Rusty steering fluid tubes - LS1GTO.com Forums
Old 04-13-2019, 02:34 PM   #1
qwicksilver
I just got under the car for the 1st time to do an oil change and saw what looks like rusted metal portion of the power steering fluid hose. First pic is the rear of the pan and 2nd shot is at the front of the pan.
Will probably get the ACDelco unit.
anything I need to know? Any tricks to getting them out/in? before I change these?
ID:	492219   Click image for larger version
Old 04-14-2019, 03:30 PM   #2
qwicksilver
Rockauto has a gates for $60 and an ACDelco for $84. Just wondering if the ACDelco is worth it now that they make mostly everything in China.
Old 04-14-2019, 05:06 PM   #3
Nothubertjfarnsworth
ಠ_ಠ
Nothubertjfarnsworth's Avatar
they're probably both the exact same part in different boxes.
get the cheaper one.
Old 04-14-2019, 05:56 PM   #4
lejambcr
My other car has wings
lejambcr's Avatar
Not sure you want to make the additional investment or go thru the extra effort but I just replaced my power steering hard lines with braided steel and Russell fittings. Looks much better and will make dropping the steering rack much less of a mess in the future if need be. Not to mention getting rid of that stupid high pressure line that goes from the pump...over to the passenger side....and then back to the rack on the driver side all because some engineer was too lazy to design a completely new line for left side driver. Would have been 4 feet shorter and gone straight aft from the pump to the rack instead of circling around the bottom of the engine and attaching in tough to get to places on the cradle.
2006 M6 BOM 39K miles
Kooks Long Tubes, catted mids thru Magnaflow Mufflers
Cam Motion Stage 2 Cam 0.553" lift, 214/220 at 0.050"
XAir OTRCAI, FAST 102 Intake
Monster Level 2 Clutch Package, MGW-P shifter
Carbon Fiber 1 piece DSS Driveshaft
Gforce Anti-Wheel Hop Axles, Gforce Heavy Duty Differential Mount Bracket
409 RWT and 407 RWHP
1/8 mile best: 2.04(60'), 5.61(330'), 8.49(660'), street tires and 2500' density altitude, lifting between gears
Old 04-14-2019, 08:18 PM   #5
ಠ_ಠ
did you make your own hoses or bought hoses that were pre-made?
Old 04-15-2019, 02:48 AM   #6
lejambcr
lejambcr's Avatar
I made them. Bought all the fittings and 10 feet of braided steel line from summit. Cut them to the proper length and assembled the high pressure fittings.
Old 04-15-2019, 08:14 AM   #7
SilverBullet19
05 Looks, 04 Slow
Typically I stick to OEM (unless I'm modding), but Gates is good quality and I have no qualms about using those parts.
DD: 2015 Toyota Tacoma TRD Sport
Lady's ride: 2016 VW Tiguan
Pride and Joy: 04 QSM/red M6 (1 of 344)
Retired for DD duties 3/23/15 at 120,600
Full JBA exhaust with shorties and catted mids, Griffin radiator, Lovell's Shocks, King HHD springs (1 inch drop front, 1/2 inch rear), various whiteline poly bushings, DSS 1 piece, Hyperblack 19" VMR VB3's, 05 hood, 05 bumper, Mavman color matched spoiler
Old 04-15-2019, 08:45 AM   #8
qwicksilver
Is there a how to do it write up?
Is there a write up how to do it somewhere on the site? I would love to do this but not sure if I have the skills.
Old 04-15-2019, 08:55 AM   #9
Gimpy1
I Googled how to make HP lines, it doesn't seem too hard nor does it appear that a bunch of tools a needed other than a vise and a cable cutter.
Old 04-15-2019, 09:19 AM   #10
lejambcr
lejambcr's Avatar
I used my dremel with a cutoff wheel to cut the hoses to length. It gives a nice clean cut of the steel strands. The clean cut is important to making the assembly of the high pressure fittings easy. Just clean them good after the cut and use a little motor oil on the compression fitting threads. Really is no big deal. Practice on the low pressure hoses first then you'll be an expert when you tackle the high pressure line from the pump to the rack.
