How many guys are in the 10s without a roll bar? - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > Racing > Drag Racing
Old 04-08-2017, 10:41 AM   #1
Iron Indian
How many guys are in the 10s without a roll bar 5-point or 6-point. Just curious
Shawn W. Larsen
2005 Pontiac GTO 6.0 LS2/A4... Stalled/Cammed/Nitrous... 10.74 @ 126 MPH
-2007 Chevy Trailblazer SS 2WD 6.0 LS2 V8: TVS1900 Maggie, LTs, True Dual 3" ext.
-2008 Chevy Express LS 3500 15-Pass Van 6.0 V8/4L80/12-bolt: Stock Work Horse.
-2013 Chevy Silverado 1500 LT Ext Cab, SWB, 6.2 L9H V8 w/ GMPP Upgrades: K&N & MBRP 3.5" Exhaust, My Daily Driver.
-2015 Yukon Denali 6.2 4WD: Stock, Wife's daily.
Old 04-08-2017, 02:21 PM   #2
CLS1GTO
CLS1GTO's Avatar
I guess I'll be the first to raise my hand
Sent from my SPH-L720 using Tapatalk
04 pbm,black,a4.K&N Intake, GT2-3 Cam, Stock 243's, P/P Throttle Body, SLP U/D Pulley, Tuned by GTODoug, Stainless Works Coated L/T, Offroad Midpipes, Magnaflow Catback, 2800 Vig., (M/T DR. & 75 Dry Shot for the track)traded in . 05 pbm,black,a4. K&N Intake, GT2-3 Cam, ported T/B, SLP U/D Pulley S/W Coated L/T, Offroad Midpipes, Magnaflow Catback, 2800Vig., (M/T DR. & skinnies for the track)
Old 04-09-2017, 12:37 PM   #3
GTO1_OHIO
GTO1_OHIO's Avatar
Yes
Old 04-10-2017, 01:55 PM   #4
Drunkin Goat
Maggie who?
Drunkin Goat's Avatar
You don't need a cage to go 10's. You need a roll bar.
416 NOVI 2500
build thread
www.ls1gto.com/forums/showthread.php?t=457175
http://www.youtube.com/watch?v=F-ykr_-nRIs
1000+rwhp
1000+rwtq
OLD NUMBERS
60'-1.477
ET-9.70's
MPH-140.78
ECS, WM Motorworks & Gforce1320 FTW
Old 04-11-2017, 10:17 AM   #5
Iron Indian
Pretty sure you need a 5 or 6 point for 10.00 - 11.49
Sent from my iPhone using Tapatalk
Old 04-11-2017, 01:08 PM   #6
Drunkin Goat
Maggie who?
A 6 point is a roll bar not a roll cage. You need a roll bar at 11.49 and a cage at 9.99.
Old 04-11-2017, 01:27 PM   #7
Iron Indian
I changed the title just for you.
When I think of a roll bar I think of a roll bar with 2 point that's worthless. If I asked for an 8.50 cert cage I'd be wanting to go faster than 9.99.
Old 04-14-2017, 11:01 PM   #8
NorCal06Goat
NorCal06Goat's Avatar
Dang, I'm jealous...HA! I wish I was in the 10s, curious if these cars are Streetable or drag only? All Auto Trans too?
*Best 1\4" mile 11.72 @ 118 MPH 60 ft = 1.859 ALL MOTOR
Corrected for DA
*Mods: Cam, Heads, SLP Double Roller Chain, HV Oil Pump, Comp Trunnion upgrade, Hardened PRs, CNC/Ported TB, Monster Level III, Steel Flywheel, Drag bags, 1-piece 1000HP aluminum DS, SLP160 Thermo, B&M shifter, LT's, catless, S10 muffs, Vararam CAI, Lingenfelter Launch, SLP Brake Lock, removed about 250+ lbs of weight, lost another 35 lbs on my belly!
*Tuned by me and ERM Performance Tuning!
Old 04-15-2017, 10:28 AM   #9
Iron Indian
My wife drives mine and it has AC and all. It doesn't feel any different from running 12s to 10s.
Mine has an RPM Level 7 4L65
Old 04-15-2017, 04:57 PM   #10
Nogomofo
Hot Rod A.D.D!
Nogomofo's Avatar
I just got busted and I only went 11.46!
1970 Nova 468ci Th400
1970 Camaro Twin turbo lq4
1971K20longbox350ciTH350
1972 Scout II 345ci727
[COLOR="DarkGreen"]1966MGBRoadster1.8L4spd[/COL]
2005 GTO 6.0L M6 11.39@122 N/A 364ci ls2
Old 04-16-2017, 05:55 AM   #11
CLS1GTO
CLS1GTO's Avatar
Mine is automatic also, and is my DD. 3900 with driver,
Old 04-17-2017, 01:02 AM   #12
hadagto
In my experience from 3 different tracks a lot depends on if there are complaints from other drivers and what the event is...
On one of the tracks I ran at you get one warning to slow it down or you are out.
On the other 2 tracks it would depend on the event you are running. If it was one of the late night "street drag" events then everything was way more laid back as far as tech. Basically if you didn't do anything stupid you were good to go. On other events like a regular test and tune or other organized events if there was one complaint from another competitor you are done.
One time at a "street drag" event I ran a NA pass and ran a 7.1x 1/8th mile. The next time around waiting in the staging lanes a track official came and talked to me. He said you don't have a roll bar or anything and explained the rule to me about roll bars. He said I could go ahead and run, but be careful because those rules are there for a reason. That next run I sprayed it and ran a 6.5x 1/8th mile. The next time around in the staging lanes he looked at me and just smiled and shook his head, but let me run.
Different day at the same track during a test and tune...one pass on motor and the competitor I ran against on that pass came over with a track official and I was asked to leave.
1980 Buick Regal turbo...no track times only street raced (wrecked...hit a deer)
2004 PBM...408 w/150 shot 10.286 ET (SOLD)
2004 IBM...1 of 369...228R cam/long tubes/magnaflow/yank 3200ss
Old 04-17-2017, 07:11 PM   #13
AdmireGTO
AdmireGTO's Avatar
I did it for a very short time before I installed a bar. I have tracks around me I could get away with it but I couldn't get away with it on Drag week. So I put one in. Now to the point I need to upgrade to a cage.
2005 Cyclone Gray GTO
10.97@123 Cam only recordNew time 10.82@127(now old setup)
11.31@119 Bolt on recordold setup
Tick SNS stage 3
BTR Double VS/Ti retainers
Kooks 1 7/8
Bassani exhaust
Fast 102/NW 102 TB
ASP underdrive
DSS driveshaft
BC racing coil overs
FTI 3800
P3 battery
Meziere WP
Old 04-20-2017, 08:58 PM   #14
Mike05TurboGto
Mike05TurboGto's Avatar
No rollbar for me. I can usually make 3 passes before I get told to load it up. I feel they don't mind the time as much as they do the mph. 139mph really set them off.
Old 04-21-2017, 04:54 PM   #15
BT802
10 Sec Daily Driver
BT802's Avatar
Send a message via ICQ to BT802 Send a message via AIM to BT802 Send a message via Yahoo to BT802
None here, just depends on the track or the event. New setup should go 9s.. still not going to mess with a bar. Maybe down the road something with swing outs, no time soon though.
05 QSM A4 - H/C/I 402 - 11.27 @ 121
SOLD back in 2010: 05 MBM A4 - 10.88 @ 127.9 Cam/150 Shot
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
