C5 brake pads on stock brakes? - LS1GTO.com Forums
Old 03-20-2017, 03:37 AM   #1
magisnyc
Just wanted to confirm... we can use C5 brake pads on stock calipers/rotors?
Shops don't always have a large selection listed for GTO but if they are the same as corvettes then its easier to shop for those.
Thanks.
Old 03-20-2017, 04:45 AM   #2
SkiPopeye36
FPFQ Herder
SkiPopeye36's Avatar
Yes, all C5 pads (except for Z06 I believe) fit 04-06 calipers.
2005 M6 GTO
CGM | CCW SP550 | Pedders Xa | Kooks | Spintech | Ed Curtis Cam | FAST 92 | Duspeed | GMM | Street Slayer Clutch | Billet Prototypes | JHP Pod, Spoiler, Steering Wheel | GTOG8TA SAP Grilles | Etc.
Old 03-20-2017, 05:15 AM   #3
Duckman
Kollar Racing Products
Duckman's Avatar
FRONT C5 Pads and 05-06 Pads are the same. 04s are a unique pad...same steel different block. C5 pads will working an 04
THE NORTH AMERICAN DISTRIBUTOR FOR LOVELLS & ROADSAFE PRODUCTS
NEED TECHNICAL SUPPORT? SUPPORT IS AVAILABLE EVERYDAY 8AM-8PM EST
631-902-2276
http://kollarracingproducts.com/
sales@kollarracingproducts.com
GREAT PARTS, GREAT PRICES, FAST SHIPPING.....
Old 03-20-2017, 11:08 AM   #4
magisnyc
Are you saying they will or will not work on an 04?
I originally meant the front pads but to be clear for future searchers the rear pads are the same as C5 as well?
Old 03-20-2017, 11:37 AM   #5
dantheman
ROW ROW ROW...
dantheman's Avatar
Send a message via AIM to dantheman Send a message via MSN to dantheman Send a message via Yahoo to dantheman
when i ordered my carbotech race pads for my 04 calipers i ordered the C5 pads and they worked fine.
SNL 346, AFR 205s, TSP 233/239, Fast 92/92, SSOTRCAI, SW LT's, Full 3in Catback with Xpipe and magnaflows, Monster LT1S twin disc, RPM level 4 trans, gforce CF 1pc DS, pedders street II, staggered VMR V710 18s.
465/422
Old 03-20-2017, 11:46 AM   #6
SkiPopeye36
FPFQ Herder
Yes, ALL base C5 front pads will fit 04-06 front calipers. Rear pads/calipers are different than corvettes. ALL GTO rear calipers from 04-06 are exactly the same and use the same pads. Only difference is that the 05-06 calipers are red.
This is well documented on here as well with a simple search:
http://www.ls1gto.com/forums/showpos...33&postcount=5
Old 03-20-2017, 04:40 PM   #7
Rob
Been here for a long time...
Rob's Avatar
I've been running AC Delco ceramic pads since new, ~100 miles. Part number is 88909667.
Never had a problem with them.
Rob
04 GTO
75 Cosworth Vega
Old 04-08-2017, 06:15 PM   #8
5ft24
How are the ceramics dust-wise?
Sent from my VS995 using Tapatalk
Old 04-09-2017, 04:43 AM   #9
Rob
Rob's Avatar
Virtually no dust for me. That's why I switched when the car was still new. I'm not hard on brakes though. Just checked them and they are about 1/2 pad left with 39K on them.
Old 04-09-2017, 05:06 AM   #10
dizzysn
dizzysn's Avatar
Send a message via AIM to dizzysn
C5's all used the exact same brake set up, so there is no specific Z06 pad, and they technically would fit.
RIP - Sgt. James E. Lyons. Apache Company Senior Sniper, 1st 1FT Squadron, 2nd Stryker Cavalry Regiment. Aug 13th, 1987 - Sept 12th, 2011 - KIA.
2004 YJ M6: SOLD
2002 Electron Blue C5 Z06: LS7 clutch, American Racing LTs, XSP exhaust, Vararam CAI, MGW shifter, RPM 3 cam: 114 LSA, 236/242, RPM lvl4 trans: 430rwhp/385ftlbs.
Old 04-09-2017, 06:04 AM   #11
SkiPopeye36
FPFQ Herder
Rotors and calipers are the same base to Z06, but I know the pads are different on a Z06. Have you confirmed that a Z06 pad does indeed work? I've yet to find confirmation.
Old 04-09-2017, 10:01 AM   #12
dizzysn
dizzysn's Avatar
The pads are exactly the same for the C5, C5Z as well as the base C6. If you look up kits on Marylandspeed or KNS they don't differentiate between the C5 models, and many of them include the 04-06 GTO in the compatible models list.
http://marylandspeed.com/stoptech-st...10-p-5046.html
The "excluding Z06/Grand Sport" is in reference to the C6 Z06/GS.
I 99.99999999999% certain the only difference from the factory between the base and the Z06 was that the calipers were red and the Z06 came with a slightly more aggressive pad from the factory (still had the same pad dimensions though), but once you go to aftermarket pads there would be no difference between them anyway.
Old 04-10-2017, 03:21 AM   #13
gto57
Is that FWD?
gto57's Avatar
I am running C5 Hawk Performance Ceramic pads up front and Ceramic in the rear for GTO.
2004 GTO - Quicksilver A4 (437rwhp 371rwtq)
Engine Mods: Livernois Stage III LS6 heads/cam | Cam - Duration 224@.050, Lift .568", LSA 114
Fast LSRX 102mm Intake | Fuel rails | LPE 100MM MAF | 105MM Accufab TB
SvedeSpeed OTRCAI | JBA Shorty Headers | JBA Mids w/Cats | JBA Catback
Appearance: Banshee Hood | Banshee Dual Outlet Exhaust Inserts |DBA Slotted Rotors | Hawk Ceramic Pads
ROH Fury Black Ice 19x8 | Michelin PSS 245/35/19
Drivetrain : Gforce Half Shafts | Inner Axle Stubs
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
