Planning to do a DIY remote start with an arduino Micro-controller? - LS1GTO.com Forums
Go Back   LS1GTO.com Forums > GTO Tech > Electronics
Old 07-21-2019, 10:15 PM   #1
05silgto
Hello.
Recently I made my own fuel pump speed controller using an arduino board and h-bridge.
Now I am in the planning stage to make my own remote start using a arduino board connected to a Bluetooth module and I'm trying to gather as much info as possible.
Now I understand that in order to keep my stock security system I will need to sacrifice a key fob, which is perfect since my battery on my 3rd key is dead anyway. Based on my research it looks like I just need to solder the key blade portion to the ignition ground, key nub portion to the other ignition wire with a relay which when activated by arduino via remote start will bypass the security system.
I believe I read on another forum that you can access both these wires under the column.
Now, how would I go about staring the car after? I assume I would need to add another relay to make a connection to start the car? Would this be a temporary connection just during the cranking or would in need to be permanent? Also how would I go about turning off the car remotely?
I looked up quite a bit of remote start install threads but they don't really go into much detail about how everything works. Since i'm going to make my own I need to know more info on the exact behavior of the ignition electrical system/how a remote start interacts with the system.
Also I read on another old forum someone stating "One good thing about GTO’s is that it has a safety remote wire that you can connect to your alarm/starter that prevents the car to start in the gear."
That's all that was mentioned about that wire and I was wondering if anyone new more about this mystery wire? My car is a manual but I never leave my car in gear anyway, never had an issue and I have owned this car for over 6 years. Figured I would do it right anyway if I could just in case.
Also I don't care about having to put the key in the ignition after remote start in order to drive. Doors will be locked and this will only be used at home during cold weather. Don't think anyone will bash my windows and steal my car within those 10 min. Plus if I ever have the famous ignition lock cylinder issue this will come in handy for an emergency.
Old 07-22-2019, 05:12 AM   #2
Squag27
If you're going to go through the trouble of cannibalizing a key, why not have VATS tuned out in order to simplify the process? Cool project though.
Old 07-22-2019, 07:23 AM   #3
05silgto
Cause I want to keep my security security system for my ignition so my car is harder to steal. I understand wiring a key in the car makes it easier as well but if you place it in a hard/time consuming place to get to I doubt anyone is going to steal it by hot wiring it vs. towing it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
BB code is On
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
