Mini Tub complete - LS1GTO.com Forums
Old 06-16-2017, 01:25 PM   #1
Silvah Goat
600 RWHP CLUB
Silvah Goat's Avatar
Online
Mini Tub complete
This winter I have been a victim of the "well I'm already there" or the "won't get a chance to do it again" train of thought, on so many occasions. This is another example.
I really had my heart set on doing the entire undercarriage in Raptor bedliner. So I talked myself into do the mini tubs from Gforce because once it's coated, that's it for welding. Not interested in grinding it off at a later date. Also after not hooking up at all with 740 crank hp last year, and with the motor back apart for aims of over 900 crank hp, I figured I'd need the extra tire in the back.
Once I could see my garage floor thru the interior of the car, I had this feeling that there was no turning back.
I scribed the gforce tubs to the opening I had created. I cut the absolute minimum I needed to so I can try to avoid wrinkled seats. Did a continuous spot weld around the entire joint. No gaps were left anywhere, even in the firewall.
ID:	461689   Click image for larger version
ID:	461697   Click image for larger version
ID:	461705   Click image for larger version
04 GTO QSM M6
14 GMC Sierra Denali 1500 6.2 - K&N
17 Grand Cherokee - Sackless Daily Driver
17 Acadia Limited 3.6 - Dealer sticker delete mod
Old 06-16-2017, 01:25 PM   #2
Silvah Goat
600 RWHP CLUB
Online
I picked up some beige seam sealer. There were no gaps or holes in the welding but I figured it was there from the factory and it should go back in.
These things were going to make road noise bad, so I stripped the entire interior out and hit it with 2 layers of Lizard Skin.
ID:	461753   Click image for larger version
ID:	461761   Click image for larger version
ID:	461769   Click image for larger version
Old 06-16-2017, 01:26 PM   #3
Silvah Goat
600 RWHP CLUB
Online
I also shot the entire trunk with Raptor bedliner while I was making a complete smurf'n mess.
I didn't really like any of the modifications to the control arms, and I wanted a poly bushing on both points. I also was using the Gforce coilover relocation kit, so most of the load from the front arm is removed.
I decided a sweeping cut, followed with cold formed 1/4" steel would do the trick. I'd fasten it with a double tig pass, and tie the tang into the new metal. After all the welding was done, it was heated to ~650 degrees to normalize the metal.
Media blasted everything, powdercoated it the closest thing I could find to QSM and mounted it up. I also bedliner'd the entire undercarriage (which was the worst experience of my life).
Ended up with 3" of clearance from my 9.5" Beyerns
ID:	461785   Click image for larger version
ID:	461793   Click image for larger version
ID:	461801   Click image for larger version
ID:	461809   Click image for larger version
Old 06-16-2017, 01:26 PM   #4
Silvah Goat
600 RWHP CLUB
Online
I had to cut the panels to fit the new tubs. I also knew a little bit would show so I went to every fabric store and finally found some leather that was somewhat close to a match. Called it good enough. I covered every area I couldn't spray with dynamat. I coated the firewall in dynamat also to try to keep out the noise of the forthcoming Eliminator fuel pump going into a custom stainless fuel cell.
Also layered the inside of the wells with suede so that the Lizard Skin wouldn't wear a hole in my mint back seats.
Got away with minimal wrinkle in the seats. If it bothers me too much, I have a great interior guy who will remove a little foam. If it stays like this, I'll be fine.
ID:	461825   Click image for larger version
ID:	461833   Click image for larger version
Old 06-16-2017, 01:33 PM   #5
jason1168tx
jason1168tx's Avatar
Man that looks good. I really need to do the same.
402 LS2
Livernois Stage 3R 243's
Harland Sharp Rockers
Comp .623/.622 239/242 112LSA
Kooks/Catless mids/Corsa Sport
FAST 102/Nick Williams 102mm TB
Lingenfelter 100mm MAF
Monster LT1-S
XAIR
Old 06-16-2017, 02:11 PM   #6
Silvah Goat
600 RWHP CLUB
Online
Thanks! Crap load of work, but it's not difficult at all.
Old 06-16-2017, 03:07 PM   #7
SilverBullet19
05 Looks, 04 Slow
looks hawt. I find myself always pondering a minitub, if I ever do the power adding I plan. Even for 350-400 whp...275's are pretty skinny for spirited canyon driving.
