Dyno newbie with a question - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Tuning/Dyno Results
Old 04-20-2017, 06:33 PM   #1
xBearxNekkidx
The Sexiest Chalupa
xBearxNekkidx's Avatar
I went to a local shop and ran my 06 with 69XXX miles on the economy three pulls for $40, and it doesn't look like my car makes very "smooth" power, if that makes any sense. Mods are a mild cam from Texas speed, vararam, kooks 1 3/4" headers into a 2.5" maganaflow setup with x-pipe, and that's about it engine-wise. I bought the car a few years and more than a few thousand miles ago and I had a graph in the glove box showing 436 "smooth" horsepower, and the only difference was a k&n in the factory location since then. Anyone care to take a stab as to why the graph looks like this? All help is appreciated!
06 IBM M6 436hp
Old 04-20-2017, 07:42 PM   #2
A TrainsGTO
A TrainsGTO's Avatar
Online
Did you put a full K&N system in or did you just put a K&N filter in the stock air box?
The full system sucks in hot air from the engine so the graph could be the engine pulling timing because of heat soak. Just spit balling.
Old 04-20-2017, 09:28 PM   #3
Mike05TurboGto
Mike05TurboGto's Avatar
How is the car running
Current Setup:
Sbe LS2, 317s, LJMS Turbo cam, meth, s480 96/1.25
17psi: 856HP/876TQ
Best 1/4 Mile time:
10.59@139
That was on 735/739 from last turbo
Old 04-20-2017, 10:23 PM   #4
xBearxNekkidx
The Sexiest Chalupa
I bought the car with a full KN intake kit, and it would heat soak bad around town, swapped to the vararam and insulated it well and have had zero issues. The graph above was with the vararam.
Car runs well, doesn't hesitate and feels strong. Can still walk around my friend's scat pack challenger. Just really thrown for a loop on what the graph is telling me.
Old 04-21-2017, 02:47 AM   #5
Steel Chicken
Cthulhu's IT D1r3ktФя
Steel Chicken's Avatar
It could be a lot of things like belt slip or knock/ignition retard. No way to know without logging the car at the same time.
2004 GTO, Stock LS1 internals, EDC custom cam, TVS2300 @ 14PSI, ETP heads and corn juice. 742 RAWRZORS.
Justice is swift and unfair in the eyes of those who don't know shit. - tmiller
Old 04-21-2017, 04:28 AM   #6
JimmyGTO
JimmyGTO's Avatar
The graph has no smoothing. All dynos that I've been on (4) has a smoothing of 5.
Old 04-21-2017, 05:14 AM   #7
Westphal
This!
Old 04-21-2017, 07:32 AM   #8
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
It's to get that outying peak tq/hp, isn't it?
( 'o')b
( '_')o
(._. )
Old 04-21-2017, 08:45 AM   #9
Steel Chicken
Smoothing doesnt explain the vast difference in spikes in different RPM ranges.
Old 04-23-2017, 05:40 AM   #10
JimmyGTO
JimmyGTO's Avatar
I was just answering his question why the graph looked a certain way. I never seen one looked that way. I'm not a tuner. I'll let the experts explain that part.
Old 04-23-2017, 12:21 PM   #11
Magnified
It's simple physics
Magnified's Avatar
So many variables. Environment (temp, DA, humidity, etc...), who was running the car, what kind of dynos, etc... What did the operator say?
Here's some good stuff on dynos from the oracle:
http://www.hotrod.com/articles/hrdp-...is-dyno-guide/
LR
2006 PBM (now dirt brown) A4, Magnacharger, Kooks LT, high flow cats, Magnaflow x-pipe, stock pipes into race glass packs, drag bags, subframe connectors/jacking rails, 18x8.5/40 offset Bayern Mesh chrome up front, 18X9.5/45 in the rear, Michelin Pilot Sport PSII, fender roll, DIY catch can, DIY factory amp mod, tuned by Chuck, black badges.
Street configuration consistent #s ONCE UPON A TIME - 12.13 / 117.5 / 1.90 60 foot. 3.75 second 0-60. Lots of wheel spin.
Old 04-24-2017, 02:20 PM   #12
xBearxNekkidx
The Sexiest Chalupa
I'm reading up what I can to understand what happened, but after a plug and wire change the car feels "smoother" to ramp up, and after looking at what I pulled out the plugs were between .015-.065", with most of them around .045", except for three outliers.
I had the foot to the floor in the car, and the button operator said one thing: "Oops I forgot to log that second run".
Thanks for the link!
Old 04-24-2017, 02:30 PM   #13
ಠ_ಠ
dug up some stuff on "smoothing" myself, since i found this thread interesting.
https://www.corvetteforum.com/forums...hing-mean.html
using 0 smoothing and having a variance of up to 8 hp is significant.
Old 04-24-2017, 02:33 PM   #14
ಠ_ಠ
https://www.corvetteforum.com/forums...ged-graph.html
more stuff on the smoothing.
Old 04-24-2017, 02:35 PM   #15
ಠ_ಠ
https://forums.nasioc.com/forums/sho...d.php?t=774781
more
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
