e-brake light on when seatbelt fastened - LS1GTO.com Forums
Old 01-10-2017, 10:28 AM   #1
jade
Hi, first time posting on this forum. Have an unusual issue cropped up yesterday on my 2005 GTO (30k mi.) E-brake warning light comes on and stays on as soon as drivers seatbelt is fastened. Light goes off as soon as seatbelt in unfastened. Brake fluid level looks normal, jiggling e brake handle doesn't turn it off. Should there be a link between the seatbelt sensor and the ebrake switch? Any ideas appreciated. Thanks!
Old 01-11-2017, 06:41 AM   #2
mlformula95
mlformula95's Avatar
Does the ebrake light work when the handle goes up?
The black blue wire from the seat belt buckle runs to a ground above the transmission according to the 05 wiring diagram. The black white wire changes to orange and runs to the cluster.
I would start with taking the center console out and trace the orange and brown wire from the ebrake handle. Inspect that area and all the wires for damage/corrosion.
Old 01-11-2017, 08:56 AM   #3
jade
Thanks for the reply. I may have solved the problem. The day before the problem started, the battery had gone dead when I accidentally left the lights on for several hours, and I had to jump start it. It was dead enough that some of the preferences on the dash readouts reset. I unhooked the battery last night for 20 minutes and then hooked it back up and drove home and had no more issue with ebrake light coming on. I've got my fingers crossed that the computer hopefully just needed a reset. If the light comes back on, I'll check the wiring.
Old 01-11-2017, 11:40 AM   #4
Jontall
1 of 262
Jontall's Avatar
These cars go crazy when the battery is low or dead... Buy a new battery when you can afford to.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
