Are you running a 2-bar MAP sensor? If not, you won't be able to derive boost values.sdgoat said:Is it possible to convert MAP values in HP Tuners to boost values (or some other way without actually installing a boost sensor)?
Just what came from the factory, which I assume is a 1-bar MAP sensor (?). Possibly a 2-bar MAP sensor was installed as part of my meth kit. I will check into it.Tim05GTO said:Are you running a 2-bar MAP sensor? If not, you won't be able to derive boost values.
Tim
