Go Back   LS1GTO.com Forums > GTO Tech > Drivetrain
Register Home Forums Active Topics Knowledge Base Site Rules Search Today's Posts Mark Forums Read
Old 12-17-2008, 01:29 PM   #1
Pappa Prich
06 Cyclone Gray A4, 1 of 336
Pappa Prich's Avatar
Question A4 Tranny cooler guys step in
Hey guys,
Just more searching for the build....Next is the Cam install (FTI streetsweeper cam kit), stall converter (vig. single disk 2800), and tranny cooler. Which cooler are you running and why?
Keep in mind this build is being done/prepped for FI down the road, maggie.
Thanks,
Bryan
Pedders suspension by ROCKSAND RACING
Tuned by RPM
Build order plate, 20% tint, SCSS gatorpod w/oil/fuel, Kircher Splitter, BP Oil CC, SCSS Trans & MMs, Hendrix-ENG wires, Hendrix-ENG Brake Lines, NGK TR-55 plugs, 160 Tstat, RPM Hardcore CAI, SLP Underdrive pulley, P&P TB & Intake Manifold, Ed Curtis StreetSweeper Blower Cam & valvetrain Kit, FTI 3600 converter w/Hayden Trans Cooler, Coated Kooks S.S. Headers and catted mids, Bassani Cat-back, TSW Crofts 18s x 19s, Harrop Diff Cover
Old 12-17-2008, 05:27 PM   #2
Plumcrazy1
Finally in the 10's
Plumcrazy1's Avatar
I am running a Derale cooler with fan. Part # 13700 got it from Jegs with a thero switch that turns the fans on and off. Installed mine with new steel braided line and AN fitting without going to the radiator. If you do a search I have pictures in here some place...
My LSX Build
04 Cosmos Purple Metallic LSX 427 Th400 Autoform Cowl Hood
Lonnies Fuel System Hardcore Intake
Tuned by Hardcore with HP Tuners
Old 12-17-2008, 05:30 PM   #3
Pappa Prich
Thanks man^^^I've been searching for a while...and I have not really found too much.
What did that run you altogether?
Old 12-17-2008, 05:51 PM   #4
Pappa Prich
Well after some more searching I've come up with these brands....TCI, Earls, and B&M...anyone have experiences with them? What kind of set-up did you use.
Thanks guys!
Old 12-17-2008, 06:02 PM   #5
JETNITRO
10 Second N/A Club
JETNITRO's Avatar
Hayes Super cooler My Trans temps runs around 138-150...Summer time 90 degrees outside Trans Temps are 155-170
10.59 @ 126.61 MPH N/A 346 c.i H/C Stock Bottom End... 1.460 60 ft
http://www.Cartek.net
1/4 Mile Video>>
http://videos.streetfire.net/video/B...GTO_203760.htm
http://www.highperformancepontiac.co.../photo_06.html
Coming soon...www.njpontiacgroup.com
Old 12-17-2008, 06:07 PM   #6
SLO GTO
SLO GTO's Avatar
I have some B&M, got it for cheap.
works just fine. they'll all work ok....a cooler isn't exactly the most technologically advanced part, they're all pretty much the same.
but if I could do it again, I'd get one w/the small fan on it. especially if you live somewhere hot and you have to do lots of heavy traffic driving. Had a small situation w/traffic and summer in texas
'04 A4 - 24x/24x cam, stock ls6 heads, stock intake manifold and TB, generic no-name 3500 stall, 150 wet shot, Drag radials with bone stock suspension
550rwhp through built 4L60e
1999 Civic = RACE CAR (too many mods to list)
Old 12-17-2008, 06:11 PM   #7
Black04A4
Black04A4's Avatar
Online
Thanks guys!
I'm running the B&M cooler. Here's a link to some pics and a parts list from my install. Look in post's 9 & 15.
http://www.ls1gto.com/forums/showthread.php?t=216833
2004 Phantom Black A4 GTO
Mods-Flowmaster catback, Dynatech LT's, Vinci 099 cam 232*/240* .551"/.551" 117 lsa, Comp Pro Magnum Rockers, Edelbrock Victor Jr. Intake, Edelbrock 90mm TB, Patriot ported 243's, Procharger P1SC @ 9psi, Performabuilt Level 2 4L60E, Performabuilt 3K stall, 2-Bar SD tuned at home with HP Tuners.
Old 12-17-2008, 06:17 PM   #8
Pappa Prich
THanks man, your thread was actually one that helped me get started
Good advice I'll look more into that....But this is not a DD but more my toy...and I live in Maryland where you never know what the weather wants to be lol
Old 12-17-2008, 06:19 PM   #9
Pappa Prich
Thanks Bruce, if Hayes is working well for you will your build (and I know you drive the crap out of that thing ) that is a brand I will definitely look into
Old 12-17-2008, 06:22 PM   #10
05Judge
Midnight GTO
05Judge's Avatar
I don't run one at all. My temps stay about the same as coolant...maybe a tad hotter. But that's just me...I am going to be using one when I do my TH400 swap, only because it came with the cooler though.
Oh and this is a 427 stroker with 5500ish stall.
2005 GTO Midnight Blue A4 1 of 368
Old Setup: TSP 427 Stroker - Didn't last even 6k miles and spun a rod bearing
The Dyno
First 1/4 mile with 427
Idle & Rev - Magnaflow
60-140mph Acceleration
Old 12-18-2008, 03:47 AM   #11
The Rock
GTO = Pontiac shenanigans
The Rock's Avatar
Location: Jax FL and wherever they decide to send me...
I have one on mine here is the link. I needed to fab some bracket hangers for it since it is a larger cooler then most run.
http://www.jegs.com/i/B%26M/130/70274/10002/-1
My temps stay at about 130-140 and stop and go traffic they get as hot as 160.
"Christina" aka "Chistine" 2006 SRM (1 of 369/A4 & 1 of 1/A4 w/418ci)
" No name" 2009 Z06 3LZ Blade Siver Metallic Corvette
Performance/Misc:
TSP LS3 418, Trickflow Heads, Ed Curtis Cam, PAC 1521 springs, Morel lifters, JB Catch Can, Ed Curtis P/P FAST 90, FAST FRs, HARDCORE CAI, KOOKS Stepped LT, FTI stall, TP Tranny, Borla CB, LPE Oil Pump, 45# Inj., SLP Pulley, LPE Fuel Pump, Drag Bags, King Springs, PLX WB, Tony Gonyon Tune
You may not post replies
vB code is On
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2003-2008, LS1GTO.com
Site Banner Design ©2005-2007, Cylosoft
LS1GTO.com is not affiliated with General Motors Corp.
