Looking for assistance - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Tuning/Dyno Results
Old 02-17-2017, 02:20 AM   #1
TprGTO-[Robo Fuzz]
Retired LEO meow
TprGTO-[Robo Fuzz]'s Avatar
GKTJNP
My go setup is basic right now. Pacesetter LT's, custom exhaust with Spintech super pro street mufflers, Svede speed OTRCAI and HP tuners.
Yesterday, I received the estimate for the spring build. MSD Atomic intake manifold, Nick Williams 102mm throttle body, Texas Speed LS series custom (.233/.239/.500) rough idle camshaft and dyno tune.
I asked the rep from the performance shop what about heads as far as performance gains and I was advised they don't give that much and that it is the cam that does.
Is it worth adding a set of aftermarket heads?
Also, without the heads, what hp/tq gains can I expect from the new mods?
Old 02-17-2017, 04:26 AM   #2
JimmyGTO
JimmyGTO's Avatar
Not trying to be short. If I were you I would find another performance shop. A real performance shop could answer all your question. Heads and cam will add plenty horsepower.
Old 02-17-2017, 04:55 AM   #3
ZigZag
Eva, my new love
ZigZag's Avatar
You are not afraid to put money into the car so why not buy a TVS 2300 and gain 150 h.p. ? Just my thoughts on the subject.
2005 Midnight Blue Metallic M6
Magnuson TVS 1900 Kroma Kote 557 rwhp 520 torque 8.6 lbs. boost. Ed Curtis custom cam
JBA Headers and JBA high flow catted mids H pipe Magnaflow Catback GMM Street LPE CAI
TSW Chrome Nogaro Wheels with Michelin Pilot Super Sport Tires
18x8 front / 18x9 rear 245/40 front 275/35 rear
2007 Pontiac G6 GT (winter car)
First car 1968 GTO 4 speed Mayfair Maize 6.5
Old 02-17-2017, 05:20 AM   #4
gto57
Is that FWD?
gto57's Avatar
Interesting question. My GTO is going in on Monday for this setup.
CNC Stage III LS6 heads/cam
Rocker bases/pushrods, etc
Fast 102mm Intake & fuel rails
LPE 100MM MAF
105MM Accufab throttle body.
Hoping to gain about 100rwhp from this setup.
2004 GTO - Quicksilver A4 (437rwhp 371rwtq)
Engine Mods: Livernois Stage III LS6 heads/cam | Cam - Duration 224@.050, Lift .568", LSA 114
Fast LSRX 102mm Intake | Fuel rails | LPE 100MM MAF | 105MM Accufab TB
SvedeSpeed OTRCAI | JBA Shorty Headers | JBA Mids w/Cats | JBA Catback
Appearance: Banshee Hood | Banshee Dual Outlet Exhaust Inserts |DBA Slotted Rotors | Hawk Ceramic Pads
ROH Fury Black Ice 19x8 | Michelin PSS 245/35/19
Drivetrain : Gforce Half Shafts | Inner Axle Stubs
Old 02-17-2017, 05:27 AM   #5
MannyLobo
HGH Optimist
MannyLobo's Avatar
Send a message via AIM to MannyLobo
CNC LS6 heads/cam
LPE 100MM MAF
Did you pay for that LPE, already?
I bought mine, years ago. Should've just went the Spectre route, but I was unaware of it, at the time. Would've saved a bit of coin.
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
Old 02-17-2017, 05:54 AM   #6
gto57
Is that FWD?
gto57's Avatar
Yes, parts are all in, car is going in on Monday for the install.
Old 02-17-2017, 06:31 AM   #7
MannyLobo
HGH Optimist
MannyLobo's Avatar
Cool, then. Hoped to save you a bit. All good, though.
Interested to see your results.
As far as OP... it all depends on what kinda heads you plan on using. I just went with bare 243's, but I had .030 milled off, and got thicker gaskets. Compression went up, just a bit. Nothing too drastic. I actually went a little undersized on my cam, because of it.
