Cold air intake pulling out of couplers - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Tech Lounge
Old 05-15-2017, 08:41 AM   #1
Wahoo
So I did an auto x yesterday and the intake pipe kept popping off the MAF, kept pulling out of the coupler.
I'm thinking my engine mounts are now weak/old, they're probably original with about 104k.
Anyone else experience this?
Old 05-15-2017, 10:42 AM   #2
Rich-Tripower
Rich-Tripower's Avatar
Do you not have a flexible coupler in the stream anywhere?
2015 Honda Accord EX-L V6 HFP
Rich's 1965 Malibu SS L79 Restoration Page
Rich's 1965 Chevelle Two-Door Wagon Project Progress Page
Bob's 1964 GTO Project Page
Rich's Brazen Orange 2006 Pontiac GTO
Rich C.
"I would rather appreciate what I cannot have than have what I cannot appreciate."
Old 05-15-2017, 10:45 AM   #3
Wahoo
The car has the Vararam cold air intake and it has silicon couplers but they're a bit old I think one developed a rip as well.
Old 05-15-2017, 10:50 AM   #4
cookmeup272
I guess I'll ask the stupid question, is there a clamp on it?
2004 GTO LS1 M6 - SBE, PRC 2.5 62cc Heads, PRC .660 springs, MagicStick v3 cam, Melling High Pressure oil pump, Cometic 0.040" headgasket, Trunion Upgrade, TSP 7.450" pushrods, LS7 Lifters, 42lb injectors, underdrive pulley, Mishimoto radiator, Awespeed intake, Kooks longtubes/Catless mids, Borla catback, Monster Stage 3, 15" Race Star's, MT ET Drags
Best run - 12.1 @ 115, 1.8 60' with above setup/275 Nitto 555r's
12.8 @ 108, 1.8 60' with intake/exhaust/555r's
Old 05-15-2017, 11:10 AM   #5
DangerNoodle
The battle of wits has begun.
DangerNoodle's Avatar
Annnnnnnd replace the coupler.
Ha ha! You fool! You fell victim to one of the classic blunders - The most famous of which is "never get involved in a land war in Asia" - but only slightly less well-known is this: "Never go in against a Sicilian when death is on the line"! Ha ha ha ha ha ha ha! Ha ha ha ha ha ha ha! Ha ha ha...
Old 05-15-2017, 11:26 AM   #6
cookmeup272
I've never had an issue with any of my couplers coming off. And honestly, I don't see how they would ever be able to. Its such a pain trying to remove the maf or intake just from how squeezed everything is in there. So....
Old 05-15-2017, 11:41 AM   #7
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
oh dear.
( 'o')b
( '_')o
(._. )
Old 05-15-2017, 11:48 AM   #8
CGMike
CGMike's Avatar
On turbo cars, we used to use a little bit of cheap hair spray (Aquanet FTW) on the intercooler couplers to help them stick and not pop off under high boost. Clean off both places for the coupler, spray a little bit of Aquanet on them on replace the clamp. Should hold steady and wont mess up the coupler
06 CGM M6 "This Goat Doesn't Graze" TVS1900! Mav Man Diffuser CCW 19 inch SP20s staggered OEM grey stitching and grey face gauges. 503hp 495ft/lbs of torque @ 8psi
Current Other Cars:
59 VW Bug 1914cc
64 Nova 327 and Muncie, new project.
06 WRX VF43. Mild built motor
06 Dodge Ram 2500 Cummins 4x4
www.facebook.com/Avcarsandcoffee/
AV Cars And Coffee every 3rd Sunday
Old 05-15-2017, 01:04 PM   #9
GTO44
2006GTO M6 dd-drag-roadcourse
GTO44's Avatar
You must have A LOT of movement going on with the motor for that to happen. Has never happened to my vararam. Get a set of hinson motor mounts if yours are that worn out.
Here's my driver side busted factory motor mount at 86K miles. Yours probably looks similar.
Vararam only, stock tune
Monster Level 2, Tick MC, RS T.Mount, Revshit insert, Hinson M.Mounts
Lovell 340/370mm springs, Koni Sports shocks/struts
Lovell Bushings: Strut Mounts & Bearings, ajust. Radius rod, rear subframe, Diff insert, rear endlinks
Hotchkis Adjust. Sways, Nobush Endlinks
DBA T3 Clubspec slotted, hawk HP+, Russle SS, Motul 600
Rebuilt T56, blocker ring kit, Tick billet 3/4 keys & springs
Dragbags, Catchcan, PTI 1-piece Alum. DS
365/368 (std)
12.81@110.6 2.03 60'
Old 05-15-2017, 02:07 PM   #10
Wahoo
of coarse it has clamps....
Old 05-15-2017, 02:09 PM   #11
Wahoo
I reattached it a couple times and every run it popped off again. And right after I reconnected everything I have it a tug and it wouldn't move, it must be the engine mounts.
Old 05-15-2017, 05:57 PM   #12
cookmeup272
I wanna see pics. because I think my engine would have to move 6+ inches for the intake to pop off lol
Old 05-15-2017, 06:00 PM   #13
ಠ_ಠ
Old 05-16-2017, 04:43 AM   #14
Wahoo
I don't know what the stock air intake looks like on these cars, so I'm not sure if that's what's making this hard to believe for people...
