i went into a shop to have my A/C system reharged after the cam installation.
the guys did vacum the system twice and recharged the system twice with the same behavior, the A/C compressor is going on and off really quick, like every 2-3 sec. they were telling me the pressure in the system is going to almost 400PSI and the shut off valve is kicking in shutting down the compressor as soon as the PSI goes that high.
the guys didn't know what might be wrong since they don't see any leaks at all, also the system is just taking 1.7lbs of freon instead of the recommended 1.81lbs.
i'm clueless about this, has anybody seen or had the same problem ???
is there something that needs to be reset so the compressor can work as expected ??
