Totally agree. My nissan 240sx i had turbo-d really drove me nuts with piping/oil&water cooling.
Ive driven a terminator mustang but havent had the experience with a centri (id imagine it was quite like my 240 since it had a smaller turbo)
A centri isn’t really like a turbo at all. None of that hot side stuff under the hood. Self contained oil so no cross contamination or heating of engine oil. No lag and no load dependent boost as boost is directly related to rpm. Linear power delivery so it’s predictable and controllable power so you don’t wait for boost and then suddenly come into boost blowing the tires off on high horse power setups. Way less under hood heat than any other power adder except nitrous. Those lower iat’s not only build power, but are safer for your engine and less likely to cause detonation. Easier maintenance and plug changing than a turbo which is huge if you like to check plugs like I do when tuning. I actually recently pulled my engine to replace the oil pan gasket and the only intercooler piping I had to remove was the pipe at the throttle body.
For the OP’s goal any form of boost will work well. I think he’s narrowed it down to an LSA or procharger, but he could also consider a Magnuson 2300 or 2650 for room to grow. For his goals I would rule out a turbo as it’s way more work. Having to deal with the oiling and under hood issues for that low power isn’t worth it in my opinion.
Here are my personal choices:
Under 500 rwhp:
LSA or roots blower of some type: at this low of power level you will experience the lack of low end the procharger is known for so roots blower gets the nod IMO.
500-700 rwhp:
Either roots or Procharger. At this point you start running enough boost the procharger will not be weak in the low rpm and the midrange starts to really get exciting along with the obvious high rpm power of the centri.
700-1000 rwhp:
Procharger all day every day. At this point low rpm power isn’t an issue. Still not the flat curve of a roots, but you will be making more torque than you can use even with the centri so the linear delivery of the centri at least makes it controllable. Some of the larger roots or twin screws are still an option here as they can make this power level I just prefer the Procharger for a street car in this range.
1000-1200 rwhp:
At this range a turbo finally starts to be worth it IMO. I personally would still go Procharger f1a-94 here, but there is a serious case for a turbo at this point. I would not run a roots or twin screw in a street car at this level you will have stupid amounts of torque with any of the power adders on v8 at this power level. It can be done obviously, but you will probably be slower than the other power adders at this level with a street car.
1200 plus rwhp:
At this point it’s all turbo. The other power adders can make this level, but start getting pretty rowdy and noisy for a street car in order to do it. The ability to easily dial down boost really makes the turbo the best option here.
Obviously most of that is all opinions and is for true street cars as well. If it’s a race car I’m still going Procharger but it will be a gear drive setup and air to water intercooler.
With any form of boost a return system with a boost referenced regulator after the rails is highly recommended. After tuning cars with dead head fuel systems and regulators in the rear just eliminate the head aches and get a proper fuel system in it from the git go. If at all possible run e85 or flex fuel it's so much more forgiving and easier to tune than pump gas as well as adding an easy 50+ rwhp on high hp boosted setups over pump gas. It even makes more power than race gas on boosted setups in most cases.