My car has the vararam air intake, it has 2 silicon couplers that are pretty rigid.
The MAF is mounted to the air filter box which is mounted in the engine compartment so it's rigid.
Later today I will post a picture .
Old 05-16-2017, 05:53 AM   #15
DangerNoodle
Because our motors don't move around enough to unhook a coupler!
With your hood open (and your engine oil warmed up), have a friend give it a rev with you recording so we can see the amount of movement.
Your motor mounts could be broken. I have also seen the nuts back off the threads that hold the motor mounts in place; Something to consider.
Old 05-16-2017, 06:06 AM   #16
Wahoo
That is a good point I didn't look to see if bolts became loose. But keep in mind revving neutral has no drivetrain load.
Driving normally it doesn't pop off, but racing is gonna torque things around much more, I believe the engine mounts are tired they must be original to the car which has almost 104k miles on it.
Old 05-16-2017, 06:09 AM   #17
cookmeup272
I still want to see how your intake tract is setup. I know the Vararam is different from my Awespeed but, like I said, I literally have to wrestle with the MAF to get it in/out. I don't see how I could ever pop a coupler anywhere.
Old 05-16-2017, 12:53 PM   #18
ಠ_ಠ
well, if the collar, or neck, or whatever you want to call it, on the vararam is collapsing, then i can see how it will slip off.
i had this issue with svede #1 about six years ago (i think it was about that long), and low and behold i was simply over-compressing the neck on the intake and causing it to collapse. oops.
stuck it in the oven for a few minutes, the fiber glass expanded back to its original shape with minimum of effort, and added some epoxy to fill in the damaged area. that fixed it and i went on my merry way.
Old 05-17-2017, 03:55 AM   #19
Wahoo
So I am an idiot it's the violant cold air intake not the vararam, that's what must have been confusing everyone.
It came on the car when I got it, and I just remembered the name started with a V.
I still need to take a picture for everyone.
Old 05-17-2017, 04:46 AM   #20
cookmeup272
That makes much more sense
Old 05-17-2017, 12:19 PM   #21
DangerNoodle
Does it? I still think his engine is moving around too much unless the Volant has a collapsible coupler somewhere. I use to have a Lingenfelter CAI which is similar to the Volant and I never had it disconnect on me.
Old 05-17-2017, 01:37 PM   #22
Wahoo
So it pulled out of the coupler from pipe to MAF.
Old 05-17-2017, 06:28 PM   #23
DangerNoodle
1. Clean your damn car! Make sure to not get water directly on your alternator.
2. Get a larger coupler. I recommend some heavy duty rubber from Lowes or Home Depot in the plumping section.
Old 05-17-2017, 07:30 PM   #24
Wahoo
It does need a good cleaning!
Don't worry I picked up some Hinson drop motor mounts, the car will be ready for track days soon, squealing tires with my piggy.
Old 05-17-2017, 08:06 PM   #25
ಠ_ಠ
http://www.intakehoses.com/mm5/merch...gory_Code=HHS6
might help.
Old 05-18-2017, 05:36 AM   #26
cookmeup272
It makes more sense to me in the fact that I literally feel like I could take all the clamps off my OTRCAI, MAF and TB and everything would stay in place just because how everything is wedged together.
Old 05-18-2017, 10:35 PM   #27
Afroman
06 Cyclone GTO
Afroman's Avatar
That's a pretty nifty idea. I'll have to tell my buddies that one.
2006 CGM A4 Gone but not forgotten.
2006 IBM M6 New GTO!
2014 SS A6
Originally Posted by AlphaEden...View Post
you're quite the manwhore now aren't you
Originally Posted by mike5215@bellsouth.n...View Post
Owing a GTO is like marrying a stripper. You know it's wrong and it's going to end badly, but the sex is so hot you can't help yourself.
Originally Posted by Brians Goat...View Post
No he ain't doing no freaking manwhoring, he has a collar around his neck lately, he rarely shows up anymore on Saturday's and when he does he usually has some HOT babe with him who causes him to constantly drool and walk funny!!!!!!!
Old 05-19-2017, 07:48 AM   #28
Audacious Nick
Send Nudes
Audacious Nick's Avatar
You could also stop doing Auto-X and start doing real track days.
2004 GTO- Gone.
2008 Corvette- Also gone. Stock- 12.5@118
2007 ES350-Racecar. Cabin air filter swap, air filter swap, spark plug swap, Pennzoil Platinum, air in tires, some MLV, premium unleaded, Michelin wipers.
2006 GSXR 1000- "The 250." Akrapovic full exhaust, Rotella, brake lines.
Old Yesterday, 04:58 PM   #29
googleman5
wHaT a LoVeLy DaY!
googleman5's Avatar
Boooo, come track prep my car and buy my admission to HPDE.
Lol I kid I kid
Operation: Black Pursuit Special
|bohnman's MP3 Jack|SAP Repro Grills|Pedders Street 2+|DBA Slotted Rotors|Hawk HP Ceramics|Monaro VX Tails|Kooks 1x3/4" Headers|SVEDE OTR Intake| Magnaflow w/e Catback|Hinson Solid Motor Mounts| Billet Prototypes Oil Catch Can (in red)|
Tuned by Don Kinder of SLOWHAWK PERFORMANCE
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" - Grumpy Jenkins
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
