Having that supercharger itch - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Forced Induction
Old 03-12-2017, 09:31 AM   #1
sgtwode
GOT GOAT? WHAAAAT???
sgtwode's Avatar
Hello. I was wondering what would be needed to have a complete supercharging system installed on my gto. What would be needed? Maryland Speed Shop offers a supercharger packages. Right now I have 2006 M6 and the usual bolt-on's, headers and CAI. Would I need rear axle upgrades, trans upgrades etc to make it street user friendly.
Old 03-12-2017, 04:51 PM   #2
Obey the Goat 04
im in the middle of my first build but from what ive read , theres alot of work to be done to get it to last and not toast something .
04 gto
gmm ripshift with lou's ss
dss 1 piece aluminum DS
dss anti-wheel hop half shafts
vcm otr intake
3.90's
comp cam .566/.568 112
pacesetter LT's and o/r extensions
flowmaster american thunder catback
ticks stg2 t56
prof pref manifold 85mm/90mm ported TB
(soon to be fast 102 manifold/TB after ported 243 heads )
Old 03-12-2017, 08:31 PM   #3
BigEd
Coco Conocido
BigEd's Avatar
All you really need is an upgraded clutch. That stock one wont last.
Old 03-12-2017, 09:40 PM   #4
dre0396
dre0396's Avatar
Well unless you really want to go nuts and replace a lot of stuff. Do a
Clutch and run it until you find your week link. Like anything it will all depend on how hard
You beat on it. In time you will need a driveshaft but that's with any gto auto or manual in time. Then you will find the next week link. It's a never ending cycle with a hot rod.
Old 03-12-2017, 10:12 PM   #5
sgtwode
sgtwode's Avatar
Ok gotcha. I'm pickin up what you guys are droppin. Thanks for the info. On that note do you guys feel I would have to upgrade the cam and other internal engine components?
Old 03-13-2017, 10:57 AM   #6
dre0396
dre0396's Avatar
No if are running low boost. But to get the most benifit out of a
Supercharger. Then you need at least forged pistons rings gaped for the added heat. What happens most of the time on the stock motors once boost is added is you brake a ringland.
If you run low boost 6-8 lbs and add water meth kit it will help the heat and detonation.
Old 03-13-2017, 03:13 PM   #7
Jailor
TIRES!
04 yj m6 mp 112, 2.7 pulley, meth, vhp custom cam 232-240 585-585,1.8 yella terras, 480/491 dyno jet monster stage 2
Old 03-13-2017, 04:28 PM   #8
mike haworth
mike haworth's Avatar
E85!....in the finishing stages of mine, went with an LSA unit, ID850s, dual walbro...
learguy
Old 03-13-2017, 04:57 PM   #9
sgtwode
sgtwode's Avatar
Ok. I see what your saying. Many options to choose from to do it right
Old 03-14-2017, 09:17 AM   #10
CGMike
CGMike's Avatar
I have the TVS1900, 1:1 rear pulleys, magnaflow 3inch cat back, LPE intake, walboro 255 fuel pump (added the magnuson boost a pump as well just to be safe), a smaller 3inch pulley (the supercharger comes with a 3.2inch), a custom tune and that's it. The rest of the motor is stock. It made 503 @8psi. I could throw headers on it and make another 40hp or so. I did upgrade the clutch to a McLeod RST just because I was worried about slippage but I ran the stock clutch for a while and it held up fine as long as I didn't beat on it a lot and gave it time to cool down between pulls.
If you want a supercharger, get the TVS1900 and stay with the stock pulleys (6psi), get a bigger fuel pump, and get it custom tuned to be safe. Don't beat on it and itll be fine. When you get the money, upgrade the clutch.
06 CGM M6 "This Goat Doesn't Graze" TVS1900! Mav Man Diffuser CCW 19 inch SP20s staggered OEM grey stitching and grey face gauges. 503hp 495ft/lbs of torque @ 8psi
Current Other Cars:
59 VW Bug 1914cc
64 Nova 327 and Muncie, new project.
06 WRX VF43. Mild built motor
06 Dodge Ram 2500 Cummins 4x4
www.facebook.com/Avcarsandcoffee/
AV Cars And Coffee every 3rd Sunday
Old 03-14-2017, 10:33 AM   #11
ForzaFTW
ForzaFTW's Avatar
My supercharger setup was a bit more extreme; I just bought a CTS-V2 instead
Seriously though, you'll need a clutch, and probably some drivetrain components after a while, you might as well at least do a blower cam to get more power out of it, installing the supercharger kit puts you a good bit of the way there already.
