Check your body control module (BCM) wires, everybody. - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Electronics
Old 08-03-2010, 08:24 AM   #1
NicD
Must go faster...
NicD's Avatar
Alright so in the last two weeks I have seen three cases locally where the BCM fuse popped, the car just died, or things like windows/door locks randomly would not work and then work again. Looking around here there are several threads on it and it's found to be the BCM wiring harness that rubs against the metal support behind the glove box and many were saying it's only an 04 issue but it's every year. The first two that I heard of locally were 05-06 cars and I just checked mine and it was on it's way with a few of the wires being visible and damn near rubbed through already. Below are a few blurry pictures showing the harness and what I did to remedy it. If it hasn't happened to you I GUARANTEE IT WILL in the future so fix it now before you are buying a new BCM, etc.
What I saw when I pulled the glove box.
What I saw when I pushed the harness back.
I electrical taped the harness up and cut a length of rubber hose to wrap over it, then zip tied it tight so it won't go anywhere. I also put a few strips of electrical tape over the sharp metal edges of the support bracket that was rubbing it.
http://GoNicD.com
2017 ZL1 | 2016 C7 Z06 | 2009 C6 Z06 | 2000 Turbo Camaro | 1994 GT - The LS-stang | 2010 SSV Tahoe
Old 08-03-2010, 08:29 AM   #2
andrewzpsu
Complete Street Performance
LS1GTO.com Sponsor
andrewzpsu's Avatar
Send a message via AIM to andrewzpsu
We put foam padding on the sharp metal edge.
Funny though. Since this was the first experience with it we didn't check the BCM fuse at first. We were looking at a ton of options, including bad keys lol. Checked every other fuse, but not the BCM haha.
Old 08-03-2010, 08:35 AM   #3
06SpiceyGoat
06SpiceyGoat's Avatar
Agreed 110%.. i had massive problems from this stupid thing... heres my angle of it from when i posted a few months ago...
2006 Spice Red Metallic M6 : 1 of 501 : Custom Flat Splitter : 6000k Low HID's : 35% Tint All Around : Custom Stock Floormats : K&N FIPK Intake : Kooks Afterburner Axleback : PS Longtubes w/ Catless Mids : Complete Street Tune by Andrewzpsu : Cquence Slotted/Drilled Rotors w/ C5 Pads : GForce 1320 Level 1 Rear : Red/Black Interior Swap : Pioneer Avic D3
Old 08-03-2010, 08:37 AM   #4
ls2weber
36 35 15.5 121 45 9.9
ls2weber's Avatar
Send a message via Yahoo to ls2weber
interesting I will check this out today, thanks for the input
06 QSM
1 OF 123
Old 08-03-2010, 08:48 AM   #5
LS2-GTO
1 of 40,757
LS2-GTO's Avatar
Thanks for the heads up.
Will take a look before problems start happening.
Old 08-03-2010, 08:51 AM   #6
slow
Send a message via AIM to slow
Thanks for the heads up and pictures. I will check today.
Ryan
2006 GTO QSM/M6/Black Interior.
Sold: 1998 WS6 M6 #370 Bright Red
Old 08-03-2010, 08:58 AM   #7
ryantown
Get offa ma boxcar
ryantown's Avatar
I would like to check this too. I haven't gone to look yet, but what is needed to pull the glove box? Does the tray just slide out or does the door have to come off? Screws and/or clips? Thanks.
A bird in the grill is worth two in the bush."
Old 08-03-2010, 09:30 AM   #8
Crisis
Crisis's Avatar
Other symptoms of this is gauge cluster faults and ABS warnings, TCS warnings, fuel gauge errors, AC turning on and off etc. My BCM was replaced by the previous owner (bought the car 2008) but the problem was never fixed. I only had issues in hot weather. I fixed it myself, went to the dealer 3 times and they could not figure it out.
I've commented on this and posted pictures like other have also... This is not a new problem, but there is no 'definitive' write-up (this one is quite good) to maybe add to the KB??
