Loud single lifter tap, only after it's warmed up - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > LS1/LS2 Engine Tech
Old 06-04-2016, 11:29 AM   #1
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Loud single lifter tap, only after it's warmed up (solved)
UPDATE:
A wiped rod bearing was the root cause of the top end noise and probably the reason the cam lobes were a little ate up. The bearing was wiped, but did not spin. It wasn't making any noise either....at least not enough to hear over the engine and the lifter noise. The only way I was able to get the bad cylinder to make noise was to unplug either the injector or the coil. When the cyl wasn't firing, I could hear a dull knock. It was definitely detonated as the bearing was deformed, no crush. There wasn't any fine metal flake in the oil. But once I drained it, large chunks of bearing material came out.
The lifter noise had to have been from low oil pressure. I thought this engine had always been on the low side from also feeding two turbos, not this low though. Also a lot of denial. :/
Since the bearing didn't spin, the crank was still in decent shape. All the rods are good as are all the pistons. I'm having the crank cut .010 under. New main, rod and cam bearings. Should be good as new.
Guess I should've waited to see what the actual carnage was before impulse buying an SDPC 416ci forged short block.
-------------------- ORIGINAL THREAD --------------------
Looking for an explanation of why a lifter would make a lot of noise, but only after the engine has warmed up. I understand that thinner oil could be the reason it starts ticking, but the oil pressure is the same now as it's always been. I use Rotella 15W-40, pretty thick. I check the level and change it regularly, and replace the filter each time. (K&N brand oil filter)
When it's making noise it's quite loud. I'm 100% certain it's internal to the engine as the noise is loudest when placing one end of a rubber hose over the open end of the oil dipstick tube and the other to my ear. So it's not the flexplate, TC bolt or anything like that, like I was hoping. When it's cold, it's dead silent though. Zero tick, even using the hose on the dipstick tube. Idling or revving.
Once it's warmed up, it's embarrassingly loud. Very similar to rod knock. But I've had rod knock before and this is different. The rod knock happened cold or warm, and was louder when the engine decelerated. This noise is constant. Unplugging each coil pack one-by-one makes no difference. Oil has no metal flake in it and the operating oil pressure has not changed since the engine was fresh (~30,000 miles ago). This is the same time the new LS9 cam, LS9 springs and LS7 lifters were installed.
I'm going to check the push rods for straightness. But could a slightly bent pushrod be whisper quiet when the engine is cold? I hammer on it every time I drive it, but not over revved, the rev limit in the tune is still the stock setting.
How much oil should flow through the pushrods out of the top of the rockers? I took a rocker arm cover off, left the coil packs attached but moved out of the way, and started it to see if I could isolate the noise that way. It took what seemed like a long time (maybe 30 seconds or so) before *any* oil came out of the rockers. And when it did, it was barely a dribble. I was expecting a mess, but it wasn't even enough to spill onto the exhaust manifold. Is that normal? Again, the oil pressure is good, between 40-50PSI at the time I was checking.
I suppose I'm just looking for someone who's had the same experience and what they found.
I can fix whatever it turns out to be myself. But I'd like to avoid doing unnecessary work by determining the actual cause before tearing into it, if possible. Using a stethoscope near each exhaust port didn't help isolate which cylinder. They all sounded the same.
Maybe I should pull both rocker arm covers and use the stethoscope on each rocker arm's bolt?
2006 APS TT, 416ci forged LS3, 4L80e, LSA heads, LS9 cam, 8PSI
Old 06-04-2016, 02:01 PM   #2
rollingGTO
rollingGTO's Avatar
I had a similar issue which turned out to be the lifters scoring the cam and creating flat spots on the lifters which then started making a tick sound that turned into a chirping sound. To diagnose, I unplugged one side of the coil packs(It will run on the 4 cylinders and started loosing the rockers til the sound stopped or reduced( I had 2 cylinders with bad lifters). It was a little messy but not a ton of oil came out while doing this. Its a good way to work cylinder by cylinder. Hope this helps. I have been through 2 tear downs to replace lifters/cam over the past 3 years.
Vararam intake- SLP LT Headers,SLP high flow cats-Dynomax ultra flow mufflers-LS7 Clutch-lowered w/ Full Pedders Street Suspension- '06 tails
Old 06-04-2016, 02:08 PM   #3
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Thanks for the tip! Was it completely quiet when cold?
Old 06-08-2016, 05:06 PM   #4
Phoenix
It will rise again
LS1GTO.com Sponsor
Phoenix's Avatar
My engine with less than 3k miles is doing the same thing. Don't know what it is.