Still got 411/422 out of my A4.
My tune is another topic. Make sure THAT is handled be a reputable shop. I went back and forth about going back to my original shop so they can "fix" what they didn't get right. But I figured... why give them another shot? Should've been done right, the first time.
Old 02-17-2017, 07:18 AM   #8
gto57
Is that FWD?
gto57's Avatar
Probably loosing about 25-40 RWHP from not changing the heads, but I am no expert. I would assume you should still gain about 60-75rwhp without the heads.
I would get some aftermarket heads since they are working on the engine anyway. I am getting the CNC Stage III LS6 heads.
Old 02-17-2017, 07:21 AM   #9
TprGTO-[Robo Fuzz]
Retired LEO meow
GKTJNP
Thanks for the feedback. Heads it is.
ZigZag, to answer your question, I like naturally aspirated.
2004 Pontiac GTO/PBM/blue interior conversion
2017 Chevy SS/PBM/6MT
R.I.P. Rick. 07/23/06. I'll miss you brother.
Old 02-17-2017, 11:33 AM   #10
CaliBayGoat06
CaliBayGoat06's Avatar
if you dont want to spend that much you could send your heads in to tsp for a 2.5 prc cnc porting service its about 950 with new ss valves that is the last step to mine before i add nitrous i already have cam package 92mm fast svede tsp longtubes and all the little things to go along with it i like all motor also hoping to get about 60 70 rwhp at least just mentioning the head porting because its not as expesive good luck with your build!
Old 02-17-2017, 06:37 PM   #11
TprGTO-[Robo Fuzz]
Retired LEO meow
GKTJNP
Decided to go with Trick Flow heads.
Old 02-18-2017, 03:44 AM   #12
MannyLobo
HGH Optimist
MannyLobo's Avatar
Good choice, sir.
241's, 243's?
Old 02-18-2017, 03:47 AM   #13
TprGTO-[Robo Fuzz]
Retired LEO meow
GKTJNP
Good choice, sir.
241's, 243's?
Trick Flow Gen X 220.
Old 02-18-2017, 03:53 AM   #14
MannyLobo
HGH Optimist
MannyLobo's Avatar
Niiiice. Gonna have a monster on your hands.
Old 02-18-2017, 05:24 AM   #15
Lakegoat
Lakegoat's Avatar
Get the powdered metal valve guides so you don't have to use roller rockers on the TF's
TVS 2300, 4L80
Old 02-18-2017, 06:52 PM   #16
Steel Chicken
Cthulhu's IT D1r3ktФя
Steel Chicken's Avatar
Hope they do more than dyno tune it. I also hope they know how to dial in that giant TB correctly. Not easy to do on the 04's. You sure you need a TB that big? Who specc'ed out the total package for you? What are your desired goals?
2004 GTO, Stock LS1 internals, EDC custom cam, TVS2300 @ 14PSI, ETP heads and corn juice. 742 RAWRZORS.
Justice is swift and unfair in the eyes of those who don't know shit. - tmiller
Old 02-18-2017, 07:58 PM   #17
TprGTO-[Robo Fuzz]
Retired LEO meow
GKTJNP
*Might be scrapping this build for now*
This afternoon, I received a call from the dealership I have been waiting for. They finally got in a 2017 Chevy SS, Slipstream blue metallic/6MT.
I've been wanting this car.
If I get the deal I am looking for, I will get the SS.
If not, continue with the build.
Old 03-08-2017, 08:15 AM   #18
gto57
Is that FWD?
gto57's Avatar
These are the initial results. They are supposed to email the dyno sheet soon and I pick up the car this Friday.
Livernois CNC Stage III LS6 heads, Stage I Cam
Cam specs, Duration 224@.050, Lift .568", LSA 114
LPE 100MM MAF
Baselined with stock tune. (Car was tuned before)
313whp 327wtq
After mods:
437whp 371wtq
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
