1 - 7 of 7 Posts
Need A Little Beethoven?
The front is already rolled from the factory. They should fit, the stockers are 8 inches wide with a 48mm offset and 245 width tire, with a 38mm offset you're pushing the wheel 10mm out and then you're adding 10mm worth of width with the tire. I think there would only be a problem if you run a tire with too much sidewall.
multistrada74 said:
hey guys. with an 18x8 with a 38mm off-set, will 255's fit up front with a rolled fender? or is the problem with hitting the strut?
I'm running 18 x 8 / 40mm with 245/40-18s with about a 1/2" drop in front (Pedders Street II).
Plenty of strut clearance but I do get some outside sidewall rubbing during hard cornering - front only.
RIP
I just put some 255/40r17's on front today with a 17x8 40mm offset. I am also running 1.5 degrees of negative camber to help cornering and they are really close to the strut. I am going back to discount tommorow and having them pulled off to see if there is rubbing. If there is off they come and back to the 245/45's. I would rather have a smaller tire that I can set the camber where I want than a wider one where I can't run a lot of camber.
Maggie Powered
I have 255-40-17-yokohama as100 on all 4 with beyern type-5 no clerance prob and has never been aligned
No mo' GTO.
They fit. I've got 255/40/17 with a +37 offset.
Its not a real hemi
Better safe then sorry, I have 255 on the front but Ive only got 17s, use caution.
1 - 7 of 7 Posts
