When I update the OS would i have to buy 2 more credits with hp tuner?
I think I did. Been so long now I don't recall. I believe it "sees" it as a whole new car based on the info contained in the OS. Same as if your ECU fried and you had to replace it.When I update the OS would i have to buy 2 more credits with hp tuner?
Not worth it on N/A. Ethanol requires 30% more fuel volume which means bigger pump, injectors and other supporting mods with a tune.I know this thread is fairly old, but I've been thinking about what it would take to make my 06 GTO run on ethanol, and really liked the way you used an original GM sensor that is pretty cheap and wired it in yourself.
Another thing I'm wondering though, with my engine being stock aside from intake and exhaust, are the stock injectors, fuel pump, etc. compatible with ethanol, and would it make sense or have any benefit to do this to a an otherwise stock engine? I know that the higher octane of ethanol potentially allows more spark advance which can gain some power and then there is an in cylinder cooling affect compared to gasoline which potentially allows a bit higher density air in the combustion chamber, but does this amount to noticeable or worthwhile gains on an LS2? I'm not sure if the LS2 is knock limited in stock form to be able to gain from any spark advance with ethanol.
Factory injectors work fine if you haven't gone to a turbo or blower yet, and the stock FP will handle E-85 up to about 450whp.Not worth it on N/A. Ethanol requires 30% more fuel volume which means bigger pump, injectors and other supporting mods with a tune.
If you're running stock injectors to 450whp on e85 then those injectors are going static.Factory injectors work fine if you haven't gone to a turbo or blower yet, and the stock FP will handle E-85 up to about 450whp.
You will definitely need a tune, but I made 30 more hp on E-85 than on 92. No cam, blower, headers etc.
Was a factory stock 06. Had it tuned when I went flex fuel and went from 356 at the tires to 386 on E-85.If you're running stock injectors to 450whp on e85 then those injectors are going static.
I highly doubt the car picked up 30whp NA unless its a stroked high compression (12.5) build.
So?Ethanol requires 30% more fuel volume which means bigger pump, injectors and other supporting mods with a tune.
I've ran stock fuel pumps on E85, they are fine.I know this thread is fairly old, but I've been thinking about what it would take to make my 06 GTO run on ethanol, and really liked the way you used an original GM sensor that is pretty cheap and wired it in yourself.
^ That is some very good motivation to look into it though.Was a factory stock 06. Had it tuned when I went flex fuel and went from 356 at the tires to 386 on E-85.
And 450 hp on E-85 isn't going to make the stock injectors go static. Plain old 93 you can do 550 or so on the stockers without going static.
100% will go static, you are never going to make 550whp on a 33lb injectors safely. A cam only cam is going to have the injectors about safely maxed out (80% DC).Was a factory stock 06. Had it tuned when I went flex fuel and went from 356 at the tires to 386 on E-85.
Livernoise is the one who claims a 50fwhp gain via e85 but they are also taking into account the stock tune compared to a fully tuned vehicle. I bet damn near the same gains could be had with a good tune on 93 if that's the case.Great, I had just about gotten that out of my mind, and there you go guys re-igniting it again. I had a guy at work bring it up to me why I don't make it run on ethanol because he had big gains on an otherwise stock Jeep Wrangler, but I wasn't sure if there would be anything to gain on a stock LS2.
So? Its common sense. The stock components were not designed to support e85. Aside from not producing the volume, they don't have anodized coatings or alcohol compatible seals. Anyone running a stock fuel system with ethanol is taking an unnecessary risk for potential issues down the road.
The factory fuel orings are ethanol compatible. I haven't had any corossion issues due to e85 in the 7 or so years that i've been running it.So? Its common sense. The stock components were not designed to support e85. Aside from not producing the volume, they don't have anodized coatings or alcohol compatible seals. Anyone running a stock fuel system with ethanol is taking an unnecessary risk for potential issues down the road.
Who's ass did you pull the 550hp from? Re-read my post. I said 450100% will go static, you are never going to make 550whp on a 33lb injectors safely. A cam only cam is going to have the injectors about safely maxed out (80% DC).
A stock ls2 vs a tuned on premium LS2 is going to nearly pick up those numbers, the e85 had little if anything to do with it.
They have been running 10% ethanol in fuel since the mid-late 90's when MTBE was banned. Manufacturers have been using ethanol safe components since then.So? Its common sense. The stock components were not designed to support e85. Aside from not producing the volume, they don't have anodized coatings or alcohol compatible seals. Anyone running a stock fuel system with ethanol is taking an unnecessary risk for potential issues down the road.
Exactly. You wont get 50hp from just E85 unless you are running healthy boost levels.Livernoise is the one who claims a 50fwhp gain via e85 but they are also taking into account the stock tune compared to a fully tuned vehicle. I bet damn near the same gains could be had with a good tune on 93 if that's the case.
true, but naturally aspirated direct injection engines get a healthy kick from e85. newer mustangs and LT1 camaros get a nice gain from switching. i forget the typical gains, but they are like 20-30hp iirc.Exactly. You wont get 50hp from just E85 unless you are running healthy boost levels.
You said it....said you can do 550 on stockers on 93Who's ass did you pull the 550hp from? Re-read my post. I said 450
You said it....said you can do 550 on stockers on 93 View attachment 506602
