So yeah this is the issue I've been having for the past few days. Before that it would crank very confidently so I'm not sure about just chucking money at a starter. I've checked the body harness under the dash as someone said that can cause this issue. For further info these are the codes I have on it:
P2101 Throttle actuator control motor circuit range and performance
P2135 Throttle pedal position sensor/ switch A/B voltage correlation
P2176 Throttle actuator control system idle position not learned
Any help appreciated.