1989 Firebird Formula LM7, Koni suspension, 6 point cage, a lot of small stuff... On going project
2001 Opel Omega 2001 2.6l - "big block"
2006 GTO PBM M6 -Sold/traded- Will be missed
2000 Silverado 5.3 - Needs a paint job
2014 SS PBM
Old 08-03-2010, 09:33 AM   #9
Fox Mulder
Alien Moderator
Fox Mulder's Avatar
This has been a known issue for a long time. More common on the '04s but does happen on '05s and '06s. Definitely the cause of many strange and intermittent symptoms and no doubt a few unnecessary BCM replacements. There have actually been a few fires from this problem with at least one or two total losses. Whether you get just a blown fuse, odd symptoms, or a raging inferno will depend on what wires are cut into and how often and how long they make contact with the frame.
05 GTO/ '15 WRX/ '02 WRX
Old 08-03-2010, 09:41 AM   #10
NicD
Must go faster...
NicD's Avatar
Correct, this is not a new problem and is a known issue but I can't believe there isn't a sticky about this when it WILL happen to every 04-06 GTO out there in due time. It's not a year issue, it's a mileage issue.
Old 08-03-2010, 09:41 AM   #11
87LC2
1LE
87LC2's Avatar
Other Holden/HSV
Nice write up!
Pics always help.
2018 1SS 1LE
Old 08-03-2010, 09:54 AM   #12
Gagtoe
Gagtoe's Avatar
I've added it to the sticky that will eventually be a concentrated list of important threads. Thanks for the pictures to go with the warning.
Originally Posted by mistermike...View Post
On an internet forum, the written word is the sole means by which intelligence can be judged. If you butcher the language, particularly with ricer textspeak, you are, in my estimation, not worth engaging. If I can discourage you from being here, I will.
Originally Posted by Leavehard...View Post
Thy rod and thy staff... they comfort him.
Old 08-03-2010, 09:57 AM   #13
bnvus
What the....
bnvus's Avatar
What is the average miles that this issue is being seen?
2005 Phantom Black M6 GTO
Built 416 by G-Engines
1996 BBB Impala SS
[email protected]
Old 08-03-2010, 10:09 AM   #14
Napalm
Have Bar, Will Travel
Napalm's Avatar
Other Holden/HSV
Send a message via Yahoo to Napalm
Where is this exacly and what do you have to do to get to it?
Since Guns Kill People, Spoons Cause Diabetes.
Old 08-03-2010, 10:11 AM   #15
Fox Mulder
Alien Moderator
Fox Mulder's Avatar
It's not really a mileage issue, it's more of a sloppy build issue. It falls into the same category with the fuel lines and vacuum hoses that rub under the hood- wiring and plumbing not secured and dressed properly to avoid damage from contact and stress. These problems were first observed not long after the first Goats hit the road over here, when they didn't have a lot of miles on them. IMO it has a lot to do with things that were relocated or modified for the RHD-to-LHD conversion, some of the final detail work was half-assed.
To really get a good look at the BCM harness you should remove the glove box.
Old 08-03-2010, 10:28 AM   #16
Napalm
Napalm's Avatar
Other Holden/HSV
So if a car has been daily driven for most of its life, this would have come up before?
I don't have my book for somereason. How do you remove the glove box?
Old 08-03-2010, 10:30 AM   #17
NicD
Must go faster...
NicD's Avatar
As these cars get more miles on them it's going to take it's toll. There isn't a single GTO I have seen that after pulling the glove box hasn't had some rubbing there. Obviously some are worse than others but as the miles pile up it's going to eventually rub through. Half-assed engineering that should have been addressed, yes but it is going to become more of an issue with the mileage these cars are starting to get to now.
Old 08-03-2010, 10:47 AM   #18
Napalm
Napalm's Avatar
Other Holden/HSV
I was partly kidding. Has anyone had to re-work the harness? IE patch some wires and re seal.
Old 08-03-2010, 10:53 AM   #19
Napalm
Napalm's Avatar
Other Holden/HSV
I just saw this thread. Never heard of this before and I have a random ABS fault showing up.
I am now concerned that this might be my issue?
And if there is a worn wire in the harnes, can I patch it or will I have to replace it. I bet that requires pulling apart the whole damn interior
Old 08-03-2010, 10:56 AM   #20
Axe Man
Spirit of Detroit
Axe Man's Avatar
Good write up! I am going to check mine this weekend!
"Spirit Of Detroit"
1968 Retro style 06-M6 QSM 18 inch wheels.
Modified.
Old 08-03-2010, 11:03 AM   #21
DEyellowgoat
i hv a sexywife
DEyellowgoat's Avatar
I havent seen this before and being I just rolled over 115k, I went out to check. Never realize glovebox just popped out, lol. Im in good shape! I could put my fingers over the support brace and the harness barely touched my fingers. No signs of rubbing either.
