Car doesnt attempt to crank - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Electronics
Old 03-19-2017, 03:26 PM   #1
Nogomofo
Hot Rod A.D.D!
Nogomofo's Avatar
I just finished installing my differential and now the car doesn't even attempt to start. I had a race battery in it that was weak so I swapped it out with a fully charged regular size unit , all lights turn on but the solenoid doesnt even click!
I tried to jump it , tried leaving the key on for 10min, unlocked everything with the fob, pulled the cables and the ecm cables....no change.
I've checked every fuse , swapped relays around and I cant even get a click.
Out of ideas , short of replacing the starter but I cant see why a functioning unit would just fail all together.
Oh and no security light on...
1970 Nova 468ci Th4001971 K20 longbox 350ci TH3501972 Scout II 345ci 727
1966 MGB Roadster 1.8L 4spd
2005 GTO 6.0L M6 11.54@123.6mph N/A 364ci ls2
Old 03-19-2017, 04:02 PM   #2
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
Check the terminal at the starter relay to see if it gets voltage when the ign key is turned, the one that commands the relay to activate.
( 'o')b
( '_')o
(._. )
Old 03-19-2017, 04:06 PM   #3
Fox Mulder
Alien Moderator
Fox Mulder's Avatar
Check the clutch switch, make sure it's not as simple as something stuck under the pedal (floor mat) not allowing it to go down all the way. It happens. If it's visually ok test with a meter or jump it out. There are two switches, one for starter safety and one for cruise disengagement, so look at the right one.
05 GTO/ '15 WRX/ '02 WRX
Old 03-19-2017, 04:14 PM   #4
Nogomofo
Hot Rod A.D.D!
Nogomofo's Avatar
Good idea!
I jumpered the upper switch, which one is the clutch safety switch?
Old 03-19-2017, 04:19 PM   #5
Fox Mulder
Alien Moderator
Fox Mulder's Avatar
It's the one right above the master cylinder pushrod. Contacts should close when the pedal is fully depressed.
Old 03-19-2017, 04:40 PM   #6
ಠ_ಠ
Do you have a 2-step? Just wondering.
Old 03-19-2017, 05:12 PM   #7
Nogomofo
Hot Rod A.D.D!
Nogomofo's Avatar
yep, the wire I had my two step pig tailed off of got pulled out .
IT RUNS!
Old 03-19-2017, 05:19 PM   #8
ಠ_ಠ
IT RUNS!
Old 03-20-2017, 09:36 AM   #9
Magnified
It's simple physics
Magnified's Avatar
out standing
LR
2006 PBM (now dirt brown) A4, Magnacharger, Kooks LT, high flow cats, Magnaflow x-pipe, stock pipes into race glass packs, drag bags, subframe connectors/jacking rails, 18x8.5/40 offset Bayern Mesh chrome up front, 18X9.5/45 in the rear, Michelin Pilot Sport PSII, fender roll, DIY catch can, DIY factory amp mod, tuned by Chuck, black badges.
Street configuration consistent #s ONCE UPON A TIME - 12.13 / 117.5 / 1.90 60 foot. 3.75 second 0-60. Lots of wheel spin.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
