have it tested.
honestly, i would just put a new battery in, but i like needlessly spending money.
Car only driven about once a week for 3 months. Battery charger Thurs said 69% when I put it on.
Drove the car a few miles that night, parked it til drove out to the store today, and put it back on the charger. Charger said 79% - w/in 20 min was back to full charge (99%).
What would you do, if you were about to take off on a 4,000 mile trip, a lot of it thru sparsely populated west?
Remove the battery, check the electrolyte levels, charge it , then take it NAPA or Vatozone for testing. While you are there pick up a tool for cleaning the battery posts and cable clamps.Car only driven about once a week for 3 months. Battery charger Thurs said 69% when I put it on.
Is that true? I hadn't really given that possibility any thought.Remove the battery, check the electrolyte levels, charge it , then take it NAPA or Vatozone for testing. While you are there pick up a tool for cleaning the battery posts and cable clamps.
The battery tester will show how many cranking amps it’s able to supply under load. Just checking the battery with your voltmeter won’t determine if it will hold a charge, or if a cell is bad.
GTO owners need to be very careful about not letting the battery voltage run down if the car isn’t being driven weekly. The non-volatile memory in the ECM seems to be sensitive to under voltage conditions. The expense and hassle of replacing a bad ECM in these cars is crazy.
it isn't. most of the gto's out there would have bad ECM's if it were.Is that true? I hadn't really given that possibility any thought.
