2017 BASIC SUSPENSION PACKAGES - LS1GTO.com Forums
Old 03-06-2017, 05:54 AM   #1
Duckman
Kollar Racing Products
Duckman's Avatar
See Attachments...packages can be tailored to meet your needs...You also get 10% off any additional Whiteline products you add to the order. If You have ANY questions ASK!!
THE NORTH AMERICAN DISTRIBUTOR FOR LOVELLS & ROADSAFE PRODUCTS
NEED TECHNICAL SUPPORT? SUPPORT IS AVAILABLE EVERYDAY 8AM-8PM EST
631-902-2276
http://kollarracingproducts.com/
sales@kollarracingproducts.com
GREAT PARTS, GREAT PRICES, FAST SHIPPING.....
Old 03-12-2017, 04:41 AM   #2
Duckman
Duckman's Avatar
Questions?
Old 03-17-2017, 05:35 AM   #3
Duckman
Duckman's Avatar
What do you want to see in a package?
Old 03-24-2017, 11:26 AM   #4
b727pic
Old Guys Rule
b727pic's Avatar
Reinstallation Hardware options??
2004 GTO Barbados Blue M6
LME Iron 403 shortblock: Callies Crank, Compstar Rods, Wiseco coated pistons, EDC custom cam, Rhoads lifters, QTP 2 piece timing chain cover, QTP hi vol oil pump, EDC custom AFR 235 heads, T&D shaft rockers, QTP Scatter shield, ACT twin clutch, JBA shorty headers, JBA midpipes, Magnaflow catback, PWM Meth Injection, custom staged twin pump boost reference return fuel system. 650HP in search of the missing 75HP
Old 04-06-2017, 06:09 AM   #5
Duckman
Duckman's Avatar
Questions?
Old 04-08-2017, 07:25 PM   #6
Logan71
Logan71's Avatar
Not exactly in line with the 'racing' theme, but I think a few of use would appreciate your insights on any availabily on rubber or at least softer poly blend replacement parts.
Surprisingly to me, practically all I can find is poly parts, which I'm sure is great for handling, but my goat is the best riding car I've every had, and I'd like to retain most of that.
Thanks!
Old 04-09-2017, 06:38 AM   #7
Duckman
Duckman's Avatar
I have Rubber Replacement bushings available
Strut Mounts:
http://www.kollarracingproducts.com/...bearings-each/
Lower Control Arm
http://www.kollarracingproducts.com/...2004-2006-gto/
Rear Radius Rod Bushing
Front Radius Rod Bushing
http://www.kollarracingproducts.com/...06-gto-rubber/
Endlinks
http://www.kollarracingproducts.com/...ment-endlinks/
Transmssion Mounts
http://www.kollarracingproducts.com/...ery=mt&Search=
Upper Shock Bushings
http://www.kollarracingproducts.com/...k-bushing-gto/
Rear Control Arm Bushings-OUTER ONLY
The balance of bushings I can source through Roadsafe in Rubber. In my opinion the only poly bushing that has any real effect on "ride" quality is subframe bushing. The Ultra sensitive enthusiast may find a poly strut mount to be firm. Premium poly (Whiteline) is very steetable and virtually noise free.
Old 04-09-2017, 04:29 PM   #8
Banananutz
Can you elaborate on that statement? Whats the NVH/performance difference between Whiteline/SuperPro/rubber for this bushing, when paired with BMR subframe connectors?
Old 04-10-2017, 05:52 AM   #9
Duckman
Duckman's Avatar
I have no experience with Super Pro paired with BMR subframe connectors. That question should be directed at BMR. I understand your concern with the choice of subframe bushings when using their subframe connectors. If memory serves me correctly, once the connectors are welded in the bushings will not be accessible without major surgery. I would think that if your at the level requiring these connectors...NVH would be the least of my concerns.
Of the poly mounts, From my experience, the Whiteline has been the quietest. The ES Race only the noisest. EARLY ES Street were pretty rough...they revised the poly its better then it was. I have never used Super Pro or Pedders.
Old 04-10-2017, 08:36 AM   #10
Banananutz
To R&R the bushings is the same process as stock, just 2 extra bolts per side. I threw the subframes on to help stiffen the chassis up, something I do with all my performance cars. Despite that, the car is still a GT car and nvh is a concern.
What's the nvh/performance implications between whiteline and rubber on a car without subframes?
Also, any reason to replace front springs when going to koni inserts if I'm happy with the ride height? Do the lovells ride better or have a performance advantage over stock springs?
