I realize I am late to the party but this is such an informative thread, I am surprised it has sat for so long. I am in the process of putting my transmission back together but am reserved because of all the back and forth about proper separation of the pressure plate.
I got these numbers from Konnie's actual measurements. Can someone check this math? Why does he only get 0.3125" of travel in his video labeled "stroke with proper spacing"
Slave Cyclinder
Inner D = 1.43, A1 = 1.606
Outer D = 1.85, A2 = 2.688
A2 - A1 = 1.082 in^2 cross section
Master cylinder
D = 0.750, A = 0.442
Stroke = 1.25"
Volume = 0.5525 in^3
Because of an incompressible fluid, fluid volume movement of the master translates to equal fluid volume movement of the slave
Vm = Vs
(1.082 in^2) * slave stroke = 0.5525 in^3
Slave stroke = 0.510 in^3 assuming a full 1.25" of master cylinder stroke
Another thought; as long as the slave cylinder does not hit full extension (which is like 0.930"), shouldn't you always get the same slave stroke and therefore the same separation? It is a sealed hydraulic system and the volume of fluid the master pushes to the slave will be the same regardless of if the slave cylinder starts at the base or 3/8" from the base. There just seems to be a lot of debate on whether or not 0.0625 or 0.200" spacing is better between TOB and PP fingers. Should it not all stroke the same and therefore cause the same separation? I believe that is why it is considered self-adjusting as long as your hydraulic system is full and has no air bubbles.
