Tailshaft Removal - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Drivetrain
Old 05-18-2017, 07:12 AM   #1
GTO44
2006GTO M6 dd-drag-roadcourse
GTO44's Avatar
Online
Tailshaft Removal
How hard is it to remove the tailshaft of the t-56 while the trans is still in the car? Any tips?
Vararam only, stock tune
Monster Level 2, Tick MC, RS T.Mount, Revshit insert, Hinson M.Mounts
Lovell 340/370mm springs, Koni Sports shocks/struts
Lovell Bushings: Strut Mounts & Bearings, ajust. Radius rod, rear subframe, Diff insert, rear endlinks
Hotchkis Adjust. Sways, Nobush Endlinks
DBA T3 Clubspec slotted, hawk HP+, Russle SS, Motul 600
Rebuilt T56, blocker ring kit, Tick billet 3/4 keys & springs
Dragbags, Catchcan, PTI 1-piece Alum. DS
365/368 (std)
12.81@110.6 2.03 60'
Old 05-18-2017, 07:25 AM   #2
LFSADRG
Need To Drive More
LFSADRG's Avatar
Never did it while in the car. The tail housing unbolts and slides off, after removing the shifter and driveshaft, of course. May have to drop the trans down some. Use RTV to seal the housing back onto the trans when reinstalling.
05 GTO MBM M6 - FORGED 6.0/FLOWTECH GRIND/MONSTER 3/SW EXHAUST/FAST 92/AFR 230/N.O.PLATE/XAIR/GFORCE 1320/SLP/PEDDERS/BILLET PROTOTYPES/MAVMAN/LOVELLS/VIKING
01 TA WS.6 A4 - STONE STOCKish
72 LEMANS A3 - FORGED 461/SOLID ROLLER/B&M/FLOWMASTER/EDELBROCK/RAIII/NOS CHEATER/MORRISON
Old 05-18-2017, 11:21 AM   #3
GotTogO
WOT's Up Doc?
GotTogO's Avatar
Not hard at all. Support the trans, remove the crossmember, lower the trans a little.
Use a loooong extension to get to the top bolts.
When putting it on don't force it. It should go all the way on (or very close to it) without using the bolts to suck it up.
And you'll have to insert a screwdriver or something to lift one of the shafts into position just before it slips all the way on (lower right, 5th gear I think). The shaft slips right in, there just isn't enough room for your fingers.
That's all I remember at the moment. I'm sure you can Google a write-up.
12.47@113.99
Old 05-19-2017, 08:15 AM   #4
GTO44
GTO44's Avatar
Online
Thanks guys, will be tackling next week.
Old 05-19-2017, 11:55 AM   #5
GTO44
GTO44's Avatar
Online
Oh last thing...
I'm assuming I have to take the end of the shift rod off to slide the tailshaft off. Does this pin just tap out?
Also if I take the tailshaft off with the trans still in the car, I'll be able to get it back in/on correct? I've read a couple things that said it's really hard to get it back on with the trans in the car because of the countershaft extension dropping out.
Goal is to remove the tailshaft and bring it to a trans shop to have a new tailshaft bushing pressed in with a new seal.
Old 05-19-2017, 04:31 PM   #6
joshcarl
Underway
joshcarl's Avatar
yes, you have to use a punch to get that pin out. i like to use a little loctite on it when reinstalling it.
Old 05-19-2017, 06:11 PM   #7
GotTogO
WOT's Up Doc?
GotTogO's Avatar
If you drop the tranny a little bit its not hard. The coutershaft is what I was talking about. You have to lift it back into position before the housing will go all the way on.
Old 05-19-2017, 09:12 PM   #8
HMBLGOAT
Online
Curious what's the noise or issue? How'd ya surmise that particular bushing needs fixin? Mostly because I get a weird noise on the 1st and 2nd gears that sounds like a faint water fall sound, yeah that's actually the best description I have for it at the moment.
Old 05-20-2017, 07:30 AM   #9
GTO44
GTO44's Avatar
Online
perfect
gotcha thank you
My tailshaft seal is leaking and there's an excessive amount of play in the tailshaft when moving the driveshaft around by the yoke. Used to be tight. I'm getting more vibration from the driveshaft now and I don't want to tear anything up. I just took the goat to a drive line / driveshaft shop to measure the pinion angles to get rid of the vibration. They said the angles were good, it was the excessive play in the tailshaft causing the vibration.
Here's a quick clip of the play. You can also see the wetness around seal and back of trans, and where it's been leaking on to the exhaust:
Old 05-21-2017, 05:44 AM   #10
jimmyonirocs
jimmyonirocs's Avatar
Mine is similar, but I only get a little leaking under power, just enough to hit the exhaust and smell.
2005 CGM 6M
BTR Stage 3 with LS3 heads, Xair OTR intake, Pacesetter LT
Full Lovells front end
285/35/18 Nitto NT05 Rear
245/40/18 Nitto NT05 Front
VMR V710 18x8.5/18x9.5
6000k 55w HID's
GMM Ripshifter
MobileAttractions Goldie 2.0
Proxses CTS-V Brembo Front Kit,Brohman CTS-V Brembo Rear Kit
FQuick
Old 05-21-2017, 02:52 PM   #11
HMBLGOAT
Online
O I C
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