Old 04-10-2017, 04:07 PM   #11
Duckman
Duckman's Avatar
I am not engineer nor do I have access to data to answer your request. To the best of my knowledge only one manufacturer makes a subframe connector for this car. Your question is best directed to them.
Lovells Front Springs are approximately 15% stiffer then stock 165# Linear Spring. The ride is firmer then stock without being harsh.
Old 04-14-2017, 09:37 AM   #12
Felix C
Felix C's Avatar
Questions?
you may wish to state the benefits to each package and if they can be installed by the owner with typical tools available in most sets. You know, if you have to rent anything out of the ordinary.
I am interested in the first kit.
2004 GTO 6spd
Old 04-17-2017, 07:22 AM   #13
Duckman
Duckman's Avatar
Email me at sales@kollarracingproducts.com your ride height measured from the center of the hub to the fender arch. I also need to know what has been done to the car and what you want to do with it. It only takes a few email discussions to figure out the system best for you
Old 04-26-2017, 06:59 AM   #14
schufflerbot
voted, 'a dick.'
schufflerbot's Avatar
wheels and tires are on the way, new rack n pinion goes in on May 8th, then it's time to address the suspension on my *new 2005 goat.
Thanks for the package, Ducky, helps a lot!!
http://i39.photobucket.com/albums/e164/schufflerbot/warface-1.jpg
I sincerely miss my
2004 Pulse Red M12
400/374
New ride is a stock 2005 TR M6!
RACING DRONES!!
Liquid Amber Media
Originally Posted by Pork Chop...View Post
I swear the Chinese are putting something in the water to make people incredibly lazy and stupid anymore.
Old 05-06-2017, 04:56 AM   #15
Duckman
Duckman's Avatar
My pleasure
Old 06-02-2017, 05:16 AM   #16
Duckman
Duckman's Avatar
Questions?
Old 06-19-2017, 02:37 AM   #17
schufflerbot
voted, 'a dick.'
Question:
Tie rod ends... why are some $130 and others are $30?
Just curious if the additional $100 is worth it for a daily driver and what the difference in steering feel (if any) is.
Thanks, Ducky!
Old 06-19-2017, 05:36 AM   #18
Duckman
Duckman's Avatar
GM uses TWO different steering racks in a GTO....the common rack uses the economical 16mm tie rods...the GM warranty replacement rack(KYB) uses expensive 14mm tie rods...the parts do not interchange
Old 06-19-2017, 07:30 AM   #19
schufflerbot
voted, 'a dick.'
Interesting. So, I bought the car used and right away replaced the rack trying to resolve a pulling issue. Only way to know which one I have is to measure the tie rod end? ...or is there another way to identify?
Old 06-19-2017, 08:30 AM   #20
Rich-Tripower
Rich-Tripower's Avatar
Does anyone still make front adjustable lower control arms?
2015 Honda Accord EX-L V6 HFP
Rich's 1965 Malibu SS L79 Restoration Page
Rich's 1965 Chevelle Two-Door Wagon Project Progress Page
Bob's 1964 GTO Project Page
Rich's Brazen Orange 2006 Pontiac GTO
Rich C.
"I would rather appreciate what I cannot have than have what I cannot appreciate."
Old 06-19-2017, 08:47 AM   #21
GTO44
2006GTO M6 dd-drag-roadcourse
GTO44's Avatar
Not sure if any of the bigger companies do, but Shane Whalley makes adjustable control arms for the GTO. He's got a drift gto and made a set for his, and now offers them to the public.
Here's him showing the control arm:
Here's another forum member installing them on her gto.
I also know other member on here, ThirdStreetTito said he might or is going to get a set for his goat.
Vararam only, stock tune
Monster Level 2, Tick MC, RS T.Mount, Revshit insert, Hinson M.Mounts
Lovell 340/370mm springs, Koni Sports shocks/struts
Lovell Bushings: Strut Mounts & Bearings, ajust. Radius rod, rear subframe, Diff insert, rear endlinks
Hotchkis Adjust. Sways, Nobush Endlinks
DBA T3 Clubspec slotted, hawk HP+, Russle SS, Motul 600
Rebuilt T56, blocker ring kit, Tick billet 3/4 keys & springs
Dragbags, Catchcan, PTI 1-piece Alum. DS
365/368 (std)
12.81@110.6 2.03 60'
Old 06-19-2017, 09:15 AM   #22
Rich-Tripower
Spohn used to make a nice set but they don't seem to be available any more.
Old 06-19-2017, 09:41 AM   #23
GTO44
GTO44's Avatar
Yeah I remember seeing those for sale back in the day. If I remember correctly people were having some kind of issue with them. Probably the reason they are no longer offered. Unless you get them used.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
