home made cold air - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Tech Lounge
Old 01-05-2013, 08:16 PM   #1
gto4gbr
Lightbulb home made cold air
was thinking about cutting the stock air intake off and then just running a filter a couple inches off the intake anyone done this or would this be a bad idea? i was thinkin to try to make it like the vararam intake
Old 01-05-2013, 08:22 PM   #2
HalfWayOutTheDoor
Elgin Goat
HalfWayOutTheDoor's Avatar
Mock it up, post pics and results.
Elgin A4 Goat. ARH Long tube headers, High flow cats, Magnaflow cat back, Lingenfelter CIA, P&P TB, Reckart performance tuned, Pedders Sports Ryder. 335hp / 348tq.
Old 01-05-2013, 08:23 PM   #3
Cwarta
MO POWA!
Cwarta's Avatar
Lots of hot air is in your future :/
2004 GTO M6 QSM
416 forged stroker lq9 block - Callie's crank - eagle rods
Custom FTI cam, Vic Jr, borla, Tick lvl 2 T56
McLeod rst - prostars - tires - Qa1 coil overs
Custom 4 link 9" SRA
1970 SS Nova - 362ci swapped Lt1 - Cam- t56 - 3:73's - borla - 2,800lbs
Old 01-05-2013, 08:24 PM   #4
xtaspeed05
Abracadabra Holmes
xtaspeed05's Avatar
2005 gto MBM M6 1 of 566
Stock~315/317~13.35@104.85~2.09 60'
Go Fast-Vararam|Ported Intake & T.b.|Jba shorties w/gutted cats|Tq.V2 cam 113lsa|Asp udp|LS7 clutch||Dyno tuned|420/393
Show-Sap front fascia & grill's|Klearz markers|06 tails|Jhp V1 lip spoiler|18X8.5 ADR's
Best E.T.
1/8 mile~7.74@92.13
1/4 mile~11.99@115.46~1.82 60'on Nitto Dr's~D.A. 250ft.
Best 60ft. 1.78
Curb weight ~ 3620lbs.
'00 540I~14.3@96
Old 01-05-2013, 08:24 PM   #5
Tyler Z28
Bangin Gears
Tyler Z28's Avatar
Go with a svede. There are plenty of used ones to be had on in the for sale section. I got a used one with a small (fixable) crack at the opening for under $200. It's much better than the stock setup and your proposed home made intake, I had the same aspirations of making my own, but I caved and bought a proven intake.
2004 GTO M6, 243 heads, 224/228 TSP cam, Svede intake, JBA Shorty's Catless Mids 383HP/376TQ
Whiteline RR bushings, Rear Sub frame, Diff inset and trans insert
Old 01-05-2013, 08:28 PM   #6
HalfWayOutTheDoor
Elgin Goat
not to sidetrack but.. xtaspeed05 ,that's a great looking car!
Old 01-05-2013, 10:37 PM   #7
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
( 'o')b
( '_')o
(._. )
Old 01-05-2013, 10:42 PM   #8
04QSMGoat
04QSMGoat's Avatar
No. The only "homemade" intake I would bother tackling is a hardcore intake. I pieced mine together with couplers and piping I had for around $80, all I paid for was the holesaw, arbor bit for the saw and the Spectre filter. Even then this is temporary because I know it's not as good as a Svede or Vararam. Honestly OP just buy a Vararam. New they are under $250, used they are around $150
2004 QSM GTO: Forged 347, bolt ons, stalled auto PHK
Old 01-06-2013, 07:41 AM   #9
batboy
cave dweller
batboy's Avatar
Let the ghetto mods begin.
2004 torrid red with red interior A4 GTO (1 of 499)
TR-230/236 cam/TEA ported Trick Flow 215 heads/4" CAI/100mm MAF/ported FAST 90/Kooks/Magnaflow
Performabuilt trans/3200 stall/Truetrac/Gforce1320 half shafts, stubs, CF driveshaft/SSR wheels/SNL tune
Old 01-06-2013, 08:06 AM   #10
Audacious Nick
Send Nudes
Audacious Nick's Avatar
Did you own a Honda Civic, or something similar, before this?
Why? Have you done extensive research to see if this will be beneficial? Or are you doing this because it will look cool? Hint, having a half-ass setup like this will look like shit, and will probably be detrimental to performance, due to the massive amounts of hot air you'll be sucking in.
I'm sure Autozone would love you, though.
2004 GTO- Gone.
2008 Corvette- Also gone. Stock- 12.5@118
2007 ES350-Racecar. Cabin air filter swap, air filter swap, spark plug swap, Pennzoil Platinum, air in tires, some MLV, premium unleaded, Michelin wipers.
