1 - 20 of 102 Posts
This is a great page from miscreant. It has all the wiring harness pin outs colors and schematics.
EDIT, This Domain has expired. Click at your own risk.
See post 89
I stickied it and changed the title for you.
Thank you sir! FULL CREDIT to miscreant for the PDFs.
Is it just my browser or is the old title still showing in the thread preview area? I tried to edit it too but it shows your new one, which shows when you click the thread.
Hey AlexandriaGTO,
I'm in Alexandria as well. What stereo did you install, and who did the deed? I had a Sirius mobile unit put in my car a couple of weeks ago at BestBuy at Potomac Yards, but I'm thinking about swapping the stock head unit out for one that is Sirius compatible, and keeping the mobile unit in my house. Any advice would be appreciated!!
Chris
cave dweller
Since this is a stereo section sticky post, I decided to list some helpful links that I found while researching my upcoming stereo mods. Thanks to the first pioneers that documented their adventures. It sure helps the rest of us.
how to replace the door speakers
http://www.ls1gto.com/forums/showthread.php?t=14264
how to replace the rear speakers
http://www.ls1gto.com/forums/showthread.php?t=15410
how to replace the dash tweeters
http://www.ls1gto.com/forums/showthread.php?t=15288
pics of the stock speakers
http://www.ls1gto.com/forums/showthread.php?t=16807
pics of rear side panel and seats removed
http://www.ls1gto.com/forums/showthread.php?t=15891
how to remove the head unit
http://www.ls1gto.com/forums/showthread.php?t=17855
Crutchfield mastersheet for stereo and speaker replacement
http://www.ls1gto.com/forums/showthread.php?t=86825
I like boobs.
Good idea, linking the good in depth threads on the stereo stuff for future reference.
2005 GTO owner
i was looking at the schematics and all i need to know is the damn color of the wires of what one is which speaker wire lol!!! I don't need a huge shematic! I cannot even tell which wires are what color! All i see is a schematic with lots of abbreviations that don't really seem to relate to colors.
Can someone PLEASE help and let me know which speaker wires are what colors? I just need the colors of the speaker wires because i'm using the stock head unit and using a 4-channel LOC so i need to know what all 8 wire colors are.
Thanks,
Rob :huh:
Is this what your asking for?
Left Front: +(tan) -(grey)
Left Right: +(brown/black) -(yellow/blue)
Rear Right: +(blue/orange) -(blue/black)
Rear Front: +(light green) -(green)
Rear Left Subwoofer: +(yellow/white) -(yellow/red)
Rear Right Subwoofer: +(green/white) -(green/red)
Does anyone know how they run the tweets? I have a set of components that I will be putting in, is there any sort of factory crossover?
Collecting "My Lil Ponies"
i just ran new wireing to the tweets. but for the factory crossover, its not showing anything in the schematics that there is one.
2005 GTO owner
normally the tweeter will have an inductor mounted to it as a high pass. Sometimes some tweeters have such a good natural rolloff they don't require any high pass, but i seriously doubt this is the case
i looked at the factory tweets and they do have an inducer on them. oh and yeah the tweets are just spliced in to the door speaker wires also.
Where is the splice? This may be a good place for the crossover
no idea, i just ran new wires for mine
10 sec club on motor
has anyone seen the 06 has door lock button in the center console. got the switch and plate and dummy button and the harness for the center console
from 05 to 06 is the same part number but still no luck finding blank connector yet anyone else trying this
8" member
Bump! I'd like more info about the door lock switch on the 06's too. I'd like to install it in my 05. Somebody do it and write up a how-to for me. :) :)
Discussion Starter #17
Its in the kick panel. You can follow the drivers side connection to where it spilts in the wiring harness. I was unable to locate the passenger side one.
Best to run new wires. Be careful placing a x-over in the kick panels, as people (myself included) have expierenced "noise" from some of the car electronics.
Hey Guys.
PLEASE KNOW THIS!!
It's not an inductor mounteed to the tweeters, it's a capacitor. (they behave in the opposite way to each other with rising frequency)
An inductor is LOWER impedance for lower frequencies, where a capacitor is HIGHER impedance down low. If you put an inductor in series with a tweeter, you'll blow it up!
(for most 4 ohm systems, a tweeter series capacitor of about 6.8uF is appropriate - be sure that it's a "bipolar" type though, or it'll blow up too!)
Cheerz!
Here's some more info for NAV installations:
I used this plug to tap into the Speed Sensor and Reverse sensor for my Eclipse AVN-5435, I'm sure this would be useful for other installs too.
is it supposed to be
left front
right front
rear right
rear left
rear left sub
rear right sub
1 - 20 of 102 Posts
