Go Back   LS1GTO.com Forums > Regional Forums > Midwest
Register Home Forums Active Topics Knowledge Base Site Rules Search Today's Posts Mark Forums Read
Old 10-31-2008, 03:39 PM   #1531
mrtosh
Here 2 chew gum and kick ass
mrtosh's Avatar
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Mods: PRC stg 2.5 5.3 heads(milled .010) MTI X1 (230/228 .592/.571 112LSA), LS7 lifters, Tune by "CJ Tunes", PRC dual springs,7.4" hardened PR's, FAST 36lbs injectors, Walbro 255, Monster Level 3, lightened flywheel, 3.91 gears, spring tuning kit, E.E. catch can, K&N CAI, Pacesetter 1 3/4" LT's, Corsa Touring, Billet Pro shifter,MiroType 359,19" Staggered, Powerslots, Hawk HPS C5 pads, BMR Drag Bags, Damn right there rolled, Spoiler delete.
Old 10-31-2008, 03:49 PM   #1532
01 MidMet WS6
01 MidMet WS6's Avatar
So, I finally got around to pulling apart the T/A last week and found some interesting things. A little backround on the car, I always thought that it smoked a little more than it should but wrote it off as the typical LS1 puff. This spring I installed a pair of PRC stage 2.5 5.3's along with an MS4, flycut the pistons, etc. After driving the car for a while, 2k miles it felt like power was falling off. I was at the dyno with another car and strapped mine down just to see what kind of power it was making. It went 410whp and 372wtrq on a mustang, knowing it was low I did a comp. test and found #7 down around 110psi (all others 225-230). After that I only drove the car a couple of times and it started smoking much worse. So here is what I found!
Other things to note, there was NO cylinder scuffing and the top of the piston looked perfect as did the top comp. ring. There is a lot of very fine aluminum in the pan so everything will be coming apart. I will be forging it up, cleaning up the heads and stepping up the cam a little in prep for next spring. Then will come the nitrous, lots of it!!
01 WS6 M6, PRC Stage 2.5 5.3's, MS4, Kooks 1 3/4", ORY, Corsa Cat-Back, SLP Lid, 18" Boze Alloys, sportlines, UMI PH, LCA's, and Re-Locate Brackets, 4.10's, self tuned w/ HPTuners
New #'s Soon!!!
Old 11-02-2008, 01:44 PM   #1533
mk9190
12.63 stock H/C
mk9190's Avatar
I have an extra pair of 04 gto axles for sale,pm if interested.
Old 11-04-2008, 07:40 PM   #1534
WilsonSSS04
I eat *****........cats.
WilsonSSS04's Avatar
Originally Posted by 01 MidMet WS6...View Post
Well, thats no good. Can't wait to have another N20 car to play with, ................I mean beat.
Can't wait to see the beast alive and ready to go again.
06 GTO-Money Pit-Sold
OMFG FAIL!
Originally Posted by dms...View Post
The install procedures require common sense. Those with common sense do not cut bump stops, plus I am gay. mike
Originally Posted by Rob@WretchedMS...View Post
I had drag bags before, I cut my stops, I haven't re-welded them. I am gay also.
Old 11-04-2008, 08:03 PM   #1535
mrtosh
mrtosh's Avatar
May have more than one car to play with that's boosted.
Old 11-05-2008, 06:03 PM   #1536
Death{AW}
Polish crazy guy :-D
Death{AW}'s Avatar
Send a message via Yahoo to Death{AW} Send a message via Skype™ to Death{AW}
I will be also :-P but only with me behind the wheel :-D should be enough :-D HEHEHEHEHE
Death{AW}
Old 11-05-2008, 06:07 PM   #1537
WilsonSSS04
Old 11-05-2008, 06:08 PM   #1538
WilsonSSS04
I have an annoucment, there is someone famous among us here..... Watch and learn.
http://videos.streetfire.net/video/M...-on_196939.htm
<cough>sean<cough)
Old 11-05-2008, 06:53 PM   #1539
mrtosh
mrtosh's Avatar
<cough>sean<cough)
Thank you thank you.... I knew my video whoring abilities would one day work in my favor. Now where's my royalty check!!!?
Old 11-06-2008, 06:43 AM   #1540
Death{AW}
Death{AW}'s Avatar
What check!!!!! you supose to pay to be on this video :-P
Old 11-06-2008, 08:21 PM   #1541
SpEeDWoRlD
Mmmmm Hmmmm
SpEeDWoRlD's Avatar
How much for an autograph? No offense, but I would probably re-sell it on Ebay...
