LS3 conversion low dyno #'s track times......... - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > LS1/LS2 Engine Tech
Old 02-02-2013, 10:52 AM   #1
morris05GTO
morris05GTO's Avatar
Starting a new thread from my last 1, the ls3 conversion check list. Well as in the last thread i had everything installed and got dynoed and came out upset with the #'s. 422rwhp/370rwtq. Went to the track last night and ran
1/4-12.0 at 114mph 1.7 60'.......did it 3 times in a row. Im kinda happy that i ran my fastest time yet but also dissapointed that its not where im suppose to be with my new mods. Was hoping mid-high 11's. My trap speed is still the same as my last setup so i think im losing topend power somewhere. Ill post the dyno sheet and my track slip...............help diagnose the problem
05 PBM A4/3.91's/EDC LS3 manifold/LS3heads ported/EDC custom cam/Vararam/SLP LT's/Yank 3600/Custom 3in dual SLP LM1/422rwhp370rwtq
1/4- 12.0
60'- 1.74
trap- 114mph
Old 02-02-2013, 10:55 AM   #2
tuboy19
tuboy19's Avatar
Stock injectors? What's the injector duty cycle?
Angelique- 2004 PBM/Black M6 - 6000k HID Lows, 3000k HID fogs, LS7 Clutch, Pacesetter LT's w/catless mids, MSD Wires, BC coilovers, 05/06 Brakes, EBC Red Stuff, Russel SS lines, Custom Catback, 232/232 .614/.614 114LSA Cam, AI 799's, Svede, Ported FAST 92mm, FAST 92mm TB, PSI Springs, 60lb injectors, SLP UDP, 18" VMR VB3's, Tuned by andrewzpsu at CSP
463whp/411wtq
2008 Corvette MN6 - 416 LS3, A&A kit V3 Si 3.4" pulley, 232/238 Cam, Alky Control Meth Kit, RXT Clutch 707whp/670wtq
Old 02-02-2013, 11:09 AM   #3
batboy
cave dweller
batboy's Avatar
So, you went from a LS2 6.0 to a LS3 6.2 and are wondering why you don't have a John Force timeslip? Which MAF are you using and probably more importantly, did you have it retuned?
2004 torrid red with red interior A4 GTO (1 of 499)
TR-230/236 cam/TEA ported Trick Flow 215 heads/4" CAI/100mm MAF/ported FAST 90/Kooks/Magnaflow
Performabuilt trans/3200 stall/Truetrac/Gforce1320 half shafts, stubs, CF driveshaft/SSR wheels/SNL tune
Old 02-02-2013, 11:18 AM   #4
high school goat
Retarded Spark
high school goat's Avatar
Send a message via AIM to high school goat
I am assuming he means LS3 top end, and his SIG says he has a custom cam.
SOLD
Old 02-02-2013, 11:37 AM   #5
batboy
cave dweller
batboy's Avatar
Ok, that makes more sense. The LS3 heads aren't the best on a 4" bore, too much valve shrouding. They work better on larger bore motors. Even then, they have big heavy valves. What compression ratio are you using or in other words, did you do any milling?
Old 02-02-2013, 11:45 AM   #6
Phantom04M6
MMOB
Phantom04M6's Avatar
Seems slow for a H/C LS2. I have non-ported stock 243's from an 06 GTO with a cam and ran 11.7 @ 122 with 1.7 60'.
Sent from AutoGuide.com Free App
USAF
14 Mustang GT M6: 5.0, Stock
04 PBM M6: LS6, SS OTRCAI, TQ V3, HE rad, Kooks 1 3/4, LM1, Spec3, GMM Race, 3.91's, GForce AWH Axle, DSS 1-piece, Pedders Struts/20mm drop springs, Drag Bags, 06 Tails.
Tuned by CSP - 411/380
PB: 11.7 @ 122, 1.7 60'
Wife's Car: 06 WRX - 20G-XT, FMIC, TBE, PPG'd. 383/365 (20psi)
DD: 07 Cobalt SS - Stock LSJ w/BW S252ET,FMIC.
Old 02-02-2013, 11:46 AM   #7
morris05GTO
They are the street/strip heads from ed curtis, i wanted them milled not sure if he did or not. And yes its a LS3 top end, ported manifold/ported heads. Pretty much all ED Curtis work on top end, still have stock TB and maf sensor from ls2. Im trying to put up the pics but the sight wont let me upload for some reason
Old 02-02-2013, 11:50 AM   #8
morris05GTO
LS3 injectors 42#
Old 02-02-2013, 12:32 PM   #9
6point0 goat
Yes, I'm a Registered User...
