Bassani Owners HELP! - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Exhaust
Old 03-17-2017, 07:28 AM   #1
blk00ss
Finally bought a Bassani catback for my 2005 GTO. Install was pretty straight forward, except for one issue. Does your passenger side intermediate pipe sweep way low by the diff? Considerably lower than the driver side? I can't even get the pipe high enough, with the hanger parallel to the ground to get it in the rubber hanger (see photo). Note the hanger in the background, you can see I have it going diagonally up into the rubber hanger. Cannot get it parallel with ground. I see no reason the passenger side couldn't be up and more snug like driver side.
I have rotated and rotated. I could maybe use floor jack to push pipe up and get into hanger? f course when that pressure is released I assume that rubber hanger will be stretched quite a bit. Disregard old catback I'm straddling
All help appreciated.
Old 03-17-2017, 11:17 AM   #2
jamesgiants76
jamesgiants76's Avatar
I don't have that exhaust but I'd say something is wrong.
Sent from my XT1254 using Tapatalk
Old 03-17-2017, 11:32 AM   #3
SkiPopeye36
FPFQ Herder
SkiPopeye36's Avatar
Nope, that's not right at all.
2005 M6 GTO
CGM | CCW SP550 | Pedders Xa | Kooks | Spintech | Ed Curtis Cam | FAST 92 | Duspeed | GMM | Street Slayer Clutch | Billet Prototypes | JHP Pod, Spoiler, Steering Wheel | GTOG8TA SAP Grilles | Etc.
Old 03-17-2017, 11:53 AM   #4
blk00ss
Exactly. If I turn those intermediate pipes where the hangers are parallel with the hanger they going to hook to, there is no way this system is going to tuck nicely. I don't get it. I even swapped intermediate pipes from left to right to see if maybe I had the wrong side. No dice
Old 03-17-2017, 12:22 PM   #5
JSRacing
JSRacing's Avatar
Here's a picture of my Bassani exhaust. Its a real pain to get everything liked up. I never did get the tips centered in the exhaust cutouts, need to get it on a lift to make it a little easier.
'05 YJ M6
X-air OTR Filter
Kooks signature series stepped headers
Kooks catless mids
Bassani catback
SLP 25% UDP
CSP ported intake
CSP ported TB
CSP tuned
Hinson Engine/Trans Mount, Shifter
VRM V710 Black
Old 03-17-2017, 12:49 PM   #6
blk00ss
Thank you for the photo. The intermediate pipes have different hangers welded onto them. Can you tell me...the hanger pic below, are you using the intermediate pipe with this hanger on your driver side?
Old 03-17-2017, 02:21 PM   #7
JSRacing
JSRacing's Avatar
Yes I'm using all of the hangers provided with the exhaust.
Old 03-17-2017, 03:25 PM   #8
blk00ss
Thanks again.
I think I'm dealing with 2 issues...
1) The only way I can get either pipe hanger up to the factory hanger is by using a floor jack to push the pipes upward where they are supposed to be.
2) I'm using the supplied clamps and I don't think I'm getting them tight enough. I noticed this evening even with a cheater bar I was still able to twist the pipe side to side even though the clamp was "tight". So I'm thinking as I'm buckling things down, the other piece of the pipe is actually twisting the pipe just a little making it lower to the ground while I'm tightening the rear clamp
Old 03-19-2017, 08:31 AM   #9
A_VAS
A_VAS's Avatar
Online
the clamps do take some decent torque to tighten, I think in the instructions it calls for 60 lb-ft?
I leave them all loose but snug so you can rotate some as needed, use the jack to keep it all tucked up...hang it and then tighten from front end working to back.
Here's a bit of what I'm into:
Short & Long Blocks - build to order
Basic rebuilds to Darton sleeved strokers
GTO rear end parts and rebuilds
Dana Gearsets (OEM Australian)
OEM seals, crush sleeves, pinion nuts, ring gear bolts, pinion shims.
specials on 3.73 and 3.91 gearsets now
Old 03-20-2017, 09:24 AM   #10
blk00ss
Appreciate the advice.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