Old 06-08-2016, 05:47 PM   #5
elephantrider
pea on mea
elephantrider's Avatar
i had the same type of noise, and it ended up being this...
trico wiper blades
Old 06-10-2016, 04:11 AM   #6
Phoenix
It will rise again
LS1GTO.com Sponsor
Phoenix's Avatar
How many miles did you have on that cam? Did Comp Cams do anything to help you out?
Old 06-10-2016, 04:59 AM   #7
elephantrider
pea on mea
eh, around 35k - 40k miles. did a valve spring change, always kept the
oil changed with jg ls30.. and no..
Old 06-10-2016, 11:31 AM   #8
rollingGTO
rollingGTO's Avatar
My comp cam and lifters looked really similar to yours and I also had 40,000 on mine and took great care as well. Comp didn't help me out either.
Old 06-10-2016, 11:41 AM   #9
LS2-GTO
1 of 40,757
LS2-GTO's Avatar
Online
What did your oil look like?
Old 06-13-2016, 04:54 AM   #10
elephantrider
pea on mea
eh, the magnetic drain plug started to get a very small beard on
it after, say, 25k miles or so.
Old 06-26-2016, 02:16 PM   #11
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Videos
Rattle
Knock
The knock is exactly 5 per second at 600 RPM, half the engine revolutions, which points to valve train. Good oil pressure and no metal in the oil which also makes a spun rod bearing less likely. But it sure is loud like a spun bearing.
It's extremely difficult to locate the source, left or right, front or back. But it seems like it's loudest near #6 and #8 cyls.
Absolutely coming from inside the block. Verified with a rubber hose from the open dipstick tube to my ear, loudest this way. So it's not the flexplate, not a torque conv bolt, not an exhaust leak.
My hopes of being able to fix it without pulling the heads is dwindling fast.
Soooo, how hard is it to swap a cam with the engine in the car? I own a hoist and I'm on fence about whether to try fixing it in the car, or just pulling it and fixing it on a stand. Would give me a chance to re-stall my TC while it's apart too.
Old 06-26-2016, 02:23 PM   #12
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Was it quiet when the engine was still cold? Seems like damage that bad would always make noise.
Old 06-26-2016, 02:56 PM   #13
svede1212
Growing up is an option
svede1212's Avatar
GVHJ4N
You can do a cam swap in the car by removing the radiator and lifting the AC condenser up and out of the way a little. I've done it a couple of times in my car.
2004 Blk/Rd M6
6.3 litre LS1
Built and tuned by svede
"It's a well know fact that after you hit 400 HP you have to go with split dual exhaust like the LS2 GTOs. The '04s could get away
with single side because they were only 350 HP. With 400 HP and beyond the car wants to turn right at WOT from the thrust."
Old 06-26-2016, 02:56 PM   #14
elephantrider
pea on mea
yup. engine sounded fine when it was cold. once the oil got to full
op temp, it would start making the noise intermittently, then gradually
got worse.
Old 06-27-2016, 06:07 PM   #15
Rob
Been here for a long time...
Rob's Avatar
I, too, have done this a few times. Easier with two people but not bad by yourself.
Rob
04 GTO
75 Cosworth Vega
Old 06-28-2016, 03:25 PM   #16
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Thanks guys. Looks like I need to pull the heads and lifters and see where it leads from there.
Old 08-13-2016, 05:42 AM   #17
Phoenix
It will rise again
LS1GTO.com Sponsor
Phoenix's Avatar
Have you found anything?
Old 08-20-2016, 02:39 PM   #18
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Thanks for asking! Your post gave me the motivation to finally tear it apart.
Yes, I found the culprit.
I think this is my fault. When I was re-assembling the engine after replacing the crankshaft and a rod, I forgot to put the alignment bar under the rockers and I started torquing down the #1 intake. I could tell something wasn't right when it was getting *really* tight but wasn't seated yet. I figured it out, installed the bar and continued. Several weeks later, the #1 intake pushrod broke and I had to limp it home. I put a used pushrod in and rode-out.
Fast forward a few years and over 25,000 miles. Now this, on the same #1 intake.
My guess is that I compromised the lifter when I overtightened it. The lifter had some slack. Then the constant, fast, hot metal to metal slamming millions of times took it's toll.
So, the engine's going to come out. I'll install a new cam and lifters.
Very seriously considering selling it once it's all back together. That might change as soon as I hit 12PSI though. ;-)
Old 08-20-2016, 06:11 PM   #19
Magnified
It's simple physics
Magnified's Avatar
At least you found out what the problem was.
