Wilwood BBK question - LS1GTO.com Forums
Old 01-28-2017, 01:33 PM   #1
Terrystasko
Terrystasko's Avatar
Anyone running the new six piston kit on stock 18s? I'm thinking about using them for my aftermarket wheels, and I did the measurements with the diagram that they supply online but I'm still not positive. If someone is running them on stock 18s can you tell me how much clearance you have from the spoke to the caliper? I'm not worried about diameter I'm worried about the caliper being too far outward from the car and hitting the spokes of my wheel. My aftermarket wheels have about a half inch less space from spoke to caliper the the stock 18 inch ones. So if there is more than a half an inch clearance from the Wilwood kit then I'm in business.
Old 02-14-2017, 11:09 AM   #2
AZNGoatDriver2
Track Goat
AZNGoatDriver2's Avatar
I will let you know about mine later tonight. I have the six piston Wilwood BBK with stock 18's on it.
Track Rat
-Thanks Pops-
Old 02-17-2017, 06:25 AM   #3
LongRifles
LongRifles's Avatar
I have a 2004 with Wilwoods on all 4 corners. At the time of the installation the car had factory wheels/tires. 6 piston fronts, 4 piston rears. slotted rotors, but not cross drilled.
No issues.
On that note.
The cross drilled rotors look cool. They look really cool, no doubt. On a street application it was emphasized to me with an exclamation that using them would result in problems, cracked disks...
I've been a machinist for a long time now, I'm no engineer, but I do work with them often. Cross drilled cast iron opens the door for fractures on a disk being subjected to massive amounts of torsional loading. Just something to consider.
Last: The only real issue I had was fitting up the rear calipers. The sheet metal dust shield was in the way and I ended up using a pneumatic nibbler and Roloc disk to remove it. -wasn't my best work, lol.
Good luck.
C.
Shoot it like ya' stole it!
Old 02-17-2017, 06:52 AM   #4
GTO44
2006GTO M6 dd-drag-roadcourse
GTO44's Avatar
Online
Yep. I used a cheaper set of cross-drilled & slotted rotors (PowerStop i believe) on the goat a long time ago. After about 6 months of DD, they were warped and had spider cracks around almost every hole. I'm lucky they didn't just break in half.
On a heavy car like this I agree, stay away from cross drilled for DD. Although, I haven't heard anyone mention this about the higher quality DBA cross drilled rotors...
Sorry OP, i know this has nothing to do with what your asking, just thought I'd add on to what Longrifles said.
Vararam only, stock tune
Monster Level 2, Tick MC, RS T.Mount, Revshit insert, Hinson M.Mounts
Lovell 340/370mm springs, Koni Sports shocks/struts
Lovell Bushings: Strut Mounts & Bearings, ajust. Radius rod, rear subframe, Diff insert, rear endlinks
Hotchkis Adjust. Sways, Nobush Endlinks
DBA T3 Clubspec slotted, hawk HP+, Russle SS, Motul 600
Rebuilt T56, blocker ring kit, Tick billet 3/4 keys & springs
Dragbags, Catchcan, PTI 1-piece Alum. DS
365/368 (std)
12.81@110.6 2.03 60'
Old Today, 09:13 AM   #5
Terrystasko
Thanks buddy!
if you could just measure from the spoke to the caliper.
On another note, how do you like them?
My douchey YouTube channel of me racing and off-roading:
https://www.youtube.com/channel/UCnA..._OUyu9g/videos
2005 GTO M6
BC Coil-overs, Hotchkis sways, DSS 1 piece, DBA 5000 T3 in front, DBA 4000 T3 in rear. Hurst SS, Pace Setter long tube, catless mids with 'H' pipe, JBA cat back. Russel SS brake lines, 3.90's with Truetrac, Svede ORCAI, SCSS gauges, lots of poly.
2000 Jeep Wrangler - Way too much to list
2014 Acura MDX - Wifey's car
2012 Acura TL - Company car/DD
Old Today, 09:15 AM   #6
Terrystasko
No issues.
On that note.
Good luck.
C.
Thanks guys. Yeah, i never intended on the cross-drilled ones. I've had bad experiences also, even with my factory Porsche ones!
I intend on just getting the slotted ones.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
