BC Coilover Install Writeup - LS1GTO.com Forums
Old 09-15-2010, 09:18 PM   #1
Oh4GTO
dum dum dum dum dudum
Oh4GTO's Avatar
Send a message via AIM to Oh4GTO
Ive never done a writeup before so I figured why not. This was my second time doing a coilover install so I knew what to do and the picture taking wasn't going to eat up much time. Plus for me this is one of the installs that are fun. I also like doing big brake installs too. Heads and headers are a major fail. I hate them. Probably because Ive done it over ten times already and it kills my back. Anyway, here we go.
Open the box and marvel and the goodness. I find it funny how these are packaged EXACTLY the same as the Pedders coilovers. In fact everything in this box is 99% the same and the other red box.
Wipe the drool off your face and get your lucky spring compressors out. This is the funnest part of then install.
Next undo the top nut.
This is the strut top bushing. This bearing comes out and is replaced with the new one that BC provides.
This is the order the the top of the coilover is assembled. Make sure the washers are facing the correct way. There will be a diagram provided with the kit. Probably the only legible part of the instructions. Snug it tight. Doesnt have to be anything crazy.
Enjoy your shiny new coilovers. They will be dirty soon.
To adjust the shock you only have to loosen the bottom nut. DO NOT TOUCH THE NUTS THAT HOLD THE SPRING. These are preset from the factory for a particular pre-load for the spring. Then jack up the arm to get some weight off. You will have to play with this setting until the threaded body can be spun by hand. That is how you adjust height.
LS3 longblock, LS9 cam, LS9 headgaskets, NW 90mm, APS 5psi = 610 RWHP / 578 RWTQ
Old 09-15-2010, 09:43 PM   #2
Oh4GTO
Oh4GTO's Avatar
Rear install
Undo the sway bar.
Put a jack under the control arm. Get your breaker bar out and undo the shock bolt. You may need to use some PB blaster depending on where you live.
Peel back the carpeting in the trunk to find this little guy. The passenger side is hidden by the fuel fill line. Its a pain to work on that side. You are going to need to use vice grips to stop the shock from spinning while you undo the nut.
You are going to need to re-use the stock bushings.
This is how they go on the BC strut. Washer and bushing on the bottom and the other on top.
To reinstall to shock at the top you are going to have to use an allen key to stop the shock from spinning. Just snug it up and make sure both sides are relatively the same length.
Remove the original spring using the spring compressor. Put the new BC spring and perch as pictured. I didnt reuse the rubber pancakes that are originally there. The limit how long you can go because the rear on the pedders wouldn't go that low unless I removed the height adjuster nuts. Plus with this kit you get a rubber insulator for the spring.
Jack the arm back up until you get some pressure on the spring and the perch is almost flush with the body.
This is how long the shock was for me. This is because I had put the spring perch on the lowest setting. Loosen up the nut and spin it way up.
Next you are going to have to thread the bottom portion until the mounting eyelet is lined up with the mounting hole in the control arm. Thread the bolt back in and torque it to 75lb/ft.
In order to make height adjustments for the shock you dont have to unbolt it. The threaded body will spin. You just have to jack the control arm to get the weight off the shock and play with it until it becomes easy to turn the threaded body. A good rule of thumb is for ever X you change the spring perch, the shock must be changed by 3X.
Hope this was helpful. Fire away if you have any other questions.
Old 09-16-2010, 04:26 AM   #3
DocDiggy
DocDiggy's Avatar
Kind of a quick how to for people that have not done this before. So I have a set of Kollar strut mounts in the closet. Does that mean I don't have to use a spring compressor if I use those??
Pacesetter LT's, Vararam, GMM Ripshift, Borla Catback, Catless Mids, 3.91s, Ls7 clutch, Mav Man CF hood, GFocre 1 piece DS, Ls2 Portworks Manifold & TB, JamesBiz CC, IAT relocate, 06 Tails, Splitter, Red stuff, more Blue stuff.
1 of 146.
Old 09-16-2010, 10:46 AM   #4
Oh4GTO
Oh4GTO's Avatar
Thats right you wont have to use the spring compressor.
Old 09-16-2010, 11:56 AM   #5
trueblueconvert
trueblueconvert's Avatar
what seetings do you have the dampners set too and how would you rate the ride quality
Old 09-16-2010, 01:55 PM   #6
Oh4GTO
Oh4GTO's Avatar
I have not driven the car yet. But with the pedders the softest setting provided a very plush ride. It was better than stock shocks and lowered springs.