6point0 goat's Avatar
Something is definitely off man, how big is your cam? What kind of head gasket did you use? Whats was your AFR? Any idea how much timing your tune is allowing?
We have near identical setups so we should be in the ballpark of each others numbers.....
Mikayla ~ (adopted 8/9/09--stock) 05' A4 PBM Stock 18s (1 of 136)
Go: |LY6 403ci|Twin 6467 Comp Turbos (oilless)|MVB 4L80e|
Show: |6000k Lows/Fogs|Weld RTS's|CV8-R Tails|Tinted Markers|PBM Valance|Debadged|Adams|
Handling: |Megan Racing|Hotchkis|Pedders|Lovells|Stoptech|iRotors|M ickey Thompsons|
1/4 mile: 11.3@134 2.1 60'
"Horsepower sells cars, Torque wins races"-Caroll Shelby
Old 02-02-2013, 12:35 PM   #10
george g
george g's Avatar
Post your dyno sheet.
mods=408 iron block,SDPC cnced ls3 heads,11.1 comp.,vic. jr. intake with a 4150 tb., 231/242 cam,pacesetter lts and a Complete Street Performance tune and an A_VAS build. (506/468 old set-up with a few problems.New numbers to come.)
Old 02-02-2013, 12:39 PM   #11
batboy
cave dweller
batboy's Avatar
Does your tuner know how to tune a LS3 MAF? I have a LS1 with ported 243 heads, 230/236 cam, and full bolt-ons which made 430 hp (stalled A4 like you). A 100mm MAF and 4" air intake made 23 hp and 18 tq.
Old 02-02-2013, 12:59 PM   #12
randy555
>__<
randy555's Avatar
Send a message via AIM to randy555
LS3 heads dont seem to make the best numbers on LS2 blocks. Take me for example. Bought the best LS3 heads you can buy with a ported L76 intake and a Ed C cam and only made 510/468. I see guys making more with the cathedral port Trickflows. Now my 402 with LS3 heads is making more than most 402's but the $/HP ratio is low.
Old 02-02-2013, 01:14 PM   #13
dyno junkie
dyno junkie's Avatar
Monaro CV8
Dyno numbers seem about right, our LS3 only made 428rwhp on a DynoJet 248C.
But your track time is way off!
2001 Monaro CV8 LS3
11.089seconds
122.78mph
Old 02-02-2013, 01:43 PM   #14
morris05GTO
231/240 617/610 cam, tune is good. Forgot which head gasket my mechanic used
Old 02-02-2013, 01:45 PM   #15
morris05GTO
Im trying to post it but the website isnt allowing it at the time for some reason...........when you see the sheet youll see the hp line going up and then taking a dip down around 5000rpms and going back up around 5500 rpms. Somethin with the locking and unlocking on convertor
Old 02-02-2013, 01:50 PM   #16
TheElementalCashew
Chevy tings
TheElementalCashew's Avatar
You can email it to me and I'll post it if you like
2017 Camaro ZL1, Nightfall Gray Metallic
2006 GTO: Sold
LS3 Heads/ported intake/ported TB, FTI StreetBeast cam, Lunati lifters/springs, Svede, Kooks Stepped LTs, Kooks 3" StreetScreamer.
Billet Pro, Tick Level 2, Monster LT1-S, Gforce CF driveshaft, TrueTrac w/3.91s and Harrop, Gforce Level 2 axles and stubs.
BC Coilovers front, Kollar/Koni rear, Pedders sway bars, Fast Ratio Steering Rack, Pedders and Kollar bushings, CCW SP500s.
Jamesbiz, Maverickman, Bohnman, various Monaro pieces.
Old 02-02-2013, 01:53 PM   #17
EDC
The stick guy -
LS1GTO.com Sponsor
EDC's Avatar
I went 11.70's at 114 MPH so it's not working on the front half of the track. Something is amiss. Email me the dyno sheets and the fuel curve.
Ed
Your number one source for custom designed camshafts, valvetrain and cylinder head combinations
"Quality is not expensive - It's PRICELESS"
Old 02-02-2013, 01:57 PM   #18
Jaime Lannister
Jaime Lannister's Avatar
With a 1.7 60', his ET matches his trap speed pretty dead nuts IMO.
LS3 heads are just not that great on LS2 blocks IMO.