04 YellowJacket M6
410rwhp 386rwtq
166k miles & counting
Capitol City GTOs
R.I.P. Jason, We'll Miss You
CSP tune|KooksSS|243s|224/231|Harland Sharp|SLP 160*/UDP/LM1|p&p TB|Svede Speed
B&M w/LSS|Monster Level 3
|BMR 1pc driveshaft|GForce LVL1 drivetrain|3.70s
Pedders
HIDs|tinted tails&side markers|5% tint|18" VMRs matte black
All made possible with the loving support of my wife, Linda(avatar)
Old 08-03-2010, 11:12 AM   #22
Napalm
Napalm's Avatar
Other Holden/HSV
Reading this, my intermitent ABS fault and failure warnings (which occur when I hit a bump on that side of the car), has me worried now.
I can just picture the wires half worn through and laid open. prolly 22 ga too.
Old 08-03-2010, 11:21 AM   #23
JoeyElbows
WANTED ALIVE!!!!
JoeyElbows's Avatar
Send a message via AIM to JoeyElbows
this is probably why my airbag light keeps coming back on after they clear the code. Gonna check it out.
Bad enough to uppercut a giraffe! 04M6YJ Mods: 3.91's and truetrac,LPE CAI, American Racing headers, Corsa Sport Exhaust,GT2-3 cam, Harland Rockers,Patriot Gold springs, pedders xa coilovers,monster stage 3 clutch,160 Stat, DDM 35W 5000K fog 55w lows, Tuned By Tom 12.18 at 114.35 1.78 60' 385HP/380TQ. 1-28-12RIP honeybee
Old 08-03-2010, 12:09 PM   #24
ryantown
Get offa ma boxcar
ryantown's Avatar
https://www.ls1gto.com/forums/showthr...lovebox+remove I found this on how to remove it unless anyone has any better input.
Old 08-03-2010, 02:51 PM   #25
JoeCiv
good heads up. went out and checked and sure enough the fabric was cut through and 2 wires were next. I have only about 20k on my 05. this should def be a sticky.
-Joe
Old 08-03-2010, 02:58 PM   #26
sergo
lost soul
sergo's Avatar
thanks for the info! i'll be checking mine when i get home.
gone but not forgotten
Old 08-03-2010, 04:59 PM   #27
ryantown
Get offa ma boxcar
ryantown's Avatar
I have been trying to figure out how to remove the glove box door without breaking something (the turned up a lot of people with sagging glove boxes). Depending on your size and determination, you should be able to slide up underneath the glove box and take a look/fix. I could see what looked like an impression on the cloth harness covering made by the metal plate, so I shoved some foam up in there between the harness and the plate.
Here are two pictures looking up at the harness from underneath, with the glove box door still in place. Before and after.
Old 08-03-2010, 05:02 PM   #28
BVGTO
BVGTO's Avatar
Great info to have! I'll be checking mine tomorrow for sure.
Old 08-03-2010, 05:34 PM   #29
whaler01
I'm the damn paterfamilias
whaler01's Avatar
I get that same ABS Fault once in a while also. Sometimes I get a brake shutter problem and never the fault, and usually get the fault when just sitting still. Guess I'll be checking this tomorrow.
_________________________________
2005 GTO QSM/Black M6 - 19" G8 GT Wheels - Corsa Sport - Volant CAI - MGW-P Shifter
Parts waiting install - King Springs
1970 Chevy Custom SWB C-10
Lowered, Foose Legend Wheels 350/350
Sic vis pacem para bellum
Sempre Avanti
Originally Posted by Konnie the Goat...View Post
I've got internet porn and a gay friend
Old 08-03-2010, 05:45 PM   #30
mistermike
mistermike's Avatar
GKPW52
Thanks, Nic!
http://i67.photobucket.com/albums/h306/MikeStainlessWorks/SigPicAniSm.gif
World's First Twin Screw Pontiac GTO
Blown H/C 408 and other stuff. Billet tires. Plasti Dip tints. Stage 3 keyboard. /////.
2017 Chevy SS w/ dead hooker in spacious trunk
2017 Cruze diesel A9 MPG queen. Rollin coal w / my balls in spacious glove compartment.
fquick
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
You may post new threads
You may post replies
BB code is On
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
