1 - 20 of 27 Posts
Might wanna knock first...
Little help wheel/tire gurus:
Plan on running 18x9.5 Thruxton TSWs out back, but 18" Nitto DRs are only offered in a 285/35 config...
So, how much offset will I need? Fender rolling is a given.
Help me out and drinks are free next time you're in Vegas! On Jcain's tab...
I'm running 18x9's (Boyd Codington F-22s) with the Nitto 555 285 DRs. I have a 56.25mm offset, and it's about perfect. I barely had to roll my fenders.
I'm running that exact combo,18x9.5 45 mm offset full fender roll and they still rub under hard accel. or over medium sized bumps,WORSE with a full tank/rear passengers or a lot of stuff in the trunk.The driver side is much worse as it sits lower even when I'm not in the car.I haven't installed my drag bags yet but I think with them it will be OK.
Captain Thread Killer returns
I dunno but :fawkdance :fawkdance :fawkdance
Puppy Power!!
"18x9.5/285-35 Nitto 555- DRs"
THat is why you are having issues with rubbing. the 275 Nitto's run narrow but the 285's are run a bit wide. Put 275 BFG's on there and you should be much better off.
Discussion Starter · #8 · (Edited)
Hmmm...more offset needed then perhaps. They're rubbing on the fender even w/full roll? Dayum. Bags should definitely help...
Bob seems confident...or just wants a free drink or two. You might just get one :) I know you're running some wide ones...(since I wrote this you've replied. Damn brotha that is one sweeeeet goat...)
Sdgoat, I read your thread about your wheels/tires thoroughly before I posted this, that is a great looking setup you have. I was going to send you a PM but saw you have 9s...I'm not a wheel/tire person so wasn't sure if the extra 0.5" width would make a difference.
And DBlue, Shirley Temples weren't included in this deal, so no drinks for you anyways. :bootyshak
sincitygoats.com
maybe you'll axtually drive the car if it had nice rims on it...
Discussion Starter · #10 ·
^Quiet ho. Get back on the corner.
BTW...next gen EVO just entered my garage :sneaky:...right hand drive. Mule, camo...looks purty nasty. They're not picking it up till 830am if you wanna see it...i know deep down u love the rice.
sincitygoats.com
how early you get to work? i get off at 5am
lets go race it with the gtslow
Discussion Starter · #12 ·
being that it's 8pm and i'm still here, not that early but by 7.
it smells like burnt clutch and looks like it's going to fall apart. Plus how the hell am I going to shift w/my left arm? it's right hand drive. I'll wreck the damn thing...wait till vipers come back...
now get back out there and make me some $.
I'm running a drift R 18x 9.5 w/49mm offset. With some minor hammering on the trunk area inside the wheel well, and a nice fender roll. A 1\2 inch pedder raise in the rear. I am able to run a 295/35/18 BFG KDW DR under extreme conditions.
Drew
Discussion Starter · #16 ·
now? or in the morning? get here AT 7am. if they see me showing it to you grab a tool and pretend you work here. wait i've seen you with tools before...grab a broom and sweep instead...:stickpoke
Thruxtons don't come with a 55mm offset, last I heard 45 was it.Keep in mind I weight 235lbs and it seems that the rear on my car is lower than most.As for BFGs I'll never buy another BFG product.I had 315-18 DRs on my SS and after less than 1500 miles the sidewalls were cracking all the way around and the tire shop refused to mount them.I notified Tirerack & BFG it took 6 months for them to tell me basically to go **** myself ,they wouldn't replace them cuz they said that was a racing tire,so I told them to give them back and they refused because they knew they were unsafe.So they basically stole my $$$ and tires.I will go with Nittos 4ever ,plus I like all my tires to match.
Discussion Starter · #18 ·
Drew
dayum that's a lot of tire...might be the widest you can come close to fitting...nice
Discussion Starter · #19 ·
Thanks for the info...getting a lot of good info here!
1 - 20 of 27 Posts
