Car has 15k miles on it, sometimes it will happen after 30 minutes of driving, sometimes I can drive it for 2 hours straight and not have it happen.
Randomly the check engine light will start flashing and there is definately something not right with the car when that happens, feels underpowered, sounds like it's breaking up, a misfire.
Usually after 15-20 seconds, the light will stop flashing and the car will quit acting like it's misfiring terribly, but it has not felt quite right since this first happened 3 days ago.
The last time that it happened, the light was flashing, the car felt like crap, and then all of a sudden the light stayed solid, so I hooked up my scanner and pulled the code, Cylinder 7 Misfire.I
Turned the car off for about 30 minutes, started it again, CEL was off.
It has done it probably 6 times the last couple days, it has never stayed solid again though, blinks for 15-20 seconds, feels like crap, goes away.
Any ideas? I would assume spark plug and/or wire but I haven't had a car that did this randomly, usually when I've had a spark plug/wire go bad it was constant until they were replaced.
Thanks in advance.