Old 11-07-2008, 01:10 PM   #1542
PewterMNZ
anyone interested in some z06 rims?
Old 11-07-2008, 04:15 PM   #1543
WilsonSSS04
Hmmm... get the rim fixed and get them pc'ed satin blk. That would look nice. What size are they? 18x10 rear? 18x8.5 front?
Might just want the rears for DR's.
Old 11-07-2008, 04:16 PM   #1544
SpEeDWoRlD
Mmmmm Hmmmm
SpEeDWoRlD's Avatar
Ummm thought you just bought these? Decided you didn't want them? LOL
Old 11-07-2008, 04:17 PM   #1545
WilsonSSS04
Lol!
Old 11-07-2008, 04:20 PM   #1546
mrtosh
mrtosh's Avatar
These do run crazy offsets(something like 52/54mm) def need spacers. Also backspacing is a bit off from ours (5x120.65). I have seen some guys put them on the GTO.
Old 11-07-2008, 04:22 PM   #1547
WilsonSSS04
You mean bolt pattern?
Might have to notch out the rear arms.....hmmmm.
Old 11-07-2008, 05:03 PM   #1548
mrtosh
mrtosh's Avatar
Whoops, you mean what I know....
Here's a vid of prolly the sickest looking Goats I've seen
http://videos.streetfire.net/video/G...LS2_197187.htm
Old 11-07-2008, 05:12 PM   #1549
WilsonSSS04
Wow. That thing is sweet.
Old 11-07-2008, 07:02 PM   #1550
PewterMNZ
Mike,
Fronts : 17x9.5 Rears: 18x10.5
The rears are fine. It is just the one front 17 that might need some work.
I believe the rear offset is 58mm. I can double check if you like. A lot of guys do 315's on the rears.
Make me an offer if you are interested.
Old 11-07-2008, 07:03 PM   #1551
PewterMNZ
Decided that heads are more important, and after talking to Sean today, I will be getting a a/f gauge as well. Got to pick my mods wisely.
Old 11-07-2008, 10:07 PM   #1552
SpEeDWoRlD
Mmmmm Hmmmm
SpEeDWoRlD's Avatar
Good idea.
Old 11-08-2008, 10:34 AM   #1553
mk9190
12.63 stock H/C
mk9190's Avatar
That is sick!!!Anyone else notice the t/b?
Old 11-08-2008, 10:37 AM   #1554
mk9190
12.63 stock H/C
mk9190's Avatar
Been there,done that.
Old 11-08-2008, 04:35 PM   #1555
mrtosh
mrtosh's Avatar
one of the first things i noticed when he let off on the first pass... Only way to go!
Old 11-12-2008, 10:44 AM   #1556
dtm8119
Go Twins
dtm8119's Avatar
Send a message via AIM to dtm8119 Send a message via MSN to dtm8119
Hey, do any of you guys know of a place in the SW metro area that swaps out tires for a low price? I'm buying some used blizzak snow tires for my winter beater. I stopped by a Tires Plus today and they wanted $95 bucks to do this which I thought was completely ridiculous! Thanks!
05 GTO M6 18's
Old 11-12-2008, 02:40 PM   #1557
SpiceRedGuy
Yes officer, It has exhaust!
SpiceRedGuy's Avatar
$20-$25 a tire is about the going rate, unless you know someone who has their own mounting/computerized balance equipment...
06 Spice Red Metallic M6, 1 of 632. Born on 04/06. Factory 18s for winter, TSW Mondello 18x8s on Nitto NT555s for all other seasons. SLP LTs, 18" Sweet Thunders, New Era intake, GMM Ripshifter, SAP spoiler and DashHawk. ProLumen 5k HID kit. HPTuned by Carl. Passport G-Timer for fun - Passport 9500ix to stay out of trouble.
Old 11-12-2008, 06:37 PM   #1558
WilsonSSS04
Try 3-T Repair on 169 and 41. Tell them "Ditch" told you. Ask for Nick or Betty. They can quote you a price.
Old 11-12-2008, 07:22 PM   #1559
dtm8119
Go Twins
dtm8119's Avatar
Alright, thanks!
Old 11-12-2008, 07:50 PM   #1560
mrtosh
mrtosh's Avatar
If you want really cheap take them to Walmart for a mount/dismount. Probably run you 20-25 for all 4.
You may not post replies
vB code is On
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2003-2008, LS1GTO.com
Site Banner Design ©2005-2007, Cylosoft
LS1GTO.com is not affiliated with General Motors Corp.
