1 - 12 of 12 Posts
2005 GTO Red/Black M6
The hesitation only occurs when the engine is cold,no problems starting the car[05-M6] and starting off in first but when I shift to second ,let off the the clutch and step on the gas, the car hesitates for a second and then takes off,the same problem occurs thru the other gears until it warms up a bit,and then it runs perfect.The hesitation is not just a minor blip,but a rather"deep" hesitation.Any thoughts?? Oh,the car had a maggie installed about 3 weeks ago,no problems then,not sure if the maggie tune being so rich would relate to this problem or not......Ron
sincitygoats.com
its in open loop, let it get warm before you get mean with it. you'll thank yourself later.
Discussion Starter · #5 ·
I'm Ron from Jersey,remember me Brian,I did business w/you,any suggestions would be helpful.As I said in my earlier post,I did not have this problem when the maggie was first installed about 3 wks ago,it started doing this about 4 or 5 days ago,not sure if its a maggie problem at all........Ron
Here for a while
Yo Ron! It sounds to me like she is a little cold blooded. I will give Magnuson a call on monday and let you know what I find out.
Sounds like the open loop enrichment needs to be tweaked up in the tune. You can't blame Magnuson, it probably never gets very cold in Ventura.;)
1 - 12 of 12 Posts