2006 GSXR 1000- "The 250." Akrapovic full exhaust, Rotella, brake lines.
Old 01-06-2013, 08:25 AM   #11
high school goat
Retarded Spark
high school goat's Avatar
Send a message via AIM to high school goat
SOLD
Old 01-06-2013, 08:27 AM   #12
paulsz28
Bolt Extractor
paulsz28's Avatar
OP,
A filter right off the intake will just guzzle the hot air coming off the radiator. Your car wants dense, cold air to make power - not the hot, massless volume right behind the radiator. PV=nRT, right? Hot ambient air will have less oxygen than cold ambient air of the same volume. The more oxygen you put into your engine, the more fuel the PCM will spray, and the more power the engine will produce (ZOMG, what a hideously gross oversimplification).
You have to get your air intake point AWAY FROM (a la "hardcore intake") or IN FRONT OF (a la Svede or Vararam) the radiator to take in "cold" air, which is really just air that's not as smoking hot as the radiator and rest of the engine bay. THAT should be your goal. Why would you want to suck in hot engine bay air anyway . . .
2004 PBM M6|109K Miles|Work Commuter
WCS Flat Splitter|Painted Shifter Knob|PDed Lugnut Caps|Llumar 26% Tint
NGK TR5IX|MSD 8mm|180 T-stat + TB bypass|Svede OTRCAI + Omega
Lovells Front RR Bushings + Strut Mounts|Lovells 0-Drop Springs|KYB Shocks/Struts
05/06 Calipers|DBA Standard S/D Rotors|Hawk PC Pads
Kooks SS Headers + O/R Mid-pipes|Stock Asymmetric Mufflers
HSC Stock Height Motor Mounts
Torco RGO|ATE Super Blue Brake/Clutch
Old 01-06-2013, 03:36 PM   #13
superchargedgp
The Grinch
superchargedgp's Avatar
Other Holden/HSV
why dont you just mount the filter directly onto the throttle body. ram air bro
2015 KIA SPORTAGE
Old 01-06-2013, 04:07 PM   #14
xtaspeed05
Abracadabra Holmes
xtaspeed05's Avatar
Thank you very very much halfwayoutthedoor !! This picture really brings out the mbm imo.
Old 01-07-2013, 03:26 AM   #15
87LC2
I got sumpin on mah face?
87LC2's Avatar
Cold air's out front, brah.
Old 01-07-2013, 04:24 AM   #16
GTO Drifter
DO A BARREL ROLL!!!!!
GTO Drifter's Avatar
welcome to sickville, population ^^^this guy
http://www.
Mod List: ..... Driver
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme. These elements are natural to the process of writing, and will only add to the overall beauty of the post.
Old 01-07-2013, 05:25 AM   #17
CrAzYGOAT
nothing witty today
CrAzYGOAT's Avatar
LOL
STOLEN
2004 PBM LS1 M6
Kooks Headers & Street Screamers - Monster stage 1 with tick performance master
Hinson engine mounts - speed bleeder - ASP UD pulley - 3.91 w/eaton tru trac and Harrop cover - BP shifter
RAMJET otrcai - LSXr/102 Big Mouth - Billet Rails - custom coolant crossover
BC coilovers, 19" TSW Cadwells 45mm on f-245/35 r-285/35 - James Biz catch can
JB blacked out arrows and side badges - Mav man spolier and diffuser - Custom suede interior and trim
Old 01-07-2013, 06:11 AM   #18
05 red tomcat
bolt-ons =11.52
05 red tomcat's Avatar
WELL my cai is a true power builder, true ram air ,but it goes against everyones best guess 3 90 deg turns and 5 feet long.
but my car does hold the bolt on record ,so im doing something right.
05 torred red black int auto
(1 of 400)
ngk plugs tr55 ,kn drop in ,drag bags
slp loud mouth II cat back
b&m trans cooler
homemade cai 4" and lots of (un) bolt ons
hotchkis bars
harrop x-member bushings,and harrop cover
noltec bushings every where else
driveshaft shop one piece alumnium
kooks 1 7/8s headers
fti 3600 stall , fast 92 intake
tuned by mayhem motorsports in raligh nc
Old 01-07-2013, 06:26 AM   #19
xtaspeed05
Abracadabra Holmes
xtaspeed05's Avatar
Any pics posted of it ?
Old 01-07-2013, 08:49 AM   #20
05 red tomcat
bolt-ons =11.52
no most of it is hidden. it is a hard core style ,but goes a lot further.