Old 09-16-2010, 02:05 PM   #7
Wang
Banned
Wang's Avatar
Thank you for this writeup, Oh4GTO. I'm a coilover noob. Interesting that the existing rear springs seem to be reused, but with the addition of height adjustment. Between this and Pete's XA installation videos, any gearhead with reasonable aptitude should be able to install these.
http://www.ls1gto.com/forums/showthread.php?t=327708
Old 09-17-2010, 08:39 AM   #8
Oh4GTO
Oh4GTO's Avatar
http://www.youtube.com/watch?v=B8B1oh_mHqA
The rear springs are not re-used. The kit comes with new springs and they are completely different than the stock pieces.
Old 09-19-2010, 09:04 AM   #9
goats&guns
FUArock
goats&guns's Avatar
No camber plates for the front!?!?! WTF mate.
Old 09-19-2010, 12:05 PM   #10
winegamd
can anyone take a couple of measurements for me? What is the length of the BC rear springs and what are the inside diameters of the ends?
2006 GTO Torrid Red M6- eh....its not too bad.
Old 09-19-2010, 12:25 PM   #11
ShelbyGoat
bananas
ShelbyGoat's Avatar
excellent write up, enjoy them, i had mine slammed the whole time I had them
camber will be way off, I adjusted it myself, the rear wasn't all that bad though
Carolina Goat Herd and SVGTO
Old 12-02-2010, 05:04 AM   #12
04GtoSilverboy
04GtoSilverboy's Avatar
I am ordering a set of these.
Old 12-02-2010, 04:22 PM   #13
StangSlaya
StangSlaya's Avatar
How much did you rub in the front??
Old 12-02-2010, 06:16 PM   #14
04GtoSilverboy
It there a need for a rear kit if I am running King HD and koni shocks out back already?
Old 12-02-2010, 06:20 PM   #15
Oh4GTO
Oh4GTO's Avatar
No need for the rears really. Not really sure how they will work together.
Old 12-13-2010, 01:31 PM   #16
DocDiggy
DocDiggy's Avatar
Maybe a dumb question, but I ordered a kit from Kollar that came with RR bushings, strut mounts and bump stops. Are bump stops used on a coilover setup??
Old 12-13-2010, 03:49 PM   #17
Oh4GTO
Oh4GTO's Avatar
Yes because you don't want the actual shock to bottom out. It will damage it.
Old 12-13-2010, 04:46 PM   #18
DocDiggy
DocDiggy's Avatar
After reading your write up and watching the Pedders video, where do the bumpstops go?? Forgive my lack of knowledge when it comes to suspension.
Old 12-13-2010, 05:24 PM   #19
Oh4GTO
Oh4GTO's Avatar
Ok I think I see why you are confused. The bump stops that you got are for the original shocks. The coilovers have them built in.
Old 12-13-2010, 06:17 PM   #20
DocDiggy
DocDiggy's Avatar
Ok good. Thanks for clearing that up.
Old 12-14-2010, 01:35 PM   #21
Jim Ignatowski
Hope he gets it!
Jim Ignatowski's Avatar
rear bump stop is hidden by the little cover.
1 of 147
Old 12-14-2010, 01:40 PM   #22
Jim Ignatowski
Hope he gets it!
When i installed the fronts, i did not make any height adjustments. It was slammed and the only rub i got was ever so slightly while pulling into an inclined driveway.
I've since adjusted them about 3/4 inch higher and it has eliminated the rub and improved the comfort.
Old 12-14-2010, 06:13 PM   #23
DocDiggy
DocDiggy's Avatar
How was the camber with it that low??
Old 12-15-2010, 12:06 PM   #24
Jim Ignatowski
Hope he gets it!
used a lovells quad eccentric kit in the rear. Front was fine with just the front just using the camber screws.
Old 12-31-2010, 03:12 PM   #25
El Dee Bee
Excellent job !!
El Dee Bee
So Cal
'87 GN, '06 GTO
Spice Red
Old 12-31-2010, 03:48 PM   #26
m45
nice , good write up.i think thats the only way to go is coilovers ,of course it would be nice to have coilovers in the rear but for the price its a good deal .
Old 01-15-2011, 06:50 PM   #27
mojackson2390
nice job on the write up. REALLY easy to follow the steps.
Old 01-15-2011, 10:19 PM   #28
americanbdass
NCG
americanbdass's Avatar
OP did you have to reuse your top retaining plate nut?
04/PBM/M6
Old 01-16-2011, 08:39 AM   #29
Oh4GTO
Oh4GTO's Avatar
Yes you reuse it.
Old 01-25-2011, 01:31 AM   #30
chromess
How and where do you adjust the dampening?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
