Momentary stumble after prolonged slow/stop/go - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > LS1/LS2 Engine Tech
Old 04-19-2017, 07:00 PM   #1
MorrisBetter
Too much is just enough
MorrisBetter's Avatar
OK, I have an intermittent problem that occurs after driving in stop-n-go traffic.
After 10 minutes or more of stop and go, moderate throttle will cause a serious stumble. Feels like a lean misfire on several cylinders. It clears itself after a few (10-15) seconds, and the car returns to normal.
During the stop-n-go, everything seems normal. Smooth idle, no off-idle issues. No codes are saved, and after the event, there is no other signs of trouble.
Any ideas?
2006 CGM/M6
Widened stock 18s
King springs
Hotchkis Bars
JBA Shorties
Magnaflow Catback
CIA
GMM Ripshifter
RR Bushings
Old 04-19-2017, 07:06 PM   #2
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
Did this happen after a tune?
( 'o')b
( '_')o
(._. )
Old 04-19-2017, 07:09 PM   #3
ಠ_ಠ
Does it happen at a particular rpm, throttle position, or manifold vacuum...
Also, sometimes a bad MAF can make you feel like you hit a rev limiter.
Old 04-20-2017, 03:35 AM   #4
MuhThugga
The Entenmann's Shim-Sham
MuhThugga's Avatar
Online
You are going to need to get a datalogger to try and see what is acting up in that particular scenario.
PROJECT SILVERBACK IS COMPLETE!!!
Originally Posted by MVDCGTO...View Post
Squeezing another 50 rwhp out of one of those setups would be like trying to squeeze the sarcasm out of MuhThugga. . . . . . . . not gonna happen
Originally Posted by 87LC2...View Post
A Prius is a vehicular dunce cap.
Drag racing is for people who love hard work and hate money.
Old 04-20-2017, 03:12 PM   #5
ಠ_ಠ
Old 04-22-2017, 01:02 PM   #6
MorrisBetter
No recent tune or any other changes. It does feel like the rev-limiter, but is throttle pos related. Any attempt at moderate to hard acceleration after prolonged idle/slow driving will cause the problem.
I'm guessing that it might be a O2 sensor, but I'd rather not start throwing parts at the problem. I will if necessary.
Old 04-22-2017, 01:16 PM   #7
ಠ_ಠ
I doubt it's an o2 sensor. There are procedures to check your o2 anyhow...
Are you getting any kind of "safety mode performance reduced" warning?
Do you have any data logging device? I would look into muhthugga's advice and log it, with as many relavent PID's as you can...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
