Hi Guys,
I have been learning a lot from all of you and have been having fun with my 06 SRM GTO.
so from my other posts a lot of you know that shortly after I bought the car. I discovered a spun cam bearing.
So Now I am without the ability to drive my newly purchased GTO.
So a quick recovery became a priority.
I found an LS364/450HP crate motor thanks to boost district and started what seamed on the surface as a straight forward swap. (not started yet)
I quickly thought of all the small items that I wanted to get done while it was at it.
The list is huge. so far I have purchased all of the following which is mind numbing after a while (all new parts)
LS7 clutch kit, clutch master cylinder, delco water pump, ls3 intake, fuel rail spacer (so I can reuse my LS2 injectors for now), Hinsen motor mounts, trans mount urathane filler, improved racing oil pan baffle, improved racing pickup tube brace, improved racing oil pan bypass plug, Jegs 4 point steam vent kit, Lucas oil break in oil, mechanical oil pressure guage (to perform preoiling procedure specified by GM, header bolts (ARP), intake bolts, header gaskets, and an MGW-P Short Shifter from Proxes Tuning.
Before this started I had bought a set of wheels for the car, 18" Niche Apex wheels. They were nice but I am not a big
blacked out fan so I stripped the wheels down to bare metal and 3 nights ago I discovered a crack in one of the rears.
Fatal flaw as the car will eventually see some track days. So I called and was able to return the wheels and while I was there I checked out a set of Ace Alloy AFF02 they had in black chrome, one look and I was hooked. So instead of getting my money back I added a little and got some fantastic wheels for the car.
On another front I found a set of Kooks Long Tube Signature Series Headers with the Catted mid pipes for sale at a good price. I made him an offer and it was accepted.
For the chassis I have done the Radius Rod bushings from Whiteline, I have the rear diff bushing filler from white line, Have fresh trans oil, Fresh rear differential oil and friction modifier from Torco, I have already done a driveshaft rebuid kit, and will add all the new bushings as money allows.
I will add some pictures in the next couple days.
