Go Back   LS1GTO.com Forums > GTO Tech > Drivetrain
Register Home Forums Active Topics Knowledge Base Site Rules Search Today's Posts Mark Forums Read
Old 11-28-2008, 09:23 PM   #1
clutchless
a4 guys: Trans Cooler or Derale Cooler Pan??
Hey guys,
i am about to flush the tranny again, reaching 60k miles and figured it wouldn't hurt to add alittle extra protection.
Cars all stock except for a cat back and plan to add a few more bolt ons maybe LT's, ported tb/intake, tune nothing to crazy and i was leaning toward derale pan because that way less chance of hoses leaking, let me know what you guys think...
Old 11-28-2008, 09:33 PM   #2
xCOLDx
I have beach vollyball tonite
xCOLDx's Avatar
I'm going to get both when i put in my stall, I'd suspect the pan is easier, but the cooler has better cooling capabilities.
since your all stock and not planning a stall, I'd go with the pan.
Spice Red A4, VZ bumper,HSV roof spoiler, JHP lip Spoiler,VIG 3200, FAST 92, FAST fuel rails, 234/240 cam, 1.7 Yella Terras, PowerBond pulley, SCSS pod, AVIC D3, ARH 1 7/8th headers, SpinTech Side exit exhaust, Race Proven Motorsports tune, halo headlights with HIDs, 0 drop rear springs, drag bags...up next: PT6776 turbo in a t4 housing and CCW's
Old 11-28-2008, 09:35 PM   #3
lanseman
Dad's Yellow Goat
lanseman's Avatar
Send a message via AIM to lanseman
Having gone 60k without any issues is enough of a reason to do nothing. With the mods you stated as far as the trans is concerned the car is stock. If you not racing much,i.e. power braking, than you are not building a lot of extra heat. Your PM program is probably doing more good than a cooler would at this point. Put a high stall converter in and all bets are off, racing often same thing.
http://inlinethumb58.webshots.com/83...500x500Q85.jpg
346ci, Cartek Forged short block, cam and heads, Kooks 1 7/8 headers, no cats, into modified STS Exhaust turning a T-70 rear mounted turbocharger, Rossler TH 350, Vig 4,000 multi disk lockup converter. 605rwhp 660rwtq, power put to the track by Rocksand Racing. Frank hooked me up with some gears! PB:10.35@131
Old 11-30-2008, 09:38 AM   #4
srtklr
I agree with these guys. At the level your at a cooler is not needed. Honestly I think you would be wasting your money on an upgraded pan too. Ive got a 3400 converter in my car and still havent installed a cooler. I watch my trans temps closely with hptuners and they have never gotten over 200 degrees even in the heat of summer. Having the trans temps too cold can be nearly as bad as having them hot.
I do have pulse width modulation for the tcc removed completely with a solid valve and have the cooling fans come on so they keep engine temp just under 200 deg. That helps keep the trans temps down as well As a reference, before any mods to the trans or cooling fans the tranny temps would be in the 210-220 range while idling and stop and go traffic.
Old 11-30-2008, 09:57 AM   #5
sledheadRick
sledheadRick's Avatar
I installed a trans cooler after putting in a 2800 stall. The install was very easy - took 30 minutes and 3 beers.
Haven't had any issues but I make a habit of changing out the trans fluid annually.
sledheadRick
'06TBSS AWD - all stock
'04 PBM/B A4
mods: some-a-dis, some-a-dat
Old 12-01-2008, 10:40 AM   #6
BUstd
JNTDC
BUstd's Avatar
The derale pan is a good purchase; extra fluid never hurt and you get some cooling (2-3*) on the highway.
the drain plug makes future fluid changes a little less messy too.
Old 12-01-2008, 07:19 PM   #7
clutchless
I've taken it to the track 3 or 4 times, and if i were to add headers and such i may take it back but its on a rare occasion i just was thinking about planning ahead so it lasts.
Also with a tune and removing some TM that it could cause alittle more heat but not enough to need one? even in florida summer stop and go lol.
Old 12-02-2008, 07:11 PM   #8
Pappa Prich
06 Cyclone Gray A4, 1 of 336
Pappa Prich's Avatar
Thumbs up
listen to this^^^
Pedders suspension by ROCKSAND RACING
Tuned by RPM
Build order plate, 20% tint, SCSS gatorpod w/oil/fuel, Kircher Splitter, BP Oil CC, SCSS Trans & MMs, Hendrix-ENG wires, Hendrix-ENG Brake Lines, NGK TR-55 plugs, 160 Tstat, RPM Hardcore CAI, SLP Underdrive pulley, P&P TB & Intake Manifold, Ed Curtis StreetSweeper Blower Cam & valvetrain Kit, FTI 3600 converter w/Hayden Trans Cooler, Coated Kooks S.S. Headers and catted mids, Bassani Cat-back, TSW Crofts 18s x 19s, Harrop Diff Cover
Old 12-03-2008, 10:40 AM   #9
JS1965
In the hot summer driving with just a derale and my shift kit/vig 3200 I am at 195 to 210 and In the fall 180 to 200...I dont beat on the car when the trans is above 195 and I only make 2 runs at the track back to back and so far the trans fluid and trans are fine 15K and going strong..
I may add a cooler but I really dont this I need one...
4K + stall and I would have one for sure...
2006 TR GTO A4
http://www.ls1gto.com/forums/profile.php?do=editsi  gnature#sigpic
M2 Race 243's/Comp XER 273HR/Fast92/3.90's
Dynoed SAE 430/395
ET 11.91@114.44
SOLD
2000 WS6 H/C
Best Et 10.89@124
Old 12-03-2008, 10:44 AM   #10
05Judge
Midnight GTO
05Judge's Avatar
I have yet to see a need for a cooler. I've got a 427 stroker pushing a 5k stall and I rarely get over 200 degrees. At the track it will hit 200 but I let it cool down between runs anyway so I just haven't found a cooler necessary at all.
2005 GTO Midnight Blue A4 1 of 368
Old Setup: TSP 427 Stroker - Didn't last even 6k miles and spun a rod bearing
The Dyno
First 1/4 mile with 427
Idle & Rev - Magnaflow
60-140mph Acceleration
Old 12-03-2008, 02:54 PM   #11
srtklr
There ya go OP. If this guys tranny is ok without one you will be too lol.
You may not post replies
vB code is On
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2003-2008, LS1GTO.com
Site Banner Design ©2005-2007, Cylosoft
LS1GTO.com is not affiliated with General Motors Corp.