'99 FRC
No longer wanting to light the car on fire
Old 02-02-2013, 02:02 PM   #19
morris05GTO
Ed
email sent
Old 02-02-2013, 02:10 PM   #20
TheElementalCashew
Chevy tings
Old 02-02-2013, 02:16 PM   #21
morris05GTO
^^ thanks man
Old 02-02-2013, 02:56 PM   #22
GTOROB
GTOROB's Avatar
Yep,seen too many LS3 heads on LS2 blocks with poor dyno numbers to think otherwise.
LS3 416 stroker 523/507
A_VAS built shortblock
Tune by Andrew at CSP
Old 02-02-2013, 03:07 PM   #23
batboy
cave dweller
batboy's Avatar
I would not put a lot of faith in that dyno pass. Surely you have more than one and hopefully a clean pass. I'm not seeing AFR? Dynojet huh and STD not SAE? Wow, something ain't right. On the other hand, low gears do dyno a little low.
I've seen time after time catherdral heads equal or beat L92 heads on a 4" bore. I'm putting down more to the rollers than that with 243 heads and a smaller cam and a LS1.
Old 02-02-2013, 04:09 PM   #24
EDC
The stick guy -
LS1GTO.com Sponsor
EDC's Avatar
OK - if you say so -
Old 02-02-2013, 04:49 PM   #25
AutomaticWpn06
Slow N/A Gto owner
AutomaticWpn06's Avatar
Send a message via AIM to AutomaticWpn06
Yeah they are just awful......
Op, how is your trans? After my ls3 top end I was only running 11.90's@114. Put a new trans in the car and picked up almost 5 mph in similar conditions.
2006 PBM/Red/A4/17's
1 of 142
LS3 heads/LS2 Portworks LS3 intake/tb/227-235 cam/Kooks LT's/Magnapacks/DMH cut-outs/Svede OTR/FTI 3800/Rossler Terminator 3 4L65/3.90's
11.13@125 1.51 60'
99 GTP
3.4 mps/ZZP 1.0 pcm/4"intake/Plog/3"DP/YT 1.95rr
13.76@98
Originally Posted by ShoddyHog...View Post
Getting the right cam the first time is pretty goddamn boring. Ask SK360...he'll set your ass straight.
l
Old 02-02-2013, 06:06 PM   #26
bozzhawg
LEGAL USER
bozzhawg's Avatar
LS3 valves have the lighter ones haas on the intake.
Its not that LS3 heads aren't best, you just have to know what you are doing. The margin of error is greater especially when understanding how the valve events work with the function and design of the valves and port of the LS3 head.
You cannot just grab a cam that you saw Joe Blow run or some cam guesser who runs a few cam designs on his desktop dyno and think that the combination is going to work. If you want that you can just order a cam from Tick's new cam guru Pat G Jr.
I find that only people talking about LS3 heads are crap are the people who have slow cars or cannot make power with them.
Old 02-02-2013, 07:06 PM   #27
Jaime Lannister
They're not awful, but they aren't as good as a ported cathedral or aftermarket head for an LS2, sorry.
With that being said, I would still expect more than 420 hp and a 114 mph trap, so maybe there is an install or tune issue going on here.
Old 02-02-2013, 07:42 PM   #28
AutomaticWpn06
Slow N/A Gto owner
I'll give you that.
Old 02-02-2013, 08:05 PM   #29
xtaspeed05
Abracadabra Holmes
xtaspeed05's Avatar
I guess I need a driver mod then ...
I agree with the math portion of this statement. His dyno numbers to me seem low but his track times are about on par with the power he is currently making with a full or close to full weight gto. Obviously if he makes the power he was expecting, (450 ish) then he would improve his e.t.'s and be more where he wanted. I see a bunch of low 400rwhp cars on here right in that 11.8-12.2 range with 1.75 to 1.85 60's trapping right about where you did or a touch higher.
2005 gto MBM M6 1 of 566
Stock~315/317~13.35@104.85~2.09 60'
Go Fast-Vararam|Ported Intake & T.b.|Jba shorties w/gutted cats|Tq.V2 cam 113lsa|Asp udp|LS7 clutch||Dyno tuned|420/393
Show-Sap front fascia & grill's|Klearz markers|06 tails|Jhp V1 lip spoiler|18X8.5 ADR's
Best E.T.
1/8 mile~7.74@92.13
1/4 mile~11.99@115.46~1.82 60'on Nitto Dr's~D.A. 250ft.
Best 60ft. 1.78
Curb weight ~ 3620lbs.
'00 540I~14.3@96
Old 02-03-2013, 03:57 AM   #30
dyno junkie
Monaro CV8
Agee about LS3 heads.
Here in Western Australia there are several mid to low 11 second LS3 headed LS2 and at least one 10 second street car with the combo.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
