Yes. In half. Slave: In half. Master: In half. A Stock LS2 pressure plate: probably NOT cut in half, but maybe.
I have some fabrication to do still, but the plan here is to mock up the clutch system in an environment where I can get some pics and vids to show folks what is going on in an area we cannot see, because we dont have transparent bellhousings.
I strongly considered putting a motor to the flywheel. Part of this will be 'bugging' the system to show flaws. A spinning flywheel would show some of these better, but I think you will all get the point. Frankly, its a lot of mass to fling around with out a bellhousing to protect me. A static display will do just fine.
So lets start with the basics. The pedal. From the center of the pivot to the top of the pedal pad is 12". From the top of the pedal pad to the master pivot is 9.5". The pivot is 5.375" from the firewall, and My car with an LS7 and factory Hydraulic bits uses 1.25" of stroke.
Master (of Puppets?)
I submit, one stock master.
I submit one stock master, gutted. Note the lack of an internal return spring. That is a feature normally reserved for Brake Masters, though some OE clutch masters, and the Tilton units used in the GM after market both have them. Brake systems need them because there is no return spring in a disc system except for the Piston-to-bore seal in the caliper. The pedal wouldnt come back up with out it.
It is (basically) a .750" (3/4" for you fractional folks) bore.
The piston is 2.510" long. The bore is 3.9" long. Minus our 1.25" stroke, this leaves us a head space of ~.180", which is just enough to not block the outlet. this will be further documented when I cut the unit in half later.
There is a valve on the end.
There is a cap over the valve, which is just a little rubber diaphragm, and the back side has a copper cap for support. There is a hole in the piston. the purpose of this valve, and the hole it covers, is to re-fill the fluid in use. As the piston comes back, the valve opens, and fluid goes thru, but only if the back side pressure is higher. So even if your slave leaks, you can still draw new fluid from the reservoir. The lip seals on the side of the piston face forward for the same reason.
I put a nail in the hole into the bore from the reservoir connection. Do note that this hole faces the rear.
A 3/16 brake line, bubble flared, fits the outlet quite nicely.
Overall, I see no no faults in this part. If I can generate enough force, I plan to test it to failure pressure. The failure will occur at the Lip seals, unless I bend the pushrod.
Over the next week or so, I will post more, culminating in the Bi-Section of the slave and master. Because im a sick bastard like that.
The Piston does have markings: 'FTE' which could mean 'Ford Tickford Experience' and 'KG 19466 A'
