Mp 112 catch can - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Forced Induction
Old 04-19-2017, 01:18 PM   #1
Jailor
Mp 112 catch can
Got an 04 with a 112. What catch can are you using and where do you mount it?
The traditional mounting spot is a bit crowded with the intercooler lines.
04 yj m6 mp 112, 2.7 pulley, meth, vhp boss cam 216-222 583-583 115lsa,1.8 yella terras, 473/465 dyno jet through stock manifolds
Old 04-19-2017, 03:40 PM   #2
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
get a vacuum pump.
( 'o')b
( '_')o
(._. )
Old 04-19-2017, 03:47 PM   #3
Jailor
Originally Posted by Nothubertjfarnsworth...View Post
get a vacuum pump.
Could you point me in the right direction as a vendor or such.
And your opinion on this being the source of my oil smoke at cold start?
Old 04-19-2017, 03:57 PM   #4
joshcarl
Underway
joshcarl's Avatar
Elite Engineering
Old 04-19-2017, 05:08 PM   #5
Jailor
Originally Posted by joshcarl...View Post
Elite Engineering
Is that the "standard" model you have their?
Old 04-19-2017, 06:30 PM   #6
ಠ_ಠ
gz motorsports or moroso.
nope. i don't have an opinion because i'm not sitting in front of your car to diagnose it. you were given a few options to look at in the other thread you created.
Old 04-20-2017, 06:25 AM   #7
Lakegoat
Lakegoat's Avatar
I am using a Rev Extreme can for blower motors--has two check valves. I mounted it to the drivers side inner fender with a bolt up thru the fender and bent the supplied bracket. The 04 may have something in the way---I don't know. I also use the GM Performance PCV that they use on the new LSA motors. It plugs into the oil fill and drains it back to the motor. I went so far as buying two passenger side valve covers from a 2000 truck motor as they have baffles built in to the valve covers to make up for no PCV.
ID:	455897   Click image for larger version
TVS 2300, 4L80
Old 04-20-2017, 09:29 PM   #8
Mike05TurboGto
Mike05TurboGto's Avatar
MMS ftw
Current Setup:
Sbe LS2, 317s, LJMS Turbo cam, meth, s480 96/1.25
17psi: 856HP/876TQ
Best 1/4 Mile time:
10.59@139
That was on 735/739 from last turbo
Old 04-22-2017, 05:14 AM   #9
joshcarl
Underway
joshcarl's Avatar
yes
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
