I just had my half shaft replaced due to the axle bolts falling out now at around 45 mph by letting off of the gas and pushing it just a little bit I have this whruing sound coming from the drivers side rear thats the half shaft thay they replaced. Im thinking bearing as it sounds like something thats dry and they did not replace any bearings here are the items they replaced and the part numbers..
1 92140331 Shaft
1 92067184 Shaft
3 90095191 F - Retainer
6 90278995 Bolt
1 00818353 Spac Case
1 00825394 Spac case
Why they have two shafts listed I do not know as only the drivers side half shaft was replaced. Do you think this is axle or wheel bearing noise as it did not have this whuring sound before the axle fell out and now it does. I do not want to be stuck with a rental again my exsuast is coming monday and I would like to get it put on and drive. If I call my dealer and tell them this will they be able to order the bearings. And it should only take them a day to do this correct? I hope this is the problem...... Getting sick of being without my $30,000 dollar car :banghead:
1 92140331 Shaft
1 92067184 Shaft
6 90278995 Bolt