Rider - wow, that's some intense grooving.
OP - how did you get that camera shot?
LR
EDIT - and on Comp Cams - two folks have the same problem at the same mileage, and no help from the company, is suspicious to me. Wonder how many others have had a similar experience. And I thought Comp was one of the more reputable manufacturers. What did they tell you when you called them?
2006 PBM (now dirt brown) A4, Magnacharger, Kooks LT, high flow cats, Magnaflow x-pipe, stock pipes into race glass packs, drag bags, subframe connectors/jacking rails, 18x8.5/40 offset Bayern Mesh chrome up front, 18X9.5/45 in the rear, Michelin Pilot Sport PSII, fender roll, DIY catch can, DIY factory amp mod, tuned by Chuck, black badges.
Street configuration consistent #s ONCE UPON A TIME - 12.13 / 117.5 / 1.90 60 foot. 3.75 second 0-60. Lots of wheel spin.
Old 08-20-2016, 06:55 PM   #20
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
Iirc someone on facet00bs said something about comp having a run of bad cores.
don't know if this is BS or what, but just introducing it to the discussion.
( 'o')b
( '_')o
(._. )
Old 08-21-2016, 04:59 AM   #21
Phoenix
It will rise again
LS1GTO.com Sponsor
Phoenix's Avatar
I've had two cams from Comp do that to me, but thought it was because some other engine damage cause that. I'm going to tear down my engine and see what is going on. I barely have 3000 miles on this one.
Old 08-21-2016, 02:41 PM   #22
gesto
Torrid 06 M6
gesto's Avatar
There is a lot of discussion on ls1tech about Comp Cam failures
06 GTO - TR/red, stock power, Upgraded T-56, Monster 2, Tick MC, SJM line lock, Gforce axle, drag bags, M/T 255 bias ply on fbody rims & gto spares. 12.925 @ 107.07, 1.832 60'
98 Z28, 222K miles, original stock engine, lid, catback,75 shot, 2800 convertor, 2.73's. 12.01 @ 112
Old 08-21-2016, 05:44 PM   #23
11chuck
Funny this pops up. I just replaced the stock cam in my 126k mile 06 that's been ticking for a while. Had a pitted lifter and a worn down cam lobe. It was on the #7 cylinder, forgot exactly which one.
Old 08-21-2016, 06:23 PM   #24
elephantrider
pea on mea
i didn't even try to call comp. that whole bad cam blank thing is why
tx speed is now grinding their own cams.
Old 08-21-2016, 09:18 PM   #25
ಠ_ಠ
i hear cam motion is the bomb.
i wonder who ed c has grind his cams?
Old 08-27-2016, 01:23 PM   #26
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Mine was a GM LS9 cam and GM LS7 lifters. Both were new when installed. I did run it for a while with whatever springs come stock on LSA heads. Later switched to LS3 springs. And this was not due to over torquing the rocker like I thought. Turns out I was off by one and this is the #2 exhaust lobe.
A mechanic friend of mine told me GM is notorious for having lifters go bad. I do still think the lifter started bleeding down and the slack allowed it to beat the piss out of the lobe.
From the top of the engine looking down into the valley. Through the front oil drain back.
Old 01-05-2017, 11:43 AM   #27
GNXClone
2006 Twin Turbo GTO
GNXClone's Avatar
Finally put the GTO back together. New cam, new lifters. Makes the same damn noise!!!
Same circumstances. Sounds perfect when it's first started cold. Once it warms up a bit, clack clack clack. Frack!
I guess it must be rod, crank or cam bearing related? SMDH
Old 01-05-2017, 02:41 PM   #28
Lakegoat
Lakegoat's Avatar
Did you check all of the rocker trunnions?
TVS 2300, 4L80
Old 01-05-2017, 03:31 PM   #29
ಠ_ಠ
What preload?
And, yeah, how many miles on your rocker trunnions?
When you got a chance to swap anything out, did you peak at your cam bearings?
Old 01-05-2017, 04:17 PM   #30
Nogomofo
Hot Rod A.D.D!
Nogomofo's Avatar
My ed cam is a lunati .
1970 Nova 468ci Th400
1970 Camaro Twin turbo lq4
1971K20longbox350ciTH350
1972 Scout II 345ci727
[COLOR="DarkGreen"]1966MGBRoadster1.8L4spd[/COL]
2005 GTO 6.0L M6 11.39@122 N/A 364ci ls2
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
