Post up wheel options on CTS-V bbk! - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Wheels/Tires
Old 08-18-2014, 04:30 PM   #1
blka4gto06
blka4gto06's Avatar
Like the title says post up pics of wheels you have on your 6piston front /4 piston rear ctsv bbk. I need to buy new rims and kinda wanna see what has worked and hasn't worked. Give details on offsets, tire sizes, spacer sizes etc.. And pics of course lol!
WHEN YOUR AHEAD NEVER LET UP!!
WHEN YOUR BEHIND NEVER GIVE UP!! -DALE SR.
FOR SOME LIFE IS RACING! EVERYTHING THAT HAPPENS BEFORE AND AFTER IS JUST WAITING! -STEVE MQUEEN
Old 08-25-2014, 06:28 PM   #2
Afroman
06 Cyclone GTO
Afroman's Avatar
Stock 18s lol
2006 CGM A4 Gone but not forgotten.
2006 IBM M6 New GTO!
2014 SS A6
Originally Posted by AlphaEden...View Post
you're quite the manwhore now aren't you
Originally Posted by mike5215@bellsouth.n...View Post
Owing a GTO is like marrying a stripper. You know it's wrong and it's going to end badly, but the sex is so hot you can't help yourself.
Originally Posted by Brians Goat...View Post
No he ain't doing no freaking manwhoring, he has a collar around his neck lately, he rarely shows up anymore on Saturday's and when he does he usually has some HOT babe with him who causes him to constantly drool and walk funny!!!!!!!
Old 08-25-2014, 06:41 PM   #3
Metallifan
FPFQ King
Metallifan's Avatar
I have the 4 piston kit in all corners.
Stock 18s. No spacers.
My drag setup. Rears are ZR1 reps 17x9.5 56MM offset with a 9MM spacer. 275/40/17, plenty of room for more. Fronts are 18x8 Focal High V custom painted/polished. 40MM offset. Clearance is so close it rubbed a bit of paint off my caliper.
668whp 643wtq | 12 PSI | Stock Bottom End LS1 | E85
Old 08-28-2014, 10:25 PM   #4
eviltwin_1987
Looking good
Old 08-29-2014, 05:11 AM   #5
Orinackra
Orinackra's Avatar
G8 GT Sport Wheels
Front: 245 35 19s ARP Studs, open lugs, 12mm spacer.
Rear: 245 40 19s Arp Studs, open lugs, 5mm spacer.
These two pics were taken before I got the rear studs and longer lugs, I was just doing some fit testing.
-Mitch
| 06 | M6 | SRM | Kooks | Magnaflow | SCSS GP | G8 19 | MM Spoiler |
| WCS Splitter | 6/4 Pot Brembo |
Old 08-31-2014, 04:36 AM   #6
itsme4g63
itsme4g63's Avatar
Enkei Kojin
Front 18" +35 245 Sumitomo HRZ3
Rear 18" +45 275 Sumitomo HRZ3
Had to grind bejesus out of rear fenders.
My 4 Piston Front Brembo 340mm http://www.ls1gto.com/forums/showthr...821&highlight=
My stock 17 4 Piston Brembo http://www.ls1gto.com/forums/showthr...448&highlight=
My 4 Piston Front CTSV Brembo 355mm http://www.ls1gto.com/forums/showthr...659&highlight=
My 6 piston Front CTSV2 Brembo 355mm http://www.ls1gto.com/forums/showthread.php?t=454917
Front/Rearkits can be purchased:www.bohnmancustoms.com ls1gto sponsor
https://www.instagram.com/itsme4g63/
Old 09-01-2014, 03:39 PM   #7
Tims05
Tims05's Avatar
Send a message via AIM to Tims05
Those look pretty familiar...now I know the ctsv brakes will fit
Old 09-01-2014, 04:18 PM   #8
blka4gto06
blka4gto06's Avatar
Looks like i might be going with a set of 18's.
Does anybody knows if they have made any of the vmr's fit I've seen a few pics of them but damn can't find them anywhere.
Old 09-02-2014, 03:52 PM   #9
gtomike60
gtomike60's Avatar
I have VMR VB3s on mine.
Front 18x8.5 40et with 8mm spacer and longer studs just clears the caliper.255/40/18
Rear 18x9.5 45et no spacer.285/35/18 with lip ground down 1/4 inch.
Car sits about 3/4 inch lower than stock.
Stock 6.0 LS2,TVS2300,3"front pulley,overdriven rear pulleys,Patriot Gold extreme valve springs,Non-Sponsor PC,Kooks 1- 7/8" headers,off-road mids,3" Kooks Street Screamer cat back,ArthurJGuy fuel system mod(Stock pump feeding venturi)full Pedder's w/xa coilovers,Hotchkiss sways,monster stage 3 clutch,RPM Level 5 T56,GMM race shifter,Hinson drop motor mounts,Non-Sponsor STB
Old 09-02-2014, 04:30 PM   #10
Cro
Cro's Avatar
These pictures are amazing guys, now I have to browse through that thread where they have the ctsv calipers conversion to do research on them.
