive options.
2005 QSM
Texas Speed 403 stroker rotating assembly, Stage3 Livernois L92, BER Ported LS3, 237/248 .622/595 115+5 , 1 7/8" Kooks, K&N intake, HSRK, CC, SLP underdrive, Nolltec MM, Poly filled Trans mount, Non-Sponsor 2pc. DS, KAAZ, 3.70 gears, Jakes 4L80, Pedders Track II -3/8" front -1/2 rear, Air Lift Drag Bags, Harrop cover, Hotchkis bars.
Old 01-09-2014, 07:47 AM   #27
Napalm
Napalm's Avatar
Other Holden/HSV
rebuildable...
the bearings are for the rear of the car and are probably mis labeled. or they were for a 68 GTO and equally mislabeled. I noticed when I bought mine that Autozone's computer system was mislabeled. but they oddly had the timken ones so that's what I got.
name and money. IIRC the pedders ones are actually SKF bearing kits.
Not sure what MOOG is using but it might be the same.
Timken units are the OEM, IIRC. and they were usually resonable from online places. that's what I ended up with. worked out great.
Old 01-09-2014, 08:48 AM   #28
steamwalker
Goatlove
Just as an FYI, my Timken rear wheel bearings were stamped NSK. I asked Timken about this and they said they don't manufacture the rear wheel bearings and supply them from NSK.
Old 01-15-2014, 10:45 AM   #29
93RedDevilZ28
Girls in da goat = GT-HOE
93RedDevilZ28's Avatar
This is common in the automotive industry for bearing manufacturers. Typically, one company will make bearings of a particular size and provide to one or multiple bearing companies.
NSK bearings are pretty good.
2006 GTO. Life begins at 6 grand.
Old 01-15-2014, 10:48 AM   #30
miker
'12-'13 ScrScca SM Champ
miker's Avatar
Monaro CV8
Send a message via AIM to miker Send a message via MSN to miker Send a message via Yahoo to miker
Timken units are the OEM. Identical in every way. I got nearly 100k out of my first set of OEM units so I went with Timken the 2nd time.
I guarantee have seen 10 more abuse then anyone on here has put on them.
I changed them in just over 30 minutes the night before a track day.
- .218/.222 .601 Cam, Lunati HighRPM Lifters, Worked 243s, UDP, Oil Baffle, Comp Trunnions, Svede, ARP Bolts, Catless JBA Shorties, HSC Mounts
- 18x9 APEX EC7 / 285 RE-11, V2 Brembos, Coilovers, Bushings, Fastrack, Swaybars, ARP Studs, 15lbs Braille, Dual 3" Stainless Catback
- T56 Swap, Mantic Twin, Sikky, Quicktime Bell, LNC-003, Anti-Hop Axles, CF DS, TruTrac, 3.73s, Harrop Cover, Sparco Evo2s
- MavMan Hood, BMR Bar, Ron Davis, PS Cooler, CatchCan, AeroForce
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
