1 - 9 of 9 Posts
I was wondering if it’s possible at all to use the ls3 ecu when swapping into a goat and make it work with the car? I’m also wondering if my JBA long tubes will bolt up to ls3 heads? Thanks for any help.
It will be much less work not doing it that way. You can get a 58x to 24x converter from ligenfelter if you are just planning on swapping an a whole LS3 engine and keep the stock ECU.
And all LS exhaust flanges are pretty much the same.
|G|et |T|urned |O|n
The Lingenfelter trigger box works very well and is reliable. Have had mine in for several years now with an LS376/480. I did buy an extra one just in case, but haven’t needed it.
Awesome, glad to hear that it’s reliable
Wol Gemut
thank you gentlemen. I should have noted, what I am looking at is the LS7. since that stroke is 4.0, would this be a good solution? (outside of price)
1 - 9 of 9 Posts