4" pvc ,i only use the full system at the track ( no filter )
Old 01-07-2013, 09:34 AM   #21
batboy
cave dweller
batboy's Avatar
A homemade CAI is doable, you just need to make it so you don't pull in hot air. Do a search on "hardcore CAI" and you'll find examples of how to route air from outside the engine compartment. I did a homemade 4" CAI borrowing SNL's design and utilized a LPE heatshield I had leftover. Since the pic was taken, I have insulated and sealed the heatshield better. Again, I'm pulling in outside air because hot air causes the IAT and ECU to pull timing to compensate for the less dense air charge.
Old 01-07-2013, 09:44 AM   #22
JNR
Quidditas
JNR's Avatar
PVC is not something you want to use (gets brittle, emits gasses), but ABS is alright. Being it's a non-pressure application you may be alright, but don't ever use it under pressure, even with the low psi the FI systems produce on these cars.
I know people will say they've done it and it's alright and all, but it is not a good idea, fwiw.
2004 Pontiac GTO - Sold
2007 Cadillac CTS-V - Sold
2006 Pontiac GTO - Sold
1992 Mitsubishi Galant VR4
1971 Chevy Malibu "383"
Old 01-08-2013, 04:22 PM   #23
Audacious Nick
Send Nudes
If you have a k&n, you can also cut a hole in the metal below the filter, then use some duct hosing and route it up to the hole, and have the other end below the car, angled so it routes the air into it. This would bring cooler air up into the filter area, without the extra bends.
Old 01-08-2013, 04:49 PM   #24
mopardakota287
mopardakota287's Avatar
Originally Posted by MuhThugga...View Post
The 2010 GT owners got 04 GTOed big time.
Old 01-08-2013, 07:49 PM   #25
DangerNoodle
The battle of wits has begun.
DangerNoodle's Avatar
Really? No homemade C6 intake love?
Define bad idea.
Vararam with no heat shield = bad idea
Just do as I've done, hack up a c6 intake, slap it on, and be done with it
Ha ha! You fool! You fell victim to one of the classic blunders - The most famous of which is "never get involved in a land war in Asia" - but only slightly less well-known is this: "Never go in against a Sicilian when death is on the line"! Ha ha ha ha ha ha ha! Ha ha ha ha ha ha ha! Ha ha ha...
Old 01-08-2013, 08:12 PM   #26
ಠ_ಠ
^^^ this!
Old 01-08-2013, 08:51 PM   #27
04QSMGoat
04QSMGoat's Avatar
Define bad idea.
I didn't mention yours because IIRC you have a shorter radiator that allowed you to do this in the first place
Old 01-13-2013, 09:51 AM   #28
ls1fan74
Totally Registered User
ls1fan74's Avatar
Maybe he meant over the radiator, and cutting or eliminating the radiator shroud, kind of like the Svede?
editL Just saw OP has an 06, not sure how different the cover is from the 2004
Old 01-13-2013, 04:24 PM   #29
DangerNoodle
What you mention is not detailed enough. Figure I'ld give you a serious answer.
If you ran a straight tube directly off the intake, it could only be as long as 5 inches before it hit the hood/radiator. You don't want the MAF being TOO close to the throttle body unless you plan on a different type of MAF or speed density tune.
Also not many filters / or piping get narrow enough to fit between the hood and the radiator. Attaching a filter before the radiator for a "short air intake" is pointless unless you develop a way to prevent the filter from sucking in the hot engine air.
The goal is to get air from outside the engine bay hence "Svede intake" is amongst the best design. If you want to spend alot of time building your own intake to simply say you built your own (as I've done), focus on how to get an intake to get past the radiator.
Things to remember when building your own intake:
1. bends restrict airflow
The less bends / elbows, the better
2. "Cold Air" Simply means air that is not heated by the engine heat. "Cold air is more dense than hot air hence Cold air = more power.
3. Regardless of what air you have the engine sucking in, the IAT (intake air temperature) sensor needs to read what temperature that air is or it will tell your motor to reduce timing when it shouldn't resulting in a loss of power. (Or if you simply relocate the sensor and/or by-pass it so it reads cold air constantly, then the computer won't compensate for the air temperature changes as you drive it and it won't reduce timing on hot days and you'll be on here later crying about how your engine blew up.)
Achieve those 3 goals and people will agree / approve of your design.
4. Is form but that comes last. Function > Form to most, unless you have the cash to spend.
Best of luck!
Here's an example of the intake I built.
Old 01-13-2013, 06:27 PM   #30
Ironmn715
What is the filter number you are using here? I want to fab my own out of some 321 SS sheet I have kicking around.
'Moe
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
