Curious what you guys think.
I was planning on keeping my car NA or maybe a Procharger and I have a set of AFR 245 cathedral port heads for that. Contemplating doing an LSA now. Would you just run adapters on the AFR heads or sell them and go LS3 (823) rec port heads with no adapters?
The data I've found shows my 245's flows a little more than 40cfm over LS3 heads on both sides at .600".
Will adapters be a restriction and counteract my heads? If I went rec port heads I don't plan on getting aftermarket heads or getting them ported, just factory heads-probably new. A buddy can get me a set of brand new ones for about $850
One big advantage for me of the LS3 heads would be no need for adapters. I think I'd like to keep the stock hood and do Hinson drop mounts to clear the hood if I went LSA
Thoughts?
Thoughts?
