1 - 2 of 2 Posts
I am intrested in putting an ASP pulley on my car. I was searching on ls1tech and noticed that if you are using the double roller timing chain that they pulley may not clear. In searching it went on to say that the newer ones would clear and the older ones wouldn't.
Question: Does anyone have any experience where this is concerned?
If I bought the pulley is their any of our vendors that sell it as a kit w/ belts, pulley, and new crank bolt?
Thanks in advance guys.
It comes with the bolt and washer. You'd have to get the appropriate sized belt in addition.
I have it on the Camaro with the stock timing chain without a problem. The only issue I have with it is that sitting for extended period of time with lights on and my fans turned on (like at night), it will tend to not charge sufficiently which leads me to have to rev it some to provide adequate RPM to charge.
Also, this isn't a power adding mod per se. It simply allows the engine to spin up faster.
1 - 2 of 2 Posts