Old 04-15-2019, 09:27 AM   #11
lejambcr
lejambcr's Avatar
Here is a picture of the new lines installed in my 2006. Zoom in for a good view. I'll admit getting the old lines out was easy with the motor out but the reinstall of the braided lines is not tough with the engine in place.
Old 04-15-2019, 09:35 AM   #12
qwicksilver
How?
Would you happen to have a total parts list for the high pressure hose replacement with stainless? Did you route the hose the same way as the stock hose? Did you follow any special procedure to bleed the steering fluid system?
I assume once you disconnect the old lines they will drain out on the floor. Sorry for all the questions
Old 04-15-2019, 09:38 AM   #13
qwicksilver
Which one is high pressure?
Is the line on top the high pressure?
Old 04-15-2019, 10:09 AM   #14
lejambcr
lejambcr's Avatar
I can get the parts list posted tonight when I get home from work. You can also do some searching on this forum. That's where I got my list. Yes, the high pressure line is the top one on the rack. The low pressure line follows the oem routing over to near the right bottom of the radiator. The high pressure line is a direct shot from the pump back to the rack instead of the big path around the engine compartment like oem. I didn't lose much fluid at all. You make up the fittings for the rack ends first. Then just tie wrap them close to their installed location. Then temporarily route them to get your length measurement. Then when the hose ends are done route the hoses again and install the rack fittings first. No bleeding was necessary I only lost about 1/2 quart.
Old 04-15-2019, 10:44 AM   #15
lejambcr
lejambcr's Avatar
Meant to say lost 1/2 pint. I pinched the old lines so they wouldn't leak while I installed the new lines on the rack. The high pressure on the pump won't lose any fluid. The low pressure line connection on the right front does lose a little fluid if your not quick with the reconnect. Did not have to bleed.
Old 04-15-2019, 07:08 PM   #16
lejambcr
lejambcr's Avatar
Here's what I purchased from summit to do the braided steel power steering line conversion
2 each Russell 648060 16mmx1.5 o-ring fittings 1 for the top of the rack, the other for the top of the pump
1 each Russell 648080 18mmx1.5 o-ring fitting for the bottom rack fitting
2 each Russell 620411 45 degree hose end fittings both for the rack connection
The low pressure connection of the steel braided line on the front right side near the radiator can be secured with a hose clamp
1 each Russell 620421 90 degree hose end fitting for the pump connection
1 each 632620 10 foot AN-6 steel braided power steering flex line
Old 04-16-2019, 04:50 PM   #17
qwicksilver
Awesome info!
This is great. Should be a sticky!! Thanks Lejambcr!!!
Old 04-17-2019, 04:24 AM   #18
Machine2004
Machine04
Machine2004's Avatar
Send a message via AIM to Machine2004
I did the same as lejambcr a couple of years back using these instructions from Blackest SRT Ever
https://www.ls1gto.com/forums/showthread.php?t=442131
Old 04-19-2019, 08:39 AM   #19
qwicksilver
Drop the rack?
After reading this I am wondering if it is necessary to drop the rack if I still have the stock exhaust??
Old 04-19-2019, 11:32 AM   #20
ಠ_ಠ
yeah, that's where i got the idea to do my low pressure lines after the stock ones got fubared.
my high pressure ones are still stock ATM.
Old 04-19-2019, 01:51 PM   #21
lejambcr
lejambcr's Avatar
I did not notice how tight it was with the stock exhaust but with my Kooks long tubes it is not necessary to drop the rack to install the new braided steel lines.
Old 04-20-2019, 10:38 AM   #22
qwicksilver
TY
Thanks again for your patient advice
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Insurance
Log-in
You may post new threads
You may post replies
BB code is On
Similar Threads
Thread Thread Starter Forum Replies Last Post
power steering fluid??? svede1212 Tech Lounge 5 03-27-2006 03:05 AM
Power Steering fluid sabby1225 Tech Lounge 8 02-23-2006 07:56 AM
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