Old 03-14-2017, 10:47 AM   #12
Lakegoat
Lakegoat's Avatar
Magnuson makes a TVS2300 for the GTO. No more 1900.
TVS 2300, 4L80
Old 03-15-2017, 09:03 AM   #13
MP_gto
6POINT0
MP_gto's Avatar
if your wiling to fab up a few brackets n things the universal e-force tvs 2300 works well.
I have had zero issues with the blower itself, but almost destroyed everything else on the car with the added power. Im constantly working on weak links the added power finds. Hopefully I have found about all of em.
at minimum you will need clutch if your m6 . if auto your on borrowed time with the 60e throw it away and go 4l80e when you burn up 3/4 (not if WHEN)
1pc Drive shaft for sure the stock 2pc will be trash quick.
Axles can prolly wait unless your launching hard on stickies.
good BRAKES! adding a lot of power and weight...
you will need to increase your tire budget for sure.
05 banana - Forged LS2 Wiseco / K1 / ARP stuff, E-Force TVS 2300 @~12.5psi on e85, TSP 224R, 1 7/8 LT, SLP LM2, Dual in tank WB450's, 4L80E / 3600 , other fun stuff
Old 03-19-2017, 01:45 PM   #14
sgtwode
sgtwode's Avatar
I do appreciate all the good info. I see Maryland Speed Shop has supercharges for sale. I'm not sure what the difference between the tvs1900 and tvs2300, other then price. Can someone sort of break it down.
Old 03-20-2017, 11:38 AM   #15
Lakegoat
Lakegoat's Avatar
The 1900 is a 1.9 blower, the 2300 is a 2.3 blower. 2300 has a Larger case and more possible boost with the 2.3. There may be injector differences, I don't remember.
Old 03-20-2017, 12:24 PM   #16
sgtwode
sgtwode's Avatar
Ok,,,,good to know..thank u...
Old 03-20-2017, 05:13 PM   #17
sgtwode
sgtwode's Avatar
Also I was wondering if I could use a Vararam CAI system to a tvs2300???? All the set up systems I've seen are using the standard aftermarket K&N CAI etc systems.
Old 03-20-2017, 11:16 PM   #18
sgtwode
sgtwode's Avatar
After digging further into this forum I did find a post indicating a Vararam CAI will not work with a Magnuson TVS2300 due to the front pulley hitting it. Idk I guess back to the drawing board.
Old 03-21-2017, 09:04 AM   #19
96SS390
96SS390's Avatar
Back to the drawing board on the Supercharger or the CAI? I would hope that your intake choice would not limit your choice in supercharger.
2006 BOM M6 l FAST92 l LPE CAI l Kooks Stepped Headers/Catless Mids l Magnaflow 2.5" l Pedders XA l GMM Race l GForce Axles/Stubs l Harrop Cover l SJM Line Lock l JamesBiz CC l BMR Skid Plate l Katech Coil Relocation/Covers l OEM 18" Wheels l More to come...
Old 03-21-2017, 12:41 PM   #20
sgtwode
sgtwode's Avatar
No, but I just had a Vararam CAI installed and would hate to have to get a new CAI system. I was hoping it would fit or at least be modified to fit a Magnuson CS. IDK..
Old 03-26-2017, 10:30 AM   #21
tron121
tron121's Avatar
Just the Maggie kit and nothing else is a very nice mod. Gives you lots of under the curve torque and its easy to install. If I got a second goat for a daily I would be real tempted to just Maggie it and that's it. Sure if you launch it from a dig every day your clutch and driveline are going to hate you....but are you really going to do that?
Trust me if you start in with the "while I'm in there" mentality it never ends. Not necessarily a bad thing....but its a slippery slope.
EDIT:
That CAI or a Maggie? Sell the CAI....no problem. Get another.
2004 PBM M6
505RWHP/568RWTQ
MODS: "The car is equipped with everything anybody can imagine" -Inspector Detector
MOD List: http://sdrv.ms/1bje9Nj
Old 03-26-2017, 10:38 AM   #22
tron121
tron121's Avatar
Some encouragement.
Old 03-26-2017, 12:47 PM   #23
Lakegoat
Lakegoat's Avatar
Just use the supplied Maggie intake tube and do this
Old 03-26-2017, 02:29 PM   #24
jkaschyk
jkaschyk's Avatar
You're better off with the stock air box and a K&N drop-in. These cars love cold air.
Old 03-26-2017, 07:06 PM   #25
sgtwode
sgtwode's Avatar
Yeah I think u are both right. I appreciate the video and ideas. I'm sure I can sell the Vararam without problems.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
