1 - 3 of 3 Posts
I'm replacing my standard brakes with the upgraded ones off a 400hp VXR. How much fluid do I need to replace and bleed the system and what type of fluid should I use? Super DOT 4 or DOT 5.1? :confused:
Single Digit Stick Shift
Use DOT 4 as the DOT 5 will eat the rubber in the system.
I personally use the Motul 600. If you are changing brakes and flushing everything, I would start with 2 pints.
Good luck and nice choice of brakes.
Thanks for the info. Ordered off e bay from the UK.
1 - 3 of 3 Posts
