1 - 16 of 16 Posts
· Registered
Having this weird issue where my ABS light comes on during a system check complete start up. ABS light comes on for a second and goes away. No ABS codes or any issues when driving. The light does not come on if I start it right away without waiting for the system check complete. Any advice is appreciated. Thanks
VIdeo of Problem.
· Registered
Discussion Starter · #4 · (Edited)
· Worthless reject member
sung and very small amount of corrosion, battery is little over a year old. Have not got it tested yet.
i would do that.
you might want to go into the secret menu and display system volage while you crank, see how low the voltage dips.
· Registered
Discussion Starter · #6 ·
Will definitely do, voltage dropped down to 9.2-10.4 during start up. 11-12 with key in and 14 while running
9.2 volts is pretty low during cranking. it's possible that's your issue.
if it was fully charged on key-on it should be in the mid 12's.
· Registered
2006 Pontiac GTO
I remember having that issue long ago while the car was still under warranty and had even taken it in for that. They didn't find anything and I have not had that issue for a long time 🤞.. no idea what it was or why/how it went away. I'll probably eat my words and it comes back now. Battery going bad sounds like a possible cause.
· Registered
Discussion Starter · #9 ·
Got the battery tested at ye’ol autozone came back good.
· Registered
Discussion Starter · #10 ·
Don't want to start throwing parts at it, are any other test or things to check you think I should do?
· Registered
Discussion Starter · #12 ·
is it still doing it now with a fully charged battery?
is the voltage still dipping into the 9's?
Yes still dipped down into the 9s on a cold start will have to drive to more to get the battery fully charged.
might want to invest in a battery tender.
if your connections on the battery/starter harness are all good, maybe have the starter tested, and clean the mating surface between the starter and the block.
· Registered
Discussion Starter · #14 ·
Drove it so the battery can charge and the ABS fault did not come on with a full start. Will definitely clean up the leads on the battery and starter.
I would like to use a tender but I park it on the street.
· Registered
I had an ABS light come on steady on my 04. My Shop guy that cleared it said it was cause by the seatbelt tensioner rheostat . Who knew our cars even had one?? It hasn't reoccurred.
i think he might have meant the pretensioner.
that does bring up a good point, though... should check the abs codes.
1 - 16 of 16 Posts