Old 09-02-2014, 05:18 PM   #11
Metallifan
FPFQ King
Metallifan's Avatar
I have my old set for sale
Old 09-03-2014, 08:13 AM   #12
Cherry Pie
not as cool as fiveman
Cherry Pie's Avatar
Send a message via AIM to Cherry Pie
18x8.5/45 V710s on my car. I have the proxses V1 front brackets/BMW 740 front rotors and the front hub would push center cap out without a spacer. Added 1/4" spacers and all was good. Rear setup is the itsme4g63/bohnman adapter and I run 18x9.5/45 rim with no spacer.
5XX/5XX at the wheels. stock-ish.
old dyno DIY Dual Gauge Bezel
Old 09-03-2014, 01:47 PM   #13
blka4gto06
blka4gto06's Avatar
Okay what about VMR VB3 18x8.5/40et on the front with 8 mm spacers and longer studs and 18x9.5/45et rear read in another thread that this works with the 6/4 calipers.
Old 09-03-2014, 01:51 PM   #14
itsme4g63
itsme4g63's Avatar
Both front and rear should clear with those offsets and without the need for spacers up front.
Old 09-03-2014, 04:38 PM   #15
ERICV1972
Old 09-04-2014, 01:41 AM   #16
gtomike60
gtomike60's Avatar
Front VMR VB3s with 40et will not clear without a spacer due to the curvature of the spokes on the backside.
Old 09-04-2014, 01:42 PM   #17
blka4gto06
blka4gto06's Avatar
http://www.ls1gto.com/forums/showthread.php?t=527633
Oh Yea found it!!!!
Old 09-04-2014, 02:58 PM   #18
Cro
Cro's Avatar
So running a BMW rotor requires running a additional spacer?
Old 09-04-2014, 03:13 PM   #19
Metallifan
FPFQ King
Metallifan's Avatar
Not by itself. Depends what wheels you run. And IIRC it depends what bracket kit you get. I have Bohnman's kit and Camaro SS on the front and C6 Z06 in the rear. 14" and 13.4" respectively.
Old 09-04-2014, 04:25 PM   #20
Cro
Cro's Avatar
So with your set up, there isnt a need for spacers? And ctsv calipers say, woul require a spacer on your setup, or once again it would depend on wheels?
Old 09-04-2014, 04:37 PM   #21
Metallifan
FPFQ King
Metallifan's Avatar
On the OEM 18s, no spacer was required. On my drag setup, a 9MM spacer was required only on the rear wheels. It always depends on the wheel. Spoke/barrel design and offset are the biggest factors.
Old 09-04-2014, 07:23 PM   #22
Cro
Cro's Avatar
How much did it all cost you? Including pads, hardware kit and paying for labor to bore the rotors? I'm estimating around $1500, give or take, depending on rotors and pads quality. Honestly, how much difference did I make, is it worth the mod just for the brake effect?
Old 09-05-2014, 04:57 AM   #23
xviperx26
Originally Posted by Orinackra...View Post
G8 GT Sport Wheels
Are the spacers for caliper clearance?
2004 YJ Procharged M6 - 47K miles
580/540 RW Dr. Phil SD
Old 09-05-2014, 08:01 AM   #24
66 LeMans
My what a large key you have!
According to the ultimate CTS-V conversion thread the VMR 705 will clear front and rear without spacers.
Old 09-05-2014, 11:27 AM   #25
Metallifan
FPFQ King
Metallifan's Avatar
Depends on rotor/pad selection. I bored my rotors myself. $1,500 is about right.
The difference between the 04 brakes was downright ridiculous. The stopping power is amazing. And there's 0 fade after multiple slow-downs from triple digit speeds consecutively.
Old 09-05-2014, 01:26 PM   #26
Cro
Cro's Avatar
Thank yo for the info. It sure is pricy, I'm not sure if I really wanna do this but it very appealing.
Old 09-05-2014, 01:40 PM   #27
Metallifan
FPFQ King
Metallifan's Avatar
Way cheaper than any other BBK.
Old 09-08-2014, 07:50 AM   #28
Orinackra
Orinackra's Avatar
Yeah. The spokes on the front and rear were hitting the calipers.
Old 10-28-2014, 12:46 PM   #29
Tony Luna
Tony Luna's Avatar
Guys, I am DONE with my Wilwood BBK and want to go with the CTS-V 6 piston callipers upfront and 4 piston rear using Bhonman's (itsme4g63) mounting brackets.
I am currently running VMR VB3s in a 19x8.5 ET40 with 245/35/19 Michelin PSS - lowered about 1".
I'm reading conflicting info on whether the wheels will clear the caliper without a spacer. Is anyone actually running these wheels with the Brembos? I can't see how it would work if I need a spacer (without excessive negative camber).
Thanks.
05/PBM-Red/M6
TVS 1900, LPE fuel pump, DMR catch can
Pedders Track II w XA Extreme Coilovers, Fast Rack w SS lines and larger cooler, Hotchkis sb F & R, 6 piston CTS-V BBK, 19" VMR CSL 8.5/245/35F 9.5/275/30R.
GMM Ripshift Street w JHP short shaft, LS7 clutch w 2QWK4U MC and lines, Harrop diff cover, G-Force CF DS and L2 half shafts, Hinson mounts, Bassini cat-back
JHP gauge pod, sport wheel, Bluetooth, door lock, SSCC fuel pressure gauge
Various Maverick Man CF parts, VX tails
Old 10-28-2014, 01:32 PM   #30
itsme4g63
itsme4g63's Avatar
Thanks.
Based on the wheel construction and offsets at that width you shouldn't have issues clearing them.
Damian
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
