H11: MORIMOTO 2STROKE? - LED headlight bulbs - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Electronics
Old 01-11-2017, 12:15 PM   #1
eHUNTERg
Anybody using H11: MORIMOTO 2STROKE LED headlight bulbs?
Can you post output pictures? Pretty please...
Are you running any harnesses? Anti-flicker or otherwise.
Thanks.
Old 01-11-2017, 12:51 PM   #2
greenmtn
greenmtn's Avatar
Old 01-11-2017, 01:10 PM   #3
eHUNTERg
Is that you?
In a GTO?
Any additional Harnesses installed?
Old 01-11-2017, 02:11 PM   #4
greenmtn
greenmtn's Avatar
no not me, google search turned it up
Old 01-11-2017, 02:27 PM   #5
eHUNTERg
I actually had seen that video.
I was told that the placement of the LEDs in relation to the projector matters and that they may be great in one car and not in another.
Also curious about any additional hardware needed to run them.
Old 01-11-2017, 02:41 PM   #6
MannyLobo
HGH Optimist
MannyLobo's Avatar
Send a message via AIM to MannyLobo
That's true with any bulb, right?
I used spacers in my headlight to get my HIDs to sit further back, and the light output increased significantly. Makes sense if you're using an LED bulb (or anything different than stock halogens).
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
Old 01-11-2017, 04:39 PM   #7
marovetsm
marovetsm's Avatar
I have run so many sets of LED headlights and fogs. I run HID's for my high beams (which I rarely use, I drive in the metro 100% of the time practically never use my highs. That being said Ive had good luck with amazon LEDs in both my GTO and my SRT8 fog lights.
Currently running these-
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
And they extremely bright and especially in my Monaro fogs they are very noticeable. I did have one burn out after about a year but at that price its cheaper than halogen bulbs.
2006 SRM M6 - MP112, E85, 563hp/570tq.
Dyno video http://www.youtube.com/watch?v=0Ha5A7vuolk
2004 Joe Gibbs Silverado RCSB - MP112, E85, T56, 470hp/465tq - Sold
Bezel pod How To
http://www.ls1gto.com/forums/showthr...690&highlight=
Old 01-12-2017, 03:48 PM   #8
23MTR
23MTR's Avatar
I also run the same led's in my monaro fogs... there 95% as bright as my low beams
Old 01-14-2017, 09:49 PM   #9
socal gto
Do those ebay bulbs fit under the caps without modification like i had to with my hid kit?
http://i647.photobucket.com/albums/u...IMG_0296-4.jpg
A few bolt ons
-----60'---mph---time
1/8: 1.594 94.16 7.254
1/4: 1.656 116.68 11.622
totalled 12/6/2010
Old 01-15-2017, 05:58 AM   #10
eHUNTERg
Morimoto includes a new larger cap.
Old 02-28-2017, 07:51 AM   #11
eHUNTERg
I've had them in for two nights. I do not recommend them.
They are not plug and play. Dremel was required to open up the caps and holes have to be punched in the included dust boot.
Light output in my headlights is not as good as in the video above.
I would not buy again.
Old 02-28-2017, 09:17 AM   #12
ViperT4
ViperT4's Avatar
I always wondered if something like this was possible but never put much energy into it. Have pics or can you describe what you used?
2004 GTO M6 Torrid Red
Ai ported 243s-ported Fast 90-FTI Tigershark cam-Kooks headers & cats 455hp/413tq
Old 02-28-2017, 10:20 AM   #13
MannyLobo
HGH Optimist
MannyLobo's Avatar
http://www.ls1gto.com/forums/showthr...ght=hid+cutoff
IBM05GTO (or whatever his name is) kinda describes what you need to do. It's basically just removing the mounting point inside the headlight. Where those 3 screws are, you add a couple of small lock washers. This moves the HID light back, which projects more light... since it's not sticking too far forward in the projector.
I used to have a picture of the improved light output, but I have no idea where it is. I think I only put 2 washers. Kind of a pain since you have to remove the headlights. Or at least I did... since I believe I resealed the outside of them anyway.
Old 02-28-2017, 11:32 AM   #14
ViperT4
ViperT4's Avatar
Interesting, thanks!
Old 03-01-2017, 09:55 AM   #15
Stoopalini
Stoopalini's Avatar
Do these Amazon bulbs fit under the dust cap, and plug right in to the factory harness? For $30, seems worth a shot.
2005 - M6 - QSM / Black
100% Poly / Lou's SS / SLP Rear Sway
DuSpeed CAI / JBA Catted mids / Stolen Fox H Pipe
Cluster Programming Sheet
Old 03-07-2017, 04:29 AM   #16
Stoopalini
Stoopalini's Avatar
So I gave these a shot, and they're getting returned today. They did fit under the dust cap, but it was scary driving the car at night with these Amazon bulbs (not) lighting up the road.
https://www.amazon.com/gp/product/B01N3QABXM
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