DD: 2015 Toyota Tacoma TRD Sport
Lady's ride: 2016 VW Tiguan
Pride and Joy: 04 QSM/red M6 (1 of 344)
Retired for DD duties 3/23/15 at 120,600
Full JBA exhaust with shorties and catted mids, Griffin radiator, Lovell's Shocks, King HHD springs (1 inch drop front, 1/2 inch rear), various whiteline poly bushings, DSS 1 piece, Hyperblack 19" VMR VB3's, 05 hood, 05 bumper, Mavman color matched spoiler
Old 06-16-2017, 03:30 PM   #8
Abe05GTO
Abe05GTO's Avatar
Very well executed in all aspects. My hat is off to you sir.
2005 Torrid red A4
Borla catback, AEM Brute Force intake,
Russell Fuel line kit, Aeroflow P/S reservoir, Outback Racing headers, JBA catted mids, Ported intake, DSS carbon fiber d/s, Lovell's stock height springs,
Monroe struts,Whiteline front and rear radius rod bushings, BMR subframe connectors, Duspeed
Enkei EKM3 wheels
Rideskinz front fascia
Roof spoiler
DEPO tails
Pilot Headlamps
Old 06-16-2017, 06:09 PM   #9
Kfxguy
Very nice
Old 06-16-2017, 09:05 PM   #10
Magnified
It's simple physics
Magnified's Avatar
You the man. I mean EXCELLENT work.
LR
2006 PBM (now dirt brown) A4, Magnacharger, Kooks LT, high flow cats, Magnaflow x-pipe, stock pipes into race glass packs, drag bags, subframe connectors/jacking rails, 18x8.5/40 offset Bayern Mesh chrome up front, 18X9.5/45 in the rear, Michelin Pilot Sport PSII, fender roll, DIY catch can, DIY factory amp mod, tuned by Chuck, black badges.
Street configuration consistent #s ONCE UPON A TIME - 12.13 / 117.5 / 1.90 60 foot. 3.75 second 0-60. Lots of wheel spin.
Old 06-17-2017, 04:48 AM   #11
Blue Dream
Still stock and proud of it..
Blue Dream's Avatar
Amazing vision and work, you da man!
Originally Posted by mistermike...View Post
Pucker factor increases as the square of vehicle speed.
1 of 101 SRM, 6mt, 17" wheels, black interior 06 GTO's ever produced
Old 06-17-2017, 05:08 AM   #12
Silvah Goat
600 RWHP CLUB
Online
Still a bit away from the undercarriage porn photo shoot but it's coming along...
Old 06-17-2017, 07:46 AM   #13
lynmup
USAF RET
lynmup's Avatar
Subscribing...
Old 06-17-2017, 09:48 AM   #14
LFSADRG
Need To Drive More
LFSADRG's Avatar
Very nice.
05 GTO MBM M6 - FORGED 6.0/FLOWTECH GRIND/MONSTER 3/SW EXHAUST/FAST 92/AFR 230/N.O.PLATE/XAIR/GFORCE 1320/SLP/PEDDERS/BILLET PROTOTYPES/MAVMAN/LOVELLS/VIKING
01 TA WS.6 A4 - STONE STOCKish
72 LEMANS A3 - FORGED 461/SOLID ROLLER/B&M/FLOWMASTER/EDELBROCK/RAIII/NOS CHEATER/MORRISON
Old 06-17-2017, 10:20 AM   #15
ATITOOD
Excellent work!
Old 06-18-2017, 07:14 PM   #16
Logan71
Logan71's Avatar
Impressive! I don't know how you find the time.
Old 06-19-2017, 02:40 AM   #17
Rob
Been here for a long time...
Rob's Avatar
WOW! Great work
Rob
04 GTO
75 Cosworth Vega
Old 06-19-2017, 04:35 AM   #18
Cucky4
Cucky4's Avatar
gawshh that looks amazing. Quite jealous.
2004 IBM M6-Totaled 6/29/16
2006 CGM M6-Forged 403, F1R, Meth Injection
Old 06-19-2017, 04:49 AM   #19
biglinux
Biglinux
biglinux's Avatar
FAN. very nice!
Old 06-19-2017, 05:37 PM   #20
jamesgiants76
jamesgiants76's Avatar
Very nice work man
Sent from my SM-G930V using Tapatalk
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
