I am finishing up my A4 to M6 swap on my 04 GTO. Some of you may know this if you've seen my other thread.
The only thing that is holding me up is that I can not find the connectors that the clutch pedal position sensor connect to. The switch is pictured. It is the switch on the clutch pedal, closest to the floor. There is about 6 inches of wire that come off the switch and split into two connectors. I've taken out the air ducts and all the trim pieces I can to clearly see the main wiring harnesses down there. I've been searching for where these connectors plug into for weeks now with no luck.
Everyone I've talked to said the A4 and M6 interior wiring harnesses are the same and that I just have to find these connectors. If anyone could PLEASE tell me where these are located, I'd really appreciate it. Heck, I'll even send you some $$ through paypal for your time. I just really need to find where these plug into before I :bomb:
I really wanted to keep this swap as clean as possible, but I really need to get this car running. If anyone has a wiring diagram or knows where I can splice the wires for this switch to function properly, please let me know. I have the ECM relocated to the drivers side footwell, so those wires are easy to tap into. The BCM and OBD2 port connectors are also easily accessible.
