$3 Custom exhaust solution with 3 different loudness settings
So I got bored on friday...lol
I'm getting exhaust soon but I just had to hear what it would sound like. I didnt want to just unbolt the mufflers and let them hang or take them off completely...thats just ghetto.
So I went to the hardware store and bought some washer for 25 cents each. Basically I unbolted the exhaust and put the washer on the bolts in between the pipes and then tightened the bolts back down. Takes less than 10 minutes.
What's needed:
*Washers (1,2 or 3 for each bolt)
*15mm wrench or socket
*Jack & Jack stand for safety. or somehow make room for you to get under the back of the car. I can just crawl under
*REMOVE GASKETS!!! They burn up and turn crispy.
You can only fit 3 on each bolt.
*3 is loud, but not bad. Clacks at WOT (see vids)
2 like 3
1 Idles like stock, but sounds great (kinda exotic) at WOT
so to make your car sound better you gave yourself an exhaust leak?
2005 PBM M6 GTO 1/2 SAP!
SAP front fascia, grilles, wing (in the attic now)
SLP catback
Wingless
Predator
Volant
Pacesetter V2s
B&M Shifter
Some extra PBM here and there.....
"Exhaust leaks" at the back are way different from exhaust leaks at the front. It the same as if I put straight pipes in. Plus, it was just a temporary solution.
So you caused exhaust leaks on purpose...um yeah...
I'm with him, that doesn't make sense to me. I was going nuts on my Nissan trying to make sure I didn't have any gaps. It took me forever to get it where I wanted it.
Hmmmmm, you know those big holes at the end of the exhaust, the ones with chrome around them? Those are big old exhaust leaks right. Leaks are only bad depending on where they are.
LR
2006 PBM A4, Magnacharger, Kooks coated LT, high flow cats, Magnaflow x-pipe, stock pipes into race glass packs, drag bags, subframe connectors/jacking rails, 18x8.5/40 offset Bayern Mesh chrome up front, 18X9.5/45 in the rear, Toyo T1-R Proxes, fender roll, DIY catch can, DIY factory amp mod, tuned by Jason @ MTI, black badges.
Street configuration consistent #s - 12.13 / 117.5 / 1.90 60 foot. 3.75 second 0-60. Lots of wheel spin.
LR
Yes, I get the concept. Typically it sounds like crap any time it's escaping before the tips.
I guess on an 05/06 with the mufflers bolting up by the axle, might not be too bad. But for us 04 guys... the only place to do that is at the mid pipes and that would sound like ass.
2004 IBM/blue M6 GTO
Originally Posted by SkiPopeye36...
JMO, and I've said it before, no arrowhead on the front looks like a boob with no nipple....it just doesn't look right.
Yeah this is more for the 05/06 guys. Doing this to an 04 would sound terrible.
I just don't get it. Sure any car would sound like that if you create a leak in the plumbing. And taking the mufflers off completely doesn't make any sense to me either. OK I get it, the car sounds like something from NASCAR, but that's ok for the track. For the street it just sounds like a car without the mufflers, period. To ME and only me it sounds like........well for lack of another word, CRAP. But what do I know, I'm old and used to a more low rumble and a more refined muscle car sound, but to each their own.........
Sounds good. I don't know much but it doesn't seem much different than installing cutouts (you just can't close yours on the fly), which also sound good. Anyway, if you like it that's all that matters. Thanks for sharing the tip!
Peddars Mods: GSR Big Bore Rear Shocks, +5/16 Rear Drag Springs, 3/8 Drop Front Springs, Diff Insert, Full Poly Bushings, Front Strut HD Mounts/Bearings, Front GSR Struts
USF, I live on Fletcher during school and live in Bradenton during summer.
haha, Ive heard of you, My brother lives on 56th and Fletcher and called me up one day to tell me he saw your GTO. Ive got a Brazen too and he feels compelled to notify me whenever he sees one because I told him how it was a rare color.
http://img210.imageshack.us/img210/3...norange8ro.gif
1994 Trans Am GT - Vortech Supercharged Victory 355, M6 - too much rwhp...Best ET 13.7@111 on old setup - New times soon
1987 Buick Grand National - BPU - ??? rwhp
2006 GTO - BOM, M6, 18's, 400 hp - Stayin Stock...Best ET 13.3@109
ok i just did this. i used 2 3/8 in washers and one 3/8 locking washer. you will have to use a pair of wire cutters to spread the locking washer out a bit if you go that route. it actually worked out for me because it held the other 2 washers in.
1st i took the mufflers off completly because... well... i was curious. damn is that thing loud without mufflers. i then put them back in with the washers and fired her up. it does sound really good. basically it sounds exactly like it does without the mufflers just not insanly loud. so if you like the mufflerless note then definatly jump on this. it is the equivilant of having a cat back installed on the car loudness wise.
i dont think anybody should flame the OP because it is definatly a great mod.
ha i just got done doing it in my driveway! easy as cake and it sounds better than i expected. no snap crackle or pop it is pretty deep. It will suffice till I get my SLP LT's and Loudmouth this summer!
and i thought honda owners were bad , atleast they rice out cheap cars , not a 30K car
lol hey it will do until i get my parts put on in a month. my sig list is sitting in my garage. i love the sound but there is a bit too much crackle on decel for my taste. once everything goes on the washers come off. hey... its a cheap cat back system that does sound really good.
hey i was just curious... will this cause you to lose any power or gas mileage??? i got on it a little and it did feel notacibly slower. maybe its just me subconciously expecting the car to go faster because its louder.
then you mickey mouse it with washers , LOL
I agree...the line between "ghetto" and "mickey mouse" is razor thin...
